Manjaro Settings Manager - kernels not listed
I just did a system update (2024-01-02) and got a notification from Manjaro Settings Manager. I checked for new kernels and got an “empty” list. Well, not empty, but only my currently installed kernels are listed, all of them marked as unsupported.
A reboot didn’t solve it. I have no clue.
msm
Hi @Aerond,
I did the update myself, no more than 2 hours ago, and just checked:
https://i.imgur.com/6llDk4o.png
So, I suggest updating your mirrors and package lists:
sudo pacman-mirrors --fasttrack=5 && sudo pacman -Syy
Where:
  • --fasttrack=5 will set it to the 5 fastest successfuly synchronised mirrors for you; and
  • -Syy will force pacman to update the package list even if it thinks there is no need.
Note:
I just realised this can expose/result in a partially-upgraded state, so best rather do:
sudo pacman-mirrors --fasttrack=5 && sudo pacman -Syyu
Where:
  • -Syyu upgrades the necessary packages as well.
That worked perfectly. Thanks a lot!
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
