Manjaro-specific packages which need an update
development
package
manjaro
#413
@oberon
mint-themes is now at 1.7.8
#414
@Ste74 I noticed on updating to timeshift-18.9.1-3-x86_64.pkg.tar.xz that I get the following error in post install:
/tmp/alpm_xEPUW1/.INSTALL: line 25: syntax error: unexpected end of file
/usr/bin/bash: post_upgrade: command not found
error: command failed to execute correctly
Looking at the .INSTALL script, I believe there is a missing } after echo “” on line 14:
        enable_cronie() {
	systemctl enable cronie
  	echo ""
  	msg "Cronie services should now be enabled."
  	msg "Reboot your system, so changes will take affect."
  	echo ""
I am using the unsatble branch.
#415
thanks. updated.
#416
Thank you, rel 4 is online… typo error sorry :roll_eyes:
#417
@fhdk ipscan at 3.5.4
#418
Thank you for pinging me - Updated package v3.5.5 in unstable.
#419
@philm
update-notifier has only yaourt as AUR helper in optional dependencies, but it support also trizen, yay and pacaur since months.
#420
in repo the version is 1.4.8 and the latest is 1.4.9 .Change Log
#421
Weird … etcher isnt in normal arch repos, but we dont seem to have it in our gitlab :-/
But anyways … its on 1.4.9 in Unstable right now.
#422
#423
be careful with repo etcher , check git , version also
#424
(From this thread)
snapd package needs an update. We currently have 2.36.2-1.0 on Testing and Stable, 2.36.3 is available on AUR.
snapd-git is even more out of date, being at 2.34.689-1 (why is this in the repo in the first place?).
Upstream recommends to use AUR to install snapd instead of repo because “it’s outdated”: https://docs.snapcraft.io/installing-snap-on-manjaro-linux/6807
@jonathon @philm
Snapd has been updated in the AUR
#425
Inxi is at v 3.0.30
faba-icon-theme and moka-icon-theme imported in Arch Community from AUR 1 2
#426
It seems that thunar-volman-gtk3 is both in extra and community repositories. I think it should be removed from community.
Repository      : extra
Version         : 0.9.0-1
Repository      : community
Version         : 0.8.1-1
#427
amdvlk and lib32-amdvlk could be updated when there is time for it.
the current one from https://github.com/GPUOpen-Drivers/AMDVLK provides Vulkan 1.1.96 while the one in the repo provides Vulkan 1.1.82
The source mentioned in the PKGBUILD lists 2.68 as current while in the repo, it is 2.63
