Manjaro Settings Manager looks bad
As u can see, with these appearance settings the settings manager not looking good…all texts are not visible…Gnome 20.2 with kernel 5.10
What themes are you using in qt5ct/kvantum?
Those control the looks of QT apps on Gnome.
I have only changed settings in gnome tweaks appearance section…nothing else…fresh installation of manjaro gnome.
Yeah, so your Qt theme settings is probably the light ones by default. So you should change those. :slight_smile:
yup…made it dark
apps: matcha dark azul
icons: papirus dark
shell: matcha dark azul
