I have acer nitro5 and i have windows 10 on ssd and i installed manjaro on hdd.
the problem when i restart my laptop it boots to windows or i have to press F12 and chose and sometimes it doesnt work, add to that manjaro takes long time.
i tried to use esayBCD to havr the menu to chose the system but it doesnt work due to the UEFI mode.
i just need to know how to make manjaro is the defult system and stop booting into windows.
sorry for my english
Hi @sulaiman, and welcome!
I’ve never done it myself, but according to this post, it’s quite easy:
Setting the default booting entry in grub
The quick method: download the grub-select.bash and run
$ bash grub-select.bash
and choose the boot entry.
Following is the manual way.
In grub (before version 2, actually it is usually version 0.99), the default entry is stored in
/boot/grub/grub.conf
. The default entry to boot is specified by the ‘default’ variable such >asdefault=2
The ‘2’ here is to set the default entry to be the 2nd (start from 0) one.
Update on Apr. 29, 2015: updated posts with support to both BIOS and UEFI based Linux systems; suggest the
grub2-regen-cfg.bash
script for re-generating grub2 config file.
Hope it helps!
