Hello,
I don’t know if I put the subject in the right category, so sorry if it’s not the case. Don’t hesitate to tell me to move it in this case.
My issue is very strange: when I start to use LibreOffice Writer, after a few time the screen starts to freeze randomly for a quick time, and then after few minutes the session restarts completely and all my applications are stopped. I don’t know where it does come from.
What commands do you want me to launch to give you some logs?
Thank you much for your help. Good day!
Hello,
Without knowing what DE you use (KDE Plasma, Gnome, XFCE, or some WM) is hard to tell, but usually either you set LibreOffice to run at startup or you set your session to launch as was last logout, or you manually saved it.
On KDE Plasma is like this:
Hello,
I’m using Gnome Shell, but I don’t think it’s a normal behavior. The session is completely restarted after few minutes, like if LibreOffice was crashing GDM or the Linux kernel.
you should look in the journal and see if what crashed the session was logged.
journalctl -b 0
for the current boot.
If your computer reboots due to the problem then -b -1 to see journal for previous boot
From GNOME/Troubleshooting - ArchWiki
The problem can be temporarily worked around by removing the files in ~/.config/gnome-session/saved-session
. A more lasting work-around is to disable the session manager’s auto-save-session
feature:
gsettings set org.gnome.SessionManager auto-save-session false
You can also use this regardless that Debian is mentioned
So you just disable it …
avril 01 08:55:08 Hostname touchegg.desktop[28248]: Reconnecting in 5 seconds...
avril 01 08:55:08 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 08:55:08 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:08 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
avril 01 08:55:11 Hostname gnome-shell[27929]: Window manager warning: WM_TRANSIENT_FOR window 0x3a289c5 for 0x3a2dc82 window override-redirect is an override-redirect window and this is not correct accor>
avril 01 08:55:13 Hostname touchegg.desktop[28248]: Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:13 Hostname touchegg.desktop[28248]: Reconnecting in 5 seconds...
avril 01 08:55:13 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 08:55:13 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:13 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
avril 01 08:55:15 Hostname gnome-shell[27929]: Window manager warning: WM_TRANSIENT_FOR window 0x3a289c5 for 0x3a2e02f window override-redirect is an override-redirect window and this is not correct accor>
avril 01 08:55:18 Hostname touchegg.desktop[28248]: Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:18 Hostname touchegg.desktop[28248]: Reconnecting in 5 seconds...
avril 01 08:55:18 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 08:55:18 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:18 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
avril 01 08:55:23 Hostname touchegg.desktop[28248]: Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:23 Hostname touchegg.desktop[28248]: Reconnecting in 5 seconds...
avril 01 08:55:23 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 08:55:23 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:23 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
avril 01 08:55:23 Hostname gnome-shell[27929]: JS ERROR: TypeError: this.actor is null
_syncEnabled@resource:///org/gnome/shell/ui/windowManager.js:138:25
onStopped@resource:///org/gnome/shell/ui/windowManager.js:150:35
_makeEaseCallback/<@resource:///org/gnome/shell/ui/environment.js:150:22
_easeActorProperty/<@resource:///org/gnome/shell/ui/environment.js:316:60
_destroyWindowDone@resource:///org/gnome/shell/ui/windowManager.js:1596:21
onStopped@resource:///org/gnome/shell/ui/windowManager.js:1584:39
_easeActor/<@resource:///org/gnome/shell/ui/environment.js:239:64
avril 01 08:55:24 Hostname dbus-daemon[27816]: [session uid=1000 pid=27816] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.>
avril 01 08:55:24 Hostname systemd[27795]: Starting Tracker metadata extractor...
avril 01 08:55:24 Hostname dbus-daemon[27816]: [session uid=1000 pid=27816] Successfully activated service 'org.freedesktop.Tracker3.Miner.Extract'
avril 01 08:55:24 Hostname systemd[27795]: Started Tracker metadata extractor.
avril 01 08:55:28 Hostname touchegg.desktop[28248]: Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:28 Hostname touchegg.desktop[28248]: Reconnecting in 5 seconds...
avril 01 08:55:28 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 08:55:28 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:28 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
avril 01 08:55:31 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:31,693 [onedrivegui:2026][fn=__init__][INFO] - [GUI] Starting worker for profile Efrei
avril 01 08:55:31 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:31,694 [onedrivegui:2030][fn=__init__][DEBUG] - [GUI] OneDrive config file: /home/illan/.config/onedrive/accounts/Efrei/config
avril 01 08:55:31 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:31,694 [onedrivegui:2031][fn=__init__][DEBUG] - [GUI] OneDrive config dir: <re.Match object; span=(0, 50), match='/home/illan/.confi>
avril 01 08:55:31 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:31,694 [onedrivegui:2033][fn=__init__][DEBUG] - [GUI] Monitoring command: 'exec onedrive --confdir='/home/illan/.config/onedrive/acc>
avril 01 08:55:31 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:31,694 [onedrivegui:2570][fn=start_onedrive_monitor][INFO] - [GUI] Opening WebEngine login window
avril 01 08:55:31 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:31,704 [onedrivegui:2224][fn=read_stderr][ERROR] - [Efrei] onedrive: error while loading shared libraries: libphobos2-ldc-shared.so.>
avril 01 08:55:32 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:32,704 [onedrivegui:2577][fn=<lambda>][INFO] - finished worker Efrei
avril 01 08:55:32 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:32,705 [onedrivegui:2037][fn=stop_worker][INFO] - [Efrei] Waiting for worker to finish...
avril 01 08:55:32 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:32,705 [onedrivegui:2041][fn=stop_worker][INFO] - [Efrei] Quitting thread
avril 01 08:55:32 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:32,705 [onedrivegui:2044][fn=stop_worker][INFO] - [Efrei] Removing thread info
avril 01 08:55:32 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:32,705 [onedrivegui:2047][fn=stop_worker][INFO] - [GUI] Remaining running workers: {}
avril 01 08:55:33 Hostname touchegg.desktop[28248]: Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:33 Hostname touchegg.desktop[28248]: Reconnecting in 5 seconds...
avril 01 08:55:33 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 08:55:33 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:33 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
avril 01 08:55:36 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:36,732 [onedrivegui:2026][fn=__init__][INFO] - [GUI] Starting worker for profile Efrei
avril 01 08:55:36 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:36,732 [onedrivegui:2030][fn=__init__][DEBUG] - [GUI] OneDrive config file: /home/illan/.config/onedrive/accounts/Efrei/config
avril 01 08:55:36 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:36,733 [onedrivegui:2031][fn=__init__][DEBUG] - [GUI] OneDrive config dir: <re.Match object; span=(0, 50), match='/home/illan/.confi>
avril 01 08:55:36 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:36,733 [onedrivegui:2033][fn=__init__][DEBUG] - [GUI] Monitoring command: 'exec onedrive --confdir='/home/illan/.config/onedrive/acc>
avril 01 08:55:36 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:36,733 [onedrivegui:2570][fn=start_onedrive_monitor][INFO] - [GUI] Opening WebEngine login window
avril 01 08:55:36 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:36,743 [onedrivegui:2224][fn=read_stderr][ERROR] - [Efrei] onedrive: error while loading shared libraries: libphobos2-ldc-shared.so.>
avril 01 08:55:37 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:37,743 [onedrivegui:2577][fn=<lambda>][INFO] - finished worker Efrei
avril 01 08:55:37 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:37,743 [onedrivegui:2037][fn=stop_worker][INFO] - [Efrei] Waiting for worker to finish...
avril 01 08:55:37 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:37,743 [onedrivegui:2041][fn=stop_worker][INFO] - [Efrei] Quitting thread
avril 01 08:55:37 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:37,743 [onedrivegui:2044][fn=stop_worker][INFO] - [Efrei] Removing thread info
avril 01 08:55:37 Hostname onedrivegui.desktop[28255]: 2023-04-01 08:55:37,743 [onedrivegui:2047][fn=stop_worker][INFO] - [GUI] Remaining running workers: {}
avril 01 08:55:38 Hostname gnome-shell[27929]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x560fa9032ce0] is on because it needs an allocation.
avril 01 08:55:38 Hostname gnome-shell[27929]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x560fa73f3810] is on because it needs an allocation.
avril 01 08:55:38 Hostname touchegg.desktop[28248]: Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:38 Hostname touchegg.desktop[28248]: Reconnecting in 5 seconds...
avril 01 08:55:38 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 08:55:38 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:38 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
avril 01 08:55:41 Hostname gnome-shell[27929]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x560fa910bf00] is on because it needs an allocation.
avril 01 08:55:41 Hostname gnome-shell[27929]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x560fa7af2e60] is on because it needs an allocation.
avril 01 08:55:43 Hostname touchegg.desktop[28248]: Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:43 Hostname touchegg.desktop[28248]: Reconnecting in 5 seconds...
avril 01 08:55:43 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 08:55:43 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 08:55:43 Hostname gnome-shell[27929]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
Very strangely, this screen freezing and then restarting completely my session (with no applications running) seems to be only the result of me using LibreOffice Writer.
you need to scroll (using arrow up/down and pgup/pgdown) to the time the crahs happened, and see if you can find any messages related to it. What you posted is mainly errors related to touchscreen gesture support (Touchégg daemon)
disable it
systemctl disable --now touchegg
and reboot, then try libre office again, and provide output of the journal again at the time the crash happened
journalctl -b -1
avril 01 08:57:03 Hostname kernel: Linux version 6.2.8-1-MANJARO (buildus>
avril 01 08:57:03 Hostname kernel: Command line: BOOT_IMAGE=/boot/vmlinuz>
avril 01 08:57:03 Hostname kernel: x86/fpu: Supporting XSAVE feature 0x00>
avril 01 08:57:03 Hostname kernel: x86/fpu: Supporting XSAVE feature 0x01>
avril 01 08:57:03 Hostname kernel: x86/fpu: xstate_offset[2]: 576, xstat>
avril 01 08:57:03 Hostname kernel: x86/fpu: xstate_offset[3]: 832, xstat>
avril 01 08:57:03 Hostname kernel: x86/fpu: xstate_offset[4]: 896, xstat>
avril 01 08:57:03 Hostname kernel: x86/fpu: Enabled xstate features 0x1f,>
avril 01 08:57:03 Hostname kernel: signal: max sigframe size: 2032
avril 01 08:57:03 Hostname kernel: BIOS-provided physical RAM map:
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x0000000000000000-0x0>
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x0000000000058000-0x0>
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x0000000000059000-0x0>
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x000000000009e000-0x0>
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x0000000000100000-0x0>
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x0000000021a68000-0x0>
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x0000000021a69000-0x0>
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x0000000021ab3000-0x0>
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x000000003695b000-0x0>
avril 01 08:57:03 Hostname kernel: BIOS-e820: [mem 0x0000000036d18000-0x0>
...skipping...
avril 01 11:08:40 Hostname systemd[1]: Reached target System Shutdown.
avril 01 11:08:40 Hostname systemd[1]: Reached target Late Shutdown Servi>
avril 01 11:08:40 Hostname systemd[1]: systemd-reboot.service: Deactivate>
avril 01 11:08:40 Hostname systemd[1]: Finished System Reboot.
avril 01 11:08:40 Hostname audit[1]: SERVICE_START pid=1 uid=0 auid=42949>
avril 01 11:08:40 Hostname audit[1]: SERVICE_STOP pid=1 uid=0 auid=429496>
avril 01 11:08:40 Hostname systemd[1]: Reached target System Reboot.
avril 01 11:08:40 Hostname systemd[1]: Shutting down.
avril 01 11:08:40 Hostname audit: BPF prog-id=151 op=UNLOAD
avril 01 11:08:40 Hostname audit: BPF prog-id=150 op=UNLOAD
avril 01 11:08:40 Hostname audit: BPF prog-id=149 op=UNLOAD
avril 01 11:08:40 Hostname audit: BPF prog-id=156 op=UNLOAD
avril 01 11:08:40 Hostname audit: BPF prog-id=155 op=UNLOAD
avril 01 11:08:40 Hostname audit: BPF prog-id=23 op=UNLOAD
avril 01 11:08:40 Hostname systemd[1]: Using hardware watchdog 'iTCO_wdt'>
avril 01 11:08:40 Hostname systemd[1]: Watchdog running with a timeout of>
avril 01 11:08:40 Hostname kernel: watchdog: watchdog0: watchdog did not >
avril 01 11:08:40 Hostname systemd-shutdown[1]: Using hardware watchdog '>
avril 01 11:08:40 Hostname systemd-shutdown[1]: Watchdog running with a t>
avril 01 11:08:40 Hostname systemd-shutdown[1]: Syncing filesystems and b>
avril 01 11:08:40 Hostname systemd-shutdown[1]: Sending SIGTERM to remain>
avril 01 11:08:40 Hostname systemd-journald[305]: Received SIGTERM from P>
avril 01 11:08:40 Hostname systemd-journald[305]: Journal stopped
lines 17768-17790/17790 (END)
avril 01 11:08:40 Hostname systemd[1]: Reached target Late Shutdown Services.
avril 01 11:08:40 Hostname systemd[1]: systemd-reboot.service: Deactivated successfully.
avril 01 11:08:40 Hostname audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? re>
avril 01 11:08:40 Hostname audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res>
avril 01 11:08:40 Hostname systemd[1]: Using hardware watchdog 'iTCO_wdt', version 0, device /dev/watchdog0
avril 01 11:08:40 Hostname systemd[1]: Watchdog running with a timeout of 10min.
avril 01 11:08:40 Hostname kernel: watchdog: watchdog0: watchdog did not stop!
avril 01 11:08:40 Hostname systemd-shutdown[1]: Using hardware watchdog 'iTCO_wdt', version 0, device /dev/watchdog0
avril 01 11:08:40 Hostname systemd-shutdown[1]: Watchdog running with a timeout of 10min.
avril 01 11:08:40 Hostname systemd-shutdown[1]: Syncing filesystems and block devices.
avril 01 11:08:40 Hostname systemd-shutdown[1]: Sending SIGTERM to remaining processes...
avril 01 11:08:40 Hostname systemd-journald[305]: Received SIGTERM from PID 1 (systemd-shutdow).
avril 01 11:08:40 Hostname audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termi>
avril 01 11:08:40 Hostname audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termin>
you posted the log of the previous boot. Not the current one that had the DE (gnome shell) crash
You want me to do a journalctl -b 0?
Reboot, run that command, press page down key or scroll to the bottom of journal, and look at relevant areas where the DE crashed/where it reloaded
and notice this will only help if you actually experienced a crash just before it. Otherwise you need to locate the crash and it’s journal entries using other methods
The problem is that I don’t have any log of the time of the crash.
My system rebooted at 11:13, and as you can see, at this timeframe there is a “skipping…” message. I have logs just before the crash, and after the system rebooted.
avril 01 11:09:04 Hostname /usr/lib/gdm-x-session[761]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event18)
avril 01 11:09:04 Hostname /usr/lib/gdm-x-session[761]: (II) No input driver specified, ignoring this device.
avril 01 11:09:04 Hostname /usr/lib/gdm-x-session[761]: (II) This device may have been added with another device file.
avril 01 11:09:04 Hostname /usr/lib/gdm-x-session[761]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event19)
avril 01 11:09:04 Hostname /usr/lib/gdm-x-session[761]: (II) config/udev: Adding input device Intel HID events (/dev/input/event8)
avril 01 11:09:04 Hostname /usr/lib/gdm-x-session[761]: () Intel HID events: Applying InputClass “evdev keyboard catchall”
avril 01 11:09:04 Hostname /usr/lib/gdm-x-session[761]: () Intel HID events: Applying InputClass “libinput keyboard catchall”
avril 01 11:09:04 Hostname /usr/lib/gdm-x-session[761]: (**) Intel HID events: Applying InputClass “system-keyboard”
…skipping…
avril 01 11:16:48 Hostname gnome-shell[4296]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 11:16:48 Hostname gnome-shell[4296]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 11:16:48 Hostname gnome-shell[4296]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
avril 01 11:16:53 Hostname touchegg.desktop[4609]: Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 11:16:53 Hostname touchegg.desktop[4609]: Reconnecting in 5 seconds…
avril 01 11:16:53 Hostname gnome-shell[4296]: [x11gestures@joseexposito.github.io] Connecting to Touchégg daemon
avril 01 11:16:53 Hostname gnome-shell[4296]: [x11gestures@joseexposito.github.io] Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 11:16:53 Hostname gnome-shell[4296]: [x11gestures@joseexposito.github.io] Reconnecting to Touchégg daemon in 5 seconds
avril 01 11:16:58 Hostname touchegg.desktop[4609]: Error connecting to Touchégg daemon: Could not connect: Connection refused
avril 01 11:16:58 Hostname touchegg.desktop[4609]: Reconnecting in 5 seconds…
no, that means you have skipped in scrolling the journal.
please, take a moment to understand how arrow keys, page up/down and even home/end keys allow you to navigate it. In my previous message i perhaps should have said to use the end key to get to bottom of journal, and then start scrolling up with arrow up key to find the place where the crash happened.
Sorry, I’m not used to ask for help here…
Thank you for your patience and for helping me.
avril 01 11:13:44 Hostname kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 9:1:85dffffb, in Xorg [1231]
=> I think that’s the first freeze. After this, I have many Touchégg errors, I delete them for my logs to be more readable.
avril 01 11:14:09 Hostname kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 9:1:85dffffb, in Xorg [1231]
=> Second freeze.
avril 01 11:14:34 Hostname kernel: i915 0000:00:02.0: [drm] Resetting rcs0 for preemption time out
=> Crash and restart of the session.
I’m trying to push the rest of the log.
avril 01 11:14:34 Hostname kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 9:1:85dffffb, in Xorg [1231]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE)
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) Backtrace:
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 0: /usr/lib/Xorg (dri3_send_open_reply+0xdd) [0x5562c908fa1d]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 1: /usr/lib/libc.so.6 (__sigaction+0x50) [0x7fe4c2c4ff50]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 2: /usr/lib/libc.so.6 (pthread_key_delete+0x14c) [0x7fe4c2c9e8ec]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 3: /usr/lib/libc.so.6 (gsignal+0x18) [0x7fe4c2c4fea8]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 4: /usr/lib/libc.so.6 (abort+0xd7) [0x7fe4c2c3953d]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) unw_get_proc_name failed: no unwind info found [-10]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 5: /usr/lib/dri/iris_dri.so (?+0x0) [0x7fe4bf491e8e]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 6: /usr/lib/dri/iris_dri.so (nouveau_drm_screen_create+0x457097) [0x7fe4c0169f27]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 7: /usr/lib/dri/iris_dri.so (__driDriverGetExtensions_d3d12+0x1e7416) [0x7fe4bf6a39d6]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 8: /usr/lib/Xorg (present_register_complete_notify+0x42a6) [0x5562c90140a6]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 9: /usr/lib/xorg/modules/drivers/modesetting_drv.so (?+0x0) [0x7fe4c321e223]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 10: /usr/lib/xorg/modules/drivers/modesetting_drv.so (?+0x0) [0x7fe4c3220cd0]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 11: /usr/lib/libdrm.so.2 (drmHandleEvent+0x9d) [0x7fe4c2e3e94d]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 12: /usr/lib/Xorg (UnlockServer+0x282) [0x5562c9087902]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 13: /usr/lib/Xorg (WaitForSomething+0x1c9) [0x5562c9082f09]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 14: /usr/lib/Xorg (SProcXkbDispatch+0x1c93) [0x5562c8f723af]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 15: /usr/lib/libc.so.6 (__libc_init_first+0x90) [0x7fe4c2c3a790]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 16: /usr/lib/libc.so.6 (__libc_start_main+0x8a) [0x7fe4c2c3a84a]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) 17: /usr/lib/Xorg (_start+0x25) [0x5562c8f732f5]
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: Fatal server error:
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) Caught signal 6 (Aborted). Server aborting
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: Please consult the The X.Org Foundation support
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: at http://wiki.x.org
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: for help.
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (II) AIGLX: Suspending AIGLX clients for VT switch
avril 01 11:14:34 Hostname /usr/lib/gdm-x-session[1231]: (EE) Server terminated with error (1). Closing log file.
avril 01 11:14:34 Hostname audit[1231]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj=unconfined pid=1231 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
avril 01 11:14:34 Hostname kernel: audit: type=1701 audit(1680340474.310:195): auid=1000 uid=1000 gid=1000 ses=3 subj=unconfined pid=1231 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
avril 01 11:14:34 Hostname systemd[1]: Created slice Slice /system/systemd-coredump.
avril 01 11:14:34 Hostname audit: BPF prog-id=46 op=LOAD
avril 01 11:14:34 Hostname audit: BPF prog-id=47 op=LOAD
avril 01 11:14:34 Hostname audit: BPF prog-id=48 op=LOAD
avril 01 11:14:34 Hostname kernel: audit: type=1334 audit(1680340474.320:196): prog-id=46 op=LOAD
avril 01 11:14:34 Hostname kernel: audit: type=1334 audit(1680340474.320:197): prog-id=47 op=LOAD
avril 01 11:14:34 Hostname kernel: audit: type=1334 audit(1680340474.320:198): prog-id=48 op=LOAD
avril 01 11:14:34 Hostname systemd[1]: Started Process Core Dump (PID 3582/UID 0).
avril 01 11:14:34 Hostname audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-coredump@0-3582-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? a>
avril 01 11:14:34 Hostname kernel: audit: type=1130 audit(1680340474.344:199): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-coredump@0-3582-0 comm="systemd" exe="/usr/lib/s>
avril 01 11:14:35 Hostname systemd-coredump[3584]: [🡕] Process 1231 (Xorg) of user 1000 dumped core.
Stack trace of thread 1231:
#0 0x00007fe4c2c9e8ec n/a (libc.so.6 + 0x878ec)
#1 0x00007fe4c2c4fea8 raise (libc.so.6 + 0x38ea8)
#2 0x00007fe4c2c3953d abort (libc.so.6 + 0x2253d)
#3 0x00005562c9087cb0 OsAbort (Xorg + 0x153cb0)
#4 0x00005562c9089113 FatalError (Xorg + 0x155113)
#5 0x00005562c908fa79 n/a (Xorg + 0x15ba79)
#6 0x00007fe4c2c4ff50 n/a (libc.so.6 + 0x38f50)
#7 0x00007fe4c2c9e8ec n/a (libc.so.6 + 0x878ec)
#8 0x00007fe4c2c4fea8 raise (libc.so.6 + 0x38ea8)
#9 0x00007fe4c2c3953d abort (libc.so.6 + 0x2253d)
#10 0x00007fe4bf491e8e n/a (iris_dri.so + 0x91e8e)
#11 0x00007fe4c0169f27 n/a (iris_dri.so + 0xd69f27)
#12 0x00007fe4bf6a39d6 n/a (iris_dri.so + 0x2a39d6)
#13 0x00005562c90140a6 n/a (Xorg + 0xe00a6)
#14 0x00007fe4c321e223 n/a (modesetting_drv.so + 0x13223)
#15 0x00007fe4c3220cd0 n/a (modesetting_drv.so + 0x15cd0)
you should not have touchegg errors if you disabled it using the command i gave you.
But aside from that, you probably found the cause of the crash, your graphics drivers don’t play nice with libre office. Now only thing left is to google/find out the exact error and if there is any fix available.
it seems you have integrated intel graphics, and why it crashes with libre office is weird as it is a very common setup.
Yeah, that’s why I’m struggling finding a way to fix this issue.
You could try taking the logs upstream, or wait for someone with actual skills in this are to find this thread and help you. But i am all out of ideas.
At least now there is enough info from you to have a starting point to troubleshooting.
Your OneDrive Client is also non operational as you have missing libraries.
You will need to rebuild and/or reinstall your OneDrive client to fix this error. Please review onedrive/INSTALL.md at master · abraunegg/onedrive · GitHub to do so.
