How do we have pacman -Syu
or of its option else can have answer NO on a confirmation
Why would you want that? If you don’t want to upgrade your system ─ which will lead to breakage over time, as you should know by now ─ then don’t run the command.
With most commands including this one, you can cancel with Ctrl+C.
If you for some reason want to cancel the update you can do so using @Yochanan’s suggestion.
There is the possibility of using the --noconfirm option but this only works for questions where Yes is the default - some questions default to No and the sync will stop.
However cancelling the process is only safe during the download phase - if the process is interrupted during the actual replace operation - either on purpose or by accident - some pacman hooks may not be processed and - depending on the situation - this may render your system unbootable.
So taking great care and knowing exactly what will happen is an absolute requirement.
