Manjaro-specific packages which need an update
A post was merged into an existing topic: Non-Manjaro packages which have been flagged as needing an update
community/grub-btrfs is at 1.11-2, while upstream and arch are at 4.0.1
Newer versions are needed to correctly populate the btrfs snapshot submenu in grub with snapshots taken with snapper -> snap-pac -> snap-pac-grub.
That is nearly two years old, any reason why we are not simply using the Arch build for this?
I don't know; I assume it's an overlay package which has stagnated.
I've removed the overlay package in unstable.
It has been fixed in May of last year with pkgrel 10
https://git.archlinux.org/svntogit/community.git/commit/trunk?h=packages/acetoneiso2&id=4d527af0bff4fa337bf656500a6bad097826f24f
Calamares 3.2.9 got released three days ago.
Release: https://github.com/calamares/calamares/releases/tag/v3.2.9
News: https://calamares.io/calamares-3.2.9-is-out/
Milestone: https://github.com/calamares/calamares/milestone/52?closed=1
@philm Might interest you.
Psst - https://github.com/calamares/calamares/graphs/contributors :wink:
xfconf-gtk3 needs rebuilding against new perl version.
Firefox 67.0.2 has been released with a few linux build bug fixes and improvements according to softpedia
Kind of the opposite ... folks are saying unstable kernel 5.1.9 was released too early?
Security vulnerabilities fixed in Thunderbird 60.7.1
Announced: June 13, 2019
Impact - high
#CVE-2019-11703: Heap buffer overflow in icalparser.c
Reporter
Luis Merino of X41 D-Sec
Impact
high
Description
A flaw in Thunderbird's implementation of iCal causes a heap buffer overflow in parser_get_next_char when processing certain email messages, resulting in a potentially exploitable crash.
References
#CVE-2019-11704: Heap buffer overflow in icalvalue.c
Reporter
Impact
high
Description
A flaw in Thunderbird's implementation of iCal causes a heap buffer overflow in icalmemory_strdup_and_dequote when processing certain email messages, resulting in a potentially exploitable crash.
References
#CVE-2019-11705: Stack buffer overflow in icalrecur.c
Reporter
Impact
high
Description
A flaw in Thunderbird's implementation of iCal causes a stack buffer overflow in icalrecur_add_bydayrules when processing certain email messages, resulting in a potentially exploitable crash.
References
#CVE-2019-11706: Type confusion in icalproperty.c
Reporter
Impact
low
Description
A flaw in Thunderbird's implementation of iCal causes a type confusion in icaltimezone_get_vtimezone_properties when processing certain email messages, resulting in a crash.
References
auracle?
pacaur -Ss auracle
extra/auracle r202.225d9b9-1 [installed]
    A flexible client for the AUR
aur/auracle-git r258.ab0e8d9-1 (37, 6.94215)
@Ste74
2 posts were merged into an existing topic: Non-Manjaro packages which have been flagged as needing an update
Just a reminder :wink:
manjaro:~ >>> pacman -Dkk
error: missing 'snapd-glib' dependency for 'discover-snap'
error: missing 'linux-hardened' dependency for 'usbctl'
error: missing 'taglib-extras' dependency for 'amarok'
error: missing 'python2-wnck' dependency for 'dockbarx'
error: missing 'python2-gconf' dependency for 'dockbarx'
error: missing 'python2-wnck' dependency for 'dockbarx-gtk3'
error: missing 'python2-gconf' dependency for 'dockbarx-gtk3'
error: missing 'linux419-rt-rtl8723bu' dependency for 'linux-rt-lts-manjaro-rtl8723bu'
error: missing 'linux418-rt-nvidia-304xx' dependency for 'linux-rt-manjaro-nvidia-304xx'
error: missing 'catalyst-utils=15.201.1151' dependency for 'linux50-rt-catalyst'
error: missing 'pamac-dev<7.4.0' dependency for 'manjaro-application-utility-dev'
error: missing 'gnome-shell-extension-taskbar' dependency for 'manjaro-gnome-assets-dev'
error: missing 'breeze-kde4' dependency for 'plasma5-themes-menda'
error: missing 'sni-qt' dependency for 'lib32-sni-qt'
It looks like dockbarx and dockbarx-gtk3 need some love @Ste74
spectre-meltdown-checker has had a couple updates since it was mentioned last in this thread:
Since it's only a standalone bash script, maybe it's not necessary?
Reminder about fancontrol-gui that's broken:
I did away with the meltdown-checker package. I don't remember where I got it, but this little script downloads the latest version and runs it. I keep it in my ~/bin directory...I call it meltcheck.
meltcheck.sh
#! /bin/bash
# Spectre & Meltdown downloader & Checker
# Downloads and runs latest version of the Spectre & Meltdown checker
# GPLv2 Sharing is Caring
# Jerry Bezencon 2018
# Variables
CHKR="spectre-meltdown-checker.sh"
SCRIPT="Spectre & Meltdown Checker"
DISTROID=`lsb_release -i`
DISTROREL=`lsb_release -r`
KERNEL=`uname -a`
bold=$(tput bold)
normal=$(tput sgr0)
clear
# Title
echo "============================================================"
echo "Spectre & Meltdown downloader & Checker for Linux"
echo "Downloads the latest version of spectre-meltdown-checker.sh"
echo "Created by Jerry Bezencon of the Linux Lite Project"
echo " "
# Display System information
echo "${bold}$DISTROID${normal}"
echo "${bold}$DISTROREL${normal}"
echo "${bold}Kernel Version: $KERNEL${normal}"
echo " "
# Download Spectre & Meltdown Checker
echo "Stage 1:"
echo " "
echo "Downloading latest $SCRIPT..."; echo " "
test -f  ["$CHKR"] || rm -rf $CHKR
sleep 2
wget https://raw.githubusercontent.com/speed47/spectre-meltdown-checker/master/$CHKR
chmod +x $CHKR
# Check to see if Spectre & Meltdown Checker was downloaded
if [ -f $CHKR ]
then
    echo "======================================================="; echo " "; echo "$SCRIPT downloaded successfully."; echo " "; echo "======================================================="; echo " "
else
    clear; echo "Something went wrong, try again."; echo " "; exit
fi
sed -i '3i clear' $CHKR
# Run Spectre & Meltdown checker
read -n 1 -s -r -p "Press any key to continue..."
clear
echo "Stage 2:"
echo " "
echo "Running $SCRIPT."; echo "Please enter your password:"; echo " "
sudo sh $CHKR
echo " "
read -n 1 -s -r -p "Spectre and Meltdown scan complete. Press any key to exit."
echo " "
exit
Give it a whirl.
@oberon, I noticed conky got a version bump a couple days ago to 1.11.4 -- can you possibly rebuild conky-lua-nv?
