Manjaro-specific packages which need an update
development
package
manjaro
#442
pdf2img-c needs to be updated or removed because it does not work.
pdf2img: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
#443
Upstream seems completely dead. When I click on the URL, I just get an error 404.
Build date: 2015-07-13, oh boy.
It’ll most likely be deleted.
#444
Yep. Checking it’s not present in the Arch repo’s and the AUR package was flagged out of date on 2016-11-22. Guessing it was missed that it was removed upstream.
#446
I think xviewer should be rebuild against exempi 2.5.0. @oberon
[Testing Update] 2019-01-27 - Kernels, Browsers, CertBot, Deepin, Wine
#447
Confirmed on Testing.
[awesome@i56400 ~]$ xviewer
xviewer: error while loading shared libraries: libexempi.so.3: cannot open shared object file: No such file or directory
#448
Will do. Thank you.
#449
Why? Firefox is in unstable repos.
Unless you are referring to the x32 build of course …
#450
65 was released at least a day before it was built in Arch. I’m normally slightly ahead of Arch for that.
#453
Who is this unknown, masked packager … :wink: … ?
Version         : 65.0-0
Packager        : Unknown Packager
#454
Chinese hackers took over Manjaro’s repositories. We’re doomed. :scream:
#460
“Imagescan” has recently moved from AUR to community. It is missing a desktop file so no menu entry. Also to access a network printer it needs a “networkscan” file also missing, note this was also missing in the AUR version. Think I pinched it from one of the other imagescan packages.
#461
Regarding upstream Archlinux packages issues would need to be reported directly there :sunglasses:
#462
snapd is due for an update. Upstream and AUR are at 2.37.2, we are at 2.37.
Our snapd is potentially affected by a vulnerability, but the guidances provided by upstream are not really that clear and I can’t figure out if we are actually affected or not.
Anyway, security or not, it is due for an update.
@jonathon
Snap is nightmare of Linux Security - dirty_sock exploit
#463
I’m going to disown that package. I don’t use it, I didn’t add it to Manjaro.
I’ve updated the package files on GitLab, so can some other @Maintainers please pick it up?
#464
…its in the aur ? does it need to be picked up ?
( this has the added benefit of dispelling that weird ‘well if I use snaps I avoid aur so its safer’ thing )
#465
It’s in the AUR, someone added it to the Manjaro repos but didn’t keep it updated so the upstream project said to use the AUR versions instead, it was flagged here, I updated the package once, and now people ping me every time the package needs to be updated.
I don’t mind packaging stuff I use. I don’t use snapd (and never have).
#466
Lol sorry for pinging you.
Mh if no one is interested to maintaining it and keep up with upstream/AUR, I think it should just be dropped. It might be disappointing for users that actually uses snapd, but it’s better to drop it and let them use AUR than just letting it rot in the repo.
If it gets dropped, it would be a good idea to mention it in the announcement once it’s become effective in Stable.
#467
lightdm-settings and lightdm-slick-greeter are out-of-date
#468
In a future step we will integrate a full store into Pamac to have a nice graphical UI for snaps
If Manjaro genuinely supports snaps then it should be in the Manjaro repos.
I don’t use snaps either, can’t see myself every using them either, but obviously some do.
#469
@philm fancontrol-gui needs update.repo version doesnt work while aur git version works
