Hi fellows!!! How i say before , when upgrade to linux 6.6 my system doenst power off, screen goes black but mouse and other indicators still on!!! Iǘe upgraded to linux 6.7 experimental (righ now) and all fine…Here the output of inxi -Fazy with 6.7…
~ inxi -Fazy ✔
Kernel: 6.7.0-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=034cce20-46f0-4762-a989-90f4125f7af9 rw quiet splash apparmor=1
security=apparmor resume=UUID=35dedb6e-40ca-4832-b4a1-6fa39675484b
udev.log_priority=3
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B1500CEAEY_B1500CEAE
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: B1500CEAEY v: 1.0 serial: <superuser required>
UEFI: ASUSTeK v: B1500CEAEY.321 date: 12/22/2022
ID-1: BAT0 charge: 34.4 Wh (100.0%) condition: 34.4/42.1 Wh (81.9%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 100
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard PID:0055
serial: N/A charge: 70% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse PID:003f
serial: N/A charge: 55% (should be ignored) rechargeable: yes
status: discharging
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 941 high: 1201 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1175 2: 400 3: 1201
4: 1035 5: 953 6: 400 7: 1166 8: 1200 bogomips: 44864
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-3,eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:7 chip-ID: 13d3:56a2
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: DP-3 model: Dell E178FP serial: <filter> built: 2009
res: 1280x1024 dpi: 96 gamma: 1.2 size: 338x270mm (13.31x10.63")
diag: 433mm (17") ratio: 5:4 modes: max: 1280x1024 min: 720x400
Monitor-2: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2017 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.96 GiB unified: yes display-ID: :0.0
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.7.0-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 0000:00:1f.6 chip-ID: 8086:15fc class-ID: 0200
IF: eno2 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:9 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.15 TiB used: 622.7 GiB (52.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1002 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 9300 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 model: USB DISK size: 3.73 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: DL07 scheme: MBR
ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 29.35 GiB (76.9%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 29.3 GiB size: 28.67 GiB (97.86%)
used: 6.4 GiB (22.3%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2400
Processes: 302 Uptime: 3m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.32 GiB used: 2.46 GiB (16.0%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1416 libs: 329 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.31
