Manjaro-specific packages which need an update
I already use juffed in my lxqt profile.
Perhaps compton-conf in repos would be nice.
https://aur.archlinux.org/packages/compton-conf/
Just saying, we shouldn’t use git versions in repos unless necessary.
I agree with @excalibur1234 we should clean up community repo.
menda-panel can probably be removed.
I agree , more packages are old in the repo and not always used … only i don’t know all pkgs really needed :sweat_smile:
Edit : @artoo Replace you the package, or should I? ( juffed-git with regular juffed )
I you can do, would be great. :slight_smile:
If you replace juffed-qt5-git with juffed from AUR you will pull qt4 dependencies. And there is no juffed-qt5 which is not git.
There is a featherpad which is qt5 and not git, version V0.5.8. The version will be probably updated soon, because the git version is from 2 Mar 2017, V0.5.9
I have try to rebuild the juffed pkg in qt5 but i have this error :
– Found PkgConfig: /usr/bin/pkg-config (found version “0.29.1”)
– Checking for module ‘enca’
– Found enca, version 1.19
– Enca includes:
– Enca library dir:
– Enca library: enca;m
– Plugins: all externally linked cmake-ready plugs will be built
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
QSCINTILLA_LIBRARY (ADVANCED)
linked by target “juffed-engine-qsci” in directory /build/makepkg/juffed-qt5/src/juffed
– Configuring incomplete, errors occurred!
See also “/build/makepkg/juffed-qt5/src/build/CMakeFiles/CMakeOutput.log”.
Any idea ?
qscintilla-qt5 and python-qscintilla-qt5 are installed?
Try to add python-qscintilla-qt5 but same error
python2-qscintilla-qt5 ?
Is it juffed-qt5-git from AUR (or equivalent) you are trying to build?
This
@Ste74
Leave it as is, leave git version, last point release of juffed is from 2013.
You’d have to add patches from git. :wink:
It is exactly (as I can see) the PKGBUILD from juffed-qt5-git from AUR https://aur.archlinux.org/cgit/aur.git/tree/PKGBUILD?h=juffed-qt5-git
juffed-qt5 seems broken
I can’t confirm all will work but it build
in
juffed/cmake/FindQScintilla2.cmake
you need to modify in line 55
    SET(QSCINTILLA_NAMES ${QSCINTILLA_NAMES} qt5scintilla2 libqt5scintilla2 libqscintilla2-qt5 qscintilla2-qt5)
to add or change the 2 last names… to change the “-” to “_”
libqscintilla2-qt5 to libqscintilla2_qt5
qscintilla2-qt5 to qscintilla2_qt5
like this
    SET(QSCINTILLA_NAMES ${QSCINTILLA_NAMES} qt5scintilla2 libqt5scintilla2 libqscintilla2_qt5 qscintilla2_qt5)
or like this
    SET(QSCINTILLA_NAMES ${QSCINTILLA_NAMES} qt5scintilla2 libqt5scintilla2 libqscintilla2-qt5 qscintilla2-qt5 libqscintilla2_qt5 qscintilla2_qt5)
it seems until v2.9.5 of qscintilla the lib name from upstream was qscintilla2 and arch/fedora applied a patch to have
qscintilla2(qt4 version) and qscintilla2-qt5
and since V2.10 (since 26.02.2017), upstream changed and now set the name to qscintilla2_qt$${QT_MAJOR_VERSION} and arch don’t apply the patch anymore
it may change again in future… who knows. :stuck_out_tongue:
Thank you, create a patch and apply . This evening upload in boxit… :slight_smile:
Well juffed-qt5 is in unstable and also @FadeMind your bumblebee patch :wink:
Is not my. It is upstream :stuck_out_tongue_winking_eye: What do you mean? @Ste74
:grin: my misunderstanding :sweat_smile: :yum:
@Ste74, the package glxinfo is gone from Manjaro repos, I don’t know in which repo it was.
Hi @eugen-b , is a part of mesa-demos pkg … you see here ?
Now pacman file search works, so it is easy:
% pacman -Fs glxinfo
extra/mesa-demos 8.3.0-2
    usr/bin/glxinfo
