Manjaro-specific packages which need an update
development
package
manjaro
#248
sorry, i was not fast enough. i thought i would release a bugfix version before you had a chance to rebuild.
you probably have to rebuild the new version 1.10.1 again.
#249
add to the list
Steam runtime - native
#250
@Tids can you check if steam-native is really missing some libraries?
#251
1.10.1 is up.
#252
We should still be fine. Do you miss something?
#253
check the post above mine :wink:
My guess is that the problems come from the preloading of steam-runtime libraries while otherwise running native, but I might be wrong, and my hint appears to be ignored in the thread.
#254
Thats an issue with an EOL’d game, that shipps an (of course) outdated fontconf and the rest of the world, that has moved on to a new config format for configs…
So you just cant use the “to modern” system runtime for this anymore or you need a old version and preload it.
The makers of Torchlight (Runic Games) where bought by “Perfect World”, they now create games for smartphones or something…
Steam - launch Games - old libconfig , missing config files for libconfig
#255
JAK v1.3.3 available :wink:
#256
Etcher, apparently.
Aur version is 2 points ahead.
#257
As @cscs said
Etcher from the AUR is now built from source @FadeMind
On stable branch, launching Etcher give a pop-up windows with error
Summary
TypeError: Cannot read property ‘UPDATE_NOTIFIER_SLEEP_DAYS’ of undefined
at Object.exports.notify (file:///opt/Etcher/resources/app.asar/generated/gui.js:118097:55)
at file:///opt/Etcher/resources/app.asar/generated/gui.js:65202:27
at tryCatcher (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise.js:504:31)
at Promise._settlePromise (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise.js:561:18)
at Promise._settlePromise0 (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise.js:606:10)
at Promise._settlePromises (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise.js:685:18)
at Promise._fulfill (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise.js:630:18)
at Promise._resolveCallback (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise.js:425:57)
at Promise._settlePromiseFromHandler (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise.js:516:17)
at MappingPromiseArray.PromiseArray._resolve (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise_array.js:125:19)
at MappingPromiseArray._filter (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/map.js:123:10)
at MappingPromiseArray._promiseFulfilled (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/map.js:95:18)
at MappingPromiseArray.PromiseArray._iterate (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise_array.js:113:31)
at MappingPromiseArray.init (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise_array.js:77:10)
at Promise._settlePromise (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise.js:558:21)
at Promise._settlePromise (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/promise.js:574:21)
at ReductionPromiseArray._resolve (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/reduce.js:51:19)
at Promise.completed [as _fulfillmentHandler0] (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/reduce.js:112:15)
at Async._drainQueue (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/async.js:138:16)
at Async._drainQueues (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/async.js:148:10)
at Async.drainQueues (/opt/Etcher/resources/app.asar/node_modules/bluebird/js/release/async.js:17:14)
at
at process._tickCallback (internal/process/next_tick.js:109:7)
#258
Hi guys, the fallowing packages, need an update, also if you could push to all branches as jade is broken, Tanks :smile:
jade-dashboard
jade-desktop-mode
lightdm-webkit2-greeter is broken in the repos new v2.2.5 is available
#259
I’m at work for your pkg … what is the problem with webkit2-greeter ( i assume the manjaro version ) ?Our version is 1.3.2 but if you see at pkgbuild source is based on 2.2.5 … If need open an issue on github > community or take a look if your problem is already mentioned on lightdm-webkit2-greeter :wink:
#260
JAK needs a rebuild v1.3.4
Keeping you busy @Ste74 :smiley:
#261
audacious-gtk3 and/or audacious-plugins-gtk3 needs a rebuild. I’m getting bunch of missing plugins messages and some songs wont play (aac codec i think).
#262
I see this pkgs are at last release, please open a specific topic and post terminal output…
#264
the package libmypaint in community can be removed as it has been added in arch repos (extra)
#265
thanks. done.
#267
Please update yay in stable. Thanks.
#268
The package pkgbrowser needs an update in unstable. Because the package depends on pacman<5.1 and with the recent move to pacman 5.1 dependency check fails.
The AUR page suggest that the version 0.21 of pkgbrowser works with pacman 5.1.
https://aur.archlinux.org/packages/pkgbrowser
#269
[New Packages]
pkgbrowser-0.21-1-x86_64.pkg.tar.xz
yay-6.784-1-x86_64.pkg.tar.xz
