Manjaro-specific packages which need an update
development
package
manjaro
#1
This thread is meant to be an information for the Manjaro-Team in case of outdated Manjaro packages in the community repository.
Please feel free and drop a line if you notice a package that is in need of an update.
Please do not report packages as out-of-date if they are up-to-date in the unstable or testing branches. There is normally a one- to two-week delay for packages to reach the stable branch.
Before reporting a package as out-of-date please check the upstream Arch package. Also read:
Suggestions for manjaro repo
Non-Manjaro packages which have been flagged as needing an update
[Unstable Update] 2019-01-04 - Deepin, Certbot, Systemd, Haskell, Python
Snapd has been updated in the AUR
MS-Office-Online not start
Unpatched vulnerabilities in cairo
[Stable Update] 2019-01-23 - Kernels, Mesa, Browsers, Nvidia, Deepin, VirtualBox
Emby Server
Pamac offers updates from AUR against community packages. Is it OK?
Rosegarden 17.12 update request
[Stable Update] 2018-04-14 - Kernels, Gnome v3.28.1, Libreoffice, Browsers, Mesa, Deepin, Mate
Not all spectre meltdown vulnerabilities are patched when using the following cpus :
Dmd and libphobos outdated
Questions related to the Brave browser
Where to ask for package bugfix updates? (+ My irrelevant opinion on manjaro repos)
Manjaro Repository Request
#2
I have sometimes crashes with aMule on Manajro Xfce Testing.
Reporting one of those crashes led the discussion to this:
Me: Manjaro / Arch provided a new(er) version of aMule 10958 (17th September)
Admin: That’s almost 2.3.2… Why not that?
Admin: 10960 is identical to 2.3.2 except that it identifies itself as a
development version. The real 2.3.2 release tarball can be found on SourceForge.
So please add the actual aMule release into the repos or AUR.
Thanks in advance
LAZA
P.S.: Sorry for the wrong thread - mentioned it after posting…
#3
dropbox from community repository seems unmantained from July, looking at AUR page for dropbox package it appears that there were many releases in the last few months.
Anyway dropbox has the bad habit to update by itself, so everyone should have the last version installed.
#4
I haven’t been checking but are bspwm-manjaro and sxhkd up to speed with their upstream versions?
#5
Dropbox pkg updated … bspwm-manjaro i see not update in upstream , sxhkd in progress to update :wink:
:grin: arch community repo
At some point we would need to switch to generic bspwm.
#8
I tried this a while back but i couldn’t get my config file to work. i went back to bspwm-manjaro because i was busy and needed to get stuff done and sort of forgot about the whole thing til now :smiley:
tcp_wrappers/tcp-wrappers/libwrap situation
I’ve noticed that there are two version of tcp wrappers but before today it wasn’t a problem,
here there is what I found:
tcp_wrappers v=7.6-16
needed by ‘lib32-tcp_wrappers’ 'steam-manjaro’
https://github.com/manjaro/packages-community/blob/master/tcp_wrappers (link is right?)
source=(ftp://ftp.porcupine.org/pub/security/tcp_wrappers_${pkgver}.tar.gz
http://archlinux-stuff.googlecode.com/files/tcp-wrappers-${pkgver}%2B.patch.gz
hosts.allow
hosts.deny)
Some of the files installed, provide libwrap but don’t declare it in PKGBUILD
/usr/lib/libwrap.a
/usr/lib/libwrap.so
/usr/lib/libwrap.so.0
/usr/lib/libwrap.so.0.7.6
tcp-wrappers v=7.6.24-3
https://www.archlinux.org/packages/community/x86_64/tcp-wrappers/
seems a split package
pkgname=(‘libwrap’ ‘tcp-wrappers’)
source=(“ftp://ftp.porcupine.org/pub/security/tcp_wrappers_${pkgver%.}.tar.gz"
"http://http.debian.net/debian/pool/main/t/tcp-wrappers/tcp-wrappers_${pkgver%.
}.q-${pkgver##*.}.debian.tar.xz”
‘tcp-wrappers-headers.patch’
‘tcp-wrappers-redhat-bug11881.patch’
‘hosts.allow’
‘hosts.deny’)
  • tcp_wrappers is needed by steam-manjaro, provide libwrap but don’t declare it
  • tcp-wrappers from Arch seems a split pkg with libwrap, with different patches
  • last revision of ginkgo-cadx [AUR] add libwrap as dependency, so there are conflicts like ‘$filename exist in filesystem’ or removing Steam (not a problem for me since I can edit it’s pkgbuild)
  • https://github.com/manjaro/packages-community/blob/master/tcp_wrappers fails to build
curl: (22) The requested URL returned error: 404 Not Found
==> ERRORE: Impossibile scaricare http://archlinux-stuff.googlecode.com/files/tcp-wrappers-7.6%2B.patch.gz
A possible solution cloud be adding
provides=(‘tcp_wrappers’ ‘libwrap’)
to tcp_wrappers pkgbuild but fails to build
Also the license need an update, seems a BSD style license
ftp://ftp.porcupine.org/pub/security/tcp_wrappers_license
license=(‘custom:TCP Wrappers license’)
Edit 1
found the patch, same md5sum
https://storage.googleapis.com/google-code-archive-downloads/v2/code.google.com/archlinux-stuff/tcp-wrappers-7.6+.patch.gz
Edit 2
Also https://github.com/manjaro/packages-multilib/tree/master/lib32-tcp_wrappers use the same patch
Please provide a working PKGBUILD and we consider to update it.
#11
Here they are
https://github.com/FabioLolix/PKGBUILD/tree/master/tcp_wrappers
https://github.com/FabioLolix/PKGBUILD/tree/master/lib32-tcp_wrappers
#12
Please test and give feedback.
#13
sudo pacman -U pkg
caricamento dei pacchetti in corso…
risoluzione delle dipendenze in corso…
ricerca dei pacchetti in conflitto in corso…
Pacchetti (3) lib32-tcp_wrappers-7.6-19 steam-manjaro-1.0.0.53-1 tcp_wrappers-7.6-17
Dimensione totale dei pacchetti da installare: 2,93 MiB
Dimensione netta dell’aggiornamento: -0,08 MiB
:: Vuoi procedere con l’installazione? [S/n] s
(3/3) verifica delle chiavi presenti nel portachiavi [################################################################] 100%
(3/3) verifica dell’integrità dei pacchetti [################################################################] 100%
(3/3) caricamento dei file dei pacchetti [################################################################] 100%
(3/3) controllo dei conflitti in corso [################################################################] 100%
:: Elaborazione delle modifiche al pacchetto…
(1/3) aggiornamento in corso di tcp_wrappers [################################################################] 100%
(2/3) aggiornamento in corso di lib32-tcp_wrappers [################################################################] 100%
(3/3) aggiornamento in corso di steam-manjaro [################################################################] 100%
If you are running x86_64, you need the lib32 opt depends for your driver - check that mhwd has it correctly set
If you are having problems with the steam license, remove .steam and .local/share/Steam
Library issues can be fixed with the Steam (Purge Libraries) launcher
Check https://forum.manjaro.org/index.php?topic=16054.msg149783 for info
:: Esecuzione degli hook di post-transazione…
(1/2) Updating icon theme caches…
(2/2) Updating the desktop file MIME type cache…
It’s gone well, Steam and ginkgo-cadx are both ok
However lib32-tcp_wrappers and lib32-libwrap conflicts on filesystem like 64bit versions did before
Adding this to lib32-tcp_wrappers pkgbuild should be ok?
provides=(‘lib32-tcp_wrappers-libs’ ‘lib32-libwrap’)
conflicts=(‘lib32-tcp_wrappers-libs’ ‘lib32-libwrap’)
https://github.com/FabioLolix/packages-multilib/blob/master/lib32-tcp_wrappers/PKGBUILD
see https://git.archlinux.org/svntogit/community.git/tree/trunk/PKGBUILD?h=packages/lib32-libwrap
For curoisity why we can’t use Arch upstream version of tcp-wrappers/lib32-libwrap?
There is a problem with the patches they’re using?
pinned #14
split this topic #15
66 posts were split to a new topic: Non-Manjaro packages which are flagged as needing an update
#24
i suggest to only UPDATE packages mentioned in this topic.
about half a year ago, phil has asked about which packages we can remove from the manjaro repos, because there is a lot of clutter, which got collected over the years.
so, please do not add any unnecessary packages (or even remove such packages). rather tell people to ask in the rest of the forum how to fix a PKGBUILD from the AUR, for example in this category: https://forum.manjaro.org/c/technical-issues-and-assistance/aur
I agree :slight_smile:
#26
Ok, thank you very much for the info!! :slight_smile:
Greetings!!
#27
Hi guys. Thank you for you great work! I noticed “xfce4-dockbarx-plugin” package is out of date both in manjaro repo and in aur. Here is a link with commit to the latest version - https://github.com/TiZ-EX1/xfce4-dockbarx-plugin/commit/b2965fc49afc891720a974946cf4bd93042427c0
#28
Thank you update and in unstable now :slight_smile:
