I’ve been having a long running issue with Manjaro on my desktop where it will lock up at random times. The screen freezes, the mouse becomes unresponsive, and if any audio was playing, it will begin looping the last few moments nonstop. The only way I’ve been able to deal with it was to do a hard reset via the hardware reset button. I’ve been unable to find any way to reproduce this freeze. It can happen at any moment. Sometimes, it will freeze several times back-to-back after each reset and sometimes it might work perfectly fine for several days.
Things I’ve tried(and reverted) over time:
- Different kernels (tried 5.4 - 5.10)
- Kernel boot options such as
max_cstate=5
,rcu_nocbs=0-11
,idle=nowait
, etc. - zenstates.py
- nohang
- Updating BIOS
- Clearing CMOS
- Turning off XMP profile and having my RAM run at 2133 instead of 3200.
- Disabling c-state control in BIOS
- Changing BIOS power idle settings (Auto => Typical Current Idle)
- Tests overnight on windows 10 drive (Prime95 and memtest86 returning no errors)
- Using different RAM even though there were no errors found
- Clean reinstall of Manjaro
I’d appreciate any ideas I may not have tried short of replacing every component in my PC piece-by-piece. I really like using Manjaro, but the issue has been incredibly frustrating. Even if it’s a hardware error, I’d love to just be able to figure out which component it is.
System Information
inxi -Fxzc0
System: Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: KDE Plasma 5.20.5 Distro: Manjaro Linux
Machine: Type: Desktop System: Gigabyte product: X570 I AORUS PRO WIFI v: -CF serial: <filter>
Mobo: Gigabyte model: X570 I AORUS PRO WIFI v: x.x serial: <filter>
UEFI: American Megatrends v: F32 date: 01/18/2021
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 rev: 0
L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86277
Speed: 3406 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3406
2: 2091 3: 3748 4: 2068 5: 2143 6: 2069 7: 4047 8: 2067 9: 3084 10: 2085 11: 2185
12: 2063
Graphics: Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 0b:00.0
Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon RX 5700 (NAVI10 DRM 3.40.0 5.10.15-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 0b:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 0d:00.4
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-2:2
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus ID: 5-4:4
Sound Server: ALSA v: k5.10.15-1-MANJARO
Network: Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel port: f000
bus ID: 04:00.0
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000 bus ID: 05:00.0
IF: wlp5s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-2:3
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 1.84 TiB used: 39.43 GiB (2.1%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB temp: 42.9 C
ID-2: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
Partition: ID-1: / size: 937.6 GiB used: 39.43 GiB (4.2%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 51.4 C mobo: 16.8 C gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 330 Uptime: 9m Memory: 15.64 GiB used: 3.8 GiB (24.3%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1342 Client: KDE Plasma v: 5.20.5 inxi: 3.3.01
Logs
journalctl -b -1 -p4
of most recent crash
-- Journal begins at Tue 2021-02-09 14:14:56 EST, ends at Fri 2021-02-12 12:49:42 EST. --
Feb 12 02:17:19 amos kernel: PPR X2APIC NX GT IA GA PC GA_vAPIC
Feb 12 02:17:19 amos kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Feb 12 02:17:19 amos kernel: ACPI: Invalid passive threshold
Feb 12 02:17:19 amos kernel: ata2.00: supports DRM functions and may not be fully accessible
Feb 12 02:17:19 amos kernel: usb: port power management may be unreliable
Feb 12 02:17:19 amos kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Feb 12 02:17:19 amos kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20200925/utaddress-204)
Feb 12 02:17:19 amos kernel: iwlwifi 0000:05:00.0: api flags index 2 larger than supported by driver
Feb 12 02:17:19 amos kernel: kvm: disabled by bios
Feb 12 02:17:20 amos kernel: kvm: disabled by bios
Feb 12 02:17:20 amos kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Feb 12 02:17:20 amos NetworkManager[517]: <warn> [1613114240.7961] sup-iface[7fb270ffe4bda26d,0,wlp5s0]: call-p2p-cancel: failed with P2P cancel failed
Feb 12 02:17:20 amos kernel: usb 3-2: Warning! Unlikely big volume range (=496), cval->res is probably wrong.
Feb 12 02:17:20 amos kernel: usb 3-2: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
Feb 12 02:17:21 amos kernel: kvm: disabled by bios
Feb 12 02:17:21 amos kernel: amdgpu 0000:0b:00.0: amdgpu: SMU driver if version not matched
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanType” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanInterval” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanWindow” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanType” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanInterval” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanWindow” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRLinkSupervisionTimeout” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRPageTimeout” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRMinSniffInterval” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “BRMaxSniffInterval” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEMinAdvertisementInterval” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEMaxAdvertisementInterval” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEMultiAdvertisementRotationInterval” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAutoConnect” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAutoConnect” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalSuspend” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowSuspend” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalDiscovery” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowDiscovery” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAdvMonitor” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAdvMonitor” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
Feb 12 02:17:21 amos bluetoothd[1101]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
Feb 12 02:17:21 amos kernel: kauditd_printk_skb: 52 callbacks suppressed
Feb 12 02:17:22 amos systemd-xdg-autostart-generator[1196]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 12 02:17:22 amos systemd-xdg-autostart-generator[1196]: Configuration file /etc/xdg/autostart/klipper.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 12 02:17:22 amos systemd[1190]: -.slice: Failed to migrate controller cgroups from /user.slice/user-966.slice/user@966.service, ignoring: Permission denied
Feb 12 02:17:22 amos sddm-greeter[1199]: QFont::fromString: Invalid description '(empty)'
Feb 12 02:17:22 amos sddm-greeter[1199]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffca6f895b0), parent's thread is QThread(0x557be5980e30), current thread is QThread(0x557be5b23bb0)
Feb 12 02:17:22 amos sddm-greeter[1199]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Feb 12 02:17:23 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/Main.qml:408:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:406:376: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:407:130: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:408:130: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:408:393: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:409:130: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:410:129: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:411:129: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:412:129: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:413:129: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:413:379: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: <input>:413:631: Could not add child element to parent element because the types are incorrect.
Feb 12 02:17:23 amos sddm-greeter[1199]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Feb 12 02:17:23 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/VirtualKeyboard.qml:22:1: Type InputPanel unavailable
Feb 12 02:17:23 amos sddm-greeter[1199]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Feb 12 02:17:23 amos sddm-greeter[1199]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Feb 12 02:17:23 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/Login.qml:84:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Feb 12 02:17:23 amos sddm-greeter[1199]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Feb 12 02:17:23 amos sddm-greeter[1199]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
Feb 12 02:17:30 amos kernel: kauditd_printk_skb: 9 callbacks suppressed
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/Main.qml:377: TypeError: Cannot read property 'smallSpacing' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/Battery.qml:27: TypeError: Cannot read property 'smallSpacing' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:55: TypeError: Cannot read property 'smallSpacing' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:34: TypeError: Cannot read property 'gridUnit' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:36: TypeError: Cannot read property 'largeSpacing' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:37: TypeError: Cannot read property 'smallSpacing' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:82: TypeError: Cannot read property 'gridUnit' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:111: TypeError: Cannot read property 'smallSpacing' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:97: TypeError: Cannot read property 'gridUnit' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:98: TypeError: Cannot read property 'gridUnit' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:88: TypeError: Cannot read property 'gridUnit' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/UserList.qml:25: TypeError: Cannot read property 'gridUnit' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/UserList.qml:26: TypeError: Cannot read property 'gridUnit' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:38: TypeError: Cannot read property 'iconSizes' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:101: TypeError: Cannot read property 'iconSizes' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:36: TypeError: Cannot read property 'smallSpacing' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ButtonStyle.qml:83: TypeError: Cannot read property 'iconSizes' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ButtonStyle.qml:28: TypeError: Cannot read property 'smallSpacing' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/TextFieldStyle.qml:77: TypeError: Cannot read property 'iconSizes' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/UserDelegate.qml:39: TypeError: Cannot read property 'largeSpacing' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/UserDelegate.qml:70: TypeError: Cannot read property 'gridUnit' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/UserDelegate.qml:45: TypeError: Cannot read property 'longDuration' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/private/TextFieldFocus.qml:80: TypeError: Cannot read property 'longDuration' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/WallpaperFader.qml:159: TypeError: Cannot read property 'longDuration' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/components/WallpaperFader.qml:153: TypeError: Cannot read property 'longDuration' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/private/ButtonShadow.qml:117: TypeError: Cannot read property 'longDuration' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/Main.qml:226: TypeError: Cannot read property 'longDuration' of null
Feb 12 07:18:42 amos sddm-greeter[1199]: file:///usr/share/sddm/themes/breath2/Main.qml:382: TypeError: Cannot read property 'longDuration' of null
Feb 12 07:18:42 amos systemd-xdg-autostart-generator[1328]: Configuration file /home/amos/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 12 07:18:42 amos systemd-xdg-autostart-generator[1328]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 12 07:18:42 amos systemd-xdg-autostart-generator[1328]: Configuration file /etc/xdg/autostart/klipper.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 12 07:18:42 amos systemd[1322]: -.slice: Failed to migrate controller cgroups from /user.slice/user-1000.slice/user@1000.service, ignoring: Permission denied
Feb 12 07:18:43 amos klauncher[1363]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Feb 12 07:18:43 amos kcminit_startup[1389]: QDBusConnection: error: could not send signal to service "" path "//home/amos/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/amos/.kde4/share/config/kdeglobals
Feb 12 07:18:43 amos kded5[1401]: org.kde.wacomtablet.common: d->name.isEmpty? true
Feb 12 07:18:43 amos ksmserver[1455]: Qt: Session management error: networkIdsList argument is NULL
Feb 12 07:18:43 amos kded5[1401]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
Feb 12 07:18:43 amos kwin_x11[1405]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Feb 12 07:18:43 amos kwin_x11[1405]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Feb 12 07:18:43 amos kwin_x11[1405]: kf.config.core: "\"fsrestore3\" - conversion of \"961,961,0,0\" to QRect failed"
Feb 12 07:18:43 amos kwin_x11[1405]: kf.config.core: "\"fsrestore4\" - conversion of \"0,0,0,0\" to QRect failed"
Feb 12 07:18:43 amos kwin_x11[1405]: kf.config.core: "\"fsrestore5\" - conversion of \"0,0,0,0\" to QRect failed"
Feb 12 07:18:43 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 944, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:18:43 amos kded5[1401]: kscreen.kded: PowerDevil SuspendSession action not available!
Feb 12 07:18:43 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1069, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:18:44 amos plasmashell[1482]: Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
Feb 12 07:18:44 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1484, resource id: 54525957, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
Feb 12 07:18:44 amos plasmashell[1482]: trying to show an empty dialog
Feb 12 07:18:44 amos plasmashell[1482]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/home/amos/.local/share/wallpapers" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Autumn" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Breath2" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/BytheWater" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Canopee" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Cascade" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Cluster" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/ColdRipple" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/ColorfulCups" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/DarkestHour" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Elarun" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/EveningGlow" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/FallenLeaf" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Flow" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/FlyingKonqui" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Grey" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/IceCold" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Kite" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Kokkini" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Next" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/OneStandsOut" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Opal" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/PastelHills" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Path" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/SafeLanding" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/summer_1am" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Volna" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/manjaro-wallpapers-18.0" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/wallpapers-2018" is a directory. Use addDir!
Feb 12 07:18:44 amos plasmashell[1482]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/wallpapers-juhraya" is a directory. Use addDir!
Feb 12 07:18:44 amos org_kde_powerdevil[1706]: org.kde.powerdevil: No outputs have backlight property
Feb 12 07:18:44 amos org_kde_powerdevil[1706]: org.kde.powerdevil: Xrandr not supported, trying ddc, helper
Feb 12 07:18:44 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2582, resource id: 4194363, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:18:44 amos backlighthelper[1768]: org.kde.powerdevil: no kernel backlight interface found
Feb 12 07:18:44 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2602, resource id: 65011717, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:18:44 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2606, resource id: 71303173, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:18:44 amos org_kde_powerdevil[1706]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Feb 12 07:18:44 amos org_kde_powerdevil[1706]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Feb 12 07:18:44 amos org_kde_powerdevil[1706]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Feb 12 07:18:44 amos org_kde_powerdevil[1706]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Feb 12 07:18:44 amos plasmashell[1482]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Feb 12 07:18:44 amos plasmashell[1482]: Both point size and pixel size set. Using pixel size.
Feb 12 07:18:44 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:302:13: QML PropertyChanges: Cannot assign to non-existent property "font.minimumPixelSize"
Feb 12 07:18:44 amos kate[1683]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so: (libaspell.so.15: cannot open shared object file: No such file or directory)"
Feb 12 07:18:44 amos kate[1683]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0: cannot open shared object file: No such file or directory)"
Feb 12 07:18:44 amos kate[1683]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1: cannot open shared object file: No such file or directory)"
Feb 12 07:18:44 amos kate[1683]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Feb 12 07:18:44 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumHeight"
Feb 12 07:18:45 amos plasmashell[1482]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Feb 12 07:18:45 amos plasmashell[1482]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:56:5: Unable to assign [undefined] to int
Feb 12 07:18:45 amos kdeinit5[1877]: Qt: Session management error: networkIdsList argument is NULL
Feb 12 07:18:45 amos plasmashell[1482]: KAStatsFavoritesModel::setFavorites is ignored
Feb 12 07:18:45 amos plasmashell[1482]: Entry is not valid "kde4-digikam.desktop" QSharedPointer(0x55709c5054e0)
Feb 12 07:18:45 amos plasmashell[1482]: Entry is not valid "pamac-manager.desktop" QSharedPointer(0x55709c505760)
Feb 12 07:18:45 amos plasmashell[1482]: Entry is not valid "pamac-updater.desktop" QSharedPointer(0x55709c5054e0)
Feb 12 07:18:45 amos plasmashell[1482]: Entry is not valid "kde4-digikam.desktop" QSharedPointer(0x55709cc99f70)
Feb 12 07:18:45 amos plasmashell[1482]: Entry is not valid "pamac-updater.desktop" QSharedPointer(0x55709cc99f70)
Feb 12 07:18:45 amos plasmashell[1482]: trying to show an empty dialog
Feb 12 07:18:45 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4803, resource id: 4194309, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:18:49 amos kwin_x11[1405]: file:///usr/share/kwin/outline/plasma/outline.qml:46:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Feb 12 07:18:50 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Feb 12 07:18:50 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13230, resource id: 35651756, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:18:50 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:379: Unable to assign [undefined] to QString
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13893, resource id: 35651736, major code: 19 (DeleteProperty), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13896, resource id: 35651736, major code: 19 (DeleteProperty), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13897, resource id: 35651736, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13898, resource id: 35651736, major code: 19 (DeleteProperty), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13899, resource id: 35651736, major code: 19 (DeleteProperty), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13900, resource id: 35651736, major code: 19 (DeleteProperty), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13901, resource id: 35651736, major code: 7 (ReparentWindow), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13902, resource id: 35651736, major code: 6 (ChangeSaveSet), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13903, resource id: 35651736, major code: 2 (ChangeWindowAttributes), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13904, resource id: 35651736, major code: 10 (UnmapWindow), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14776, resource id: 14681452, major code: 3 (GetWindowAttributes), minor code: 0
Feb 12 07:18:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 14777, resource id: 14681452, major code: 14 (GetGeometry), minor code: 0
Feb 12 07:18:51 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Feb 12 07:18:53 amos kernel: kauditd_printk_skb: 6 callbacks suppressed
Feb 12 07:18:53 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
Feb 12 07:19:04 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Feb 12 07:19:04 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28926, resource id: 35651789, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:19:04 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:379: Unable to assign [undefined] to QString
Feb 12 07:19:04 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29217, resource id: 35651791, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:19:05 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 07:19:05 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the xesam:url entry of the "Metadata" property
Feb 12 07:19:05 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:69:5: Unable to assign QStringList to QString
Feb 12 07:19:05 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31208, resource id: 14683024, major code: 3 (GetWindowAttributes), minor code: 0
Feb 12 07:19:05 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02316a0de31116905aefed853e: Unsupported image format
Feb 12 07:19:05 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02316a0de31116905aefed853e: Unsupported image format
Feb 12 07:19:06 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33819, resource id: 94371841, major code: 15 (QueryTree), minor code: 0
Feb 12 07:19:35 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57365, resource id: 113246213, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:19:35 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57374, resource id: 113246213, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:23:15 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7327, resource id: 65011723, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:23:57 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02316a0de31116905aefed853e: Unsupported image format
Feb 12 07:28:50 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02316a0de31116905aefed853e: Unsupported image format
Feb 12 07:28:50 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02316a0de31116905aefed853e: Unsupported image format
Feb 12 07:29:03 amos pulseaudio[1531]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Feb 12 07:29:03 amos pulseaudio[1531]: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Feb 12 07:29:03 amos pulseaudio[1531]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Feb 12 07:34:52 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0294e30102e8f706fce7d67355: Unsupported image format
Feb 12 07:34:52 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0294e30102e8f706fce7d67355: Unsupported image format
Feb 12 07:34:57 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0282cc5fddb8df9f3c89a85cfd: Unsupported image format
Feb 12 07:34:57 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0282cc5fddb8df9f3c89a85cfd: Unsupported image format
Feb 12 07:36:34 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0282cc5fddb8df9f3c89a85cfd: Unsupported image format
Feb 12 07:36:34 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0282cc5fddb8df9f3c89a85cfd: Unsupported image format
Feb 12 07:38:11 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22905, resource id: 35651861, major code: 15 (QueryTree), minor code: 0
Feb 12 07:38:21 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0260e99c09e312cf4181a2c8b8: Unsupported image format
Feb 12 07:38:21 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0260e99c09e312cf4181a2c8b8: Unsupported image format
Feb 12 07:40:39 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 07:41:09 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 07:41:40 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 07:42:45 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e024f5d03bf896adc807260f1a1: Unsupported image format
Feb 12 07:42:45 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e024f5d03bf896adc807260f1a1: Unsupported image format
Feb 12 07:48:58 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12702, resource id: 35651955, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:48:58 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Feb 12 07:48:58 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13334, resource id: 14774408, major code: 3 (GetWindowAttributes), minor code: 0
Feb 12 07:48:58 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 13335, resource id: 14774408, major code: 14 (GetGeometry), minor code: 0
Feb 12 07:49:18 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26630, resource id: 65011719, major code: 15 (QueryTree), minor code: 0
Feb 12 07:49:18 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26787, resource id: 35651957, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:49:23 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30183, resource id: 35651959, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:49:24 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30688, resource id: 14775758, major code: 3 (GetWindowAttributes), minor code: 0
Feb 12 07:49:24 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 30689, resource id: 14775758, major code: 14 (GetGeometry), minor code: 0
Feb 12 07:49:24 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Feb 12 07:49:25 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02e1ef204f863ad3cb8f2ee83c: Unsupported image format
Feb 12 07:49:25 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02e1ef204f863ad3cb8f2ee83c: Unsupported image format
Feb 12 07:49:34 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40807, resource id: 65011739, major code: 2 (ChangeWindowAttributes), minor code: 0
Feb 12 07:49:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54043, resource id: 65011719, major code: 15 (QueryTree), minor code: 0
Feb 12 07:49:51 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54204, resource id: 35652015, major code: 18 (ChangeProperty), minor code: 0
Feb 12 07:52:16 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61331, resource id: 35652016, major code: 15 (QueryTree), minor code: 0
Feb 12 07:55:22 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 07:55:52 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 07:55:53 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 07:56:23 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 07:56:24 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 07:56:59 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2091, resource id: 35652036, major code: 15 (QueryTree), minor code: 0
Feb 12 08:08:12 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11310, resource id: 73401067, major code: 15 (QueryTree), minor code: 0
Feb 12 08:08:34 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 08:09:05 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 08:09:35 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 08:21:29 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 08:21:59 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 08:22:30 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 08:22:34 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5538, resource id: 102760449, major code: 15 (QueryTree), minor code: 0
Feb 12 08:22:34 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5643, resource id: 35652141, major code: 18 (ChangeProperty), minor code: 0
Feb 12 08:22:34 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Feb 12 08:22:34 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6319, resource id: 35652143, major code: 18 (ChangeProperty), minor code: 0
Feb 12 08:22:34 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:379: Unable to assign [undefined] to QString
Feb 12 08:22:35 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:379: Unable to assign [undefined] to QString
Feb 12 08:22:35 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 08:22:35 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the xesam:url entry of the "Metadata" property
Feb 12 08:22:35 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:69:5: Unable to assign QStringList to QString
Feb 12 08:22:35 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0294e30102e8f706fce7d67355: Unsupported image format
Feb 12 08:22:35 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e0294e30102e8f706fce7d67355: Unsupported image format
Feb 12 08:23:05 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32876, resource id: 77594629, major code: 18 (ChangeProperty), minor code: 0
Feb 12 08:23:05 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32923, resource id: 77594629, major code: 18 (ChangeProperty), minor code: 0
Feb 12 08:24:53 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e022e4f699fcb5aa169fa04c972: Unsupported image format
Feb 12 08:24:53 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e022e4f699fcb5aa169fa04c972: Unsupported image format
Feb 12 08:27:45 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02cfb78f479c145a7e781bfd91: Unsupported image format
Feb 12 08:27:45 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02cfb78f479c145a7e781bfd91: Unsupported image format
Feb 12 08:30:16 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 08:30:16 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 08:39:59 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 08:39:59 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 08:46:29 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 08:46:29 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 08:53:22 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 08:53:22 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 08:55:35 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 08:55:35 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 09:02:27 amos kdeconnectd[1519]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Feb 12 09:02:27 amos kdeconnectd[1519]: kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
Feb 12 09:02:27 amos kdeconnectd[1519]: kdeconnect.plugin.battery: Total quantity of batteries found: 0
Feb 12 09:02:27 amos kdeconnectd[1519]: QMetaObject::invokeMethod: No such method KIO::StoredTransferJob::slotDataReqFromDevice()
Feb 12 09:02:28 amos kdeconnectd[1519]: QMetaObject::invokeMethod: No such method KIO::StoredTransferJob::slotDataReqFromDevice()
Feb 12 09:02:28 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:59:9: QML QQuickTextEdit: Binding loop detected for property "width"
Feb 12 09:22:58 amos kdeconnectd[1519]: QMetaObject::invokeMethod: No such method KIO::StoredTransferJob::slotDataReqFromDevice()
Feb 12 09:36:32 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 64957, resource id: 117440517, major code: 18 (ChangeProperty), minor code: 0
Feb 12 09:36:33 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 64965, resource id: 117440517, major code: 18 (ChangeProperty), minor code: 0
Feb 12 09:39:23 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 09:39:23 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 09:39:27 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12051, resource id: 113246209, major code: 15 (QueryTree), minor code: 0
Feb 12 09:39:30 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 09:39:30 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02b2387351e6eadb0ace900f36: Unsupported image format
Feb 12 09:39:34 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e025df1dea262a8f177f140258d: Unsupported image format
Feb 12 09:39:34 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e025df1dea262a8f177f140258d: Unsupported image format
Feb 12 09:39:35 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e024f46967f868bf5277aa91e7b: Unsupported image format
Feb 12 09:39:35 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e024f46967f868bf5277aa91e7b: Unsupported image format
Feb 12 09:39:39 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e020c5cb9c1a8f1d9391d263b0d: Unsupported image format
Feb 12 09:39:39 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e020c5cb9c1a8f1d9391d263b0d: Unsupported image format
Feb 12 09:39:42 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02d119124ddb597a652024f646: Unsupported image format
Feb 12 09:39:42 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02d119124ddb597a652024f646: Unsupported image format
Feb 12 09:39:43 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02cb7c37260f13b17fd9e83bca: Unsupported image format
Feb 12 09:39:43 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02cb7c37260f13b17fd9e83bca: Unsupported image format
Feb 12 09:40:33 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02a745cd586eb362b639d76435: Unsupported image format
Feb 12 09:40:33 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02a745cd586eb362b639d76435: Unsupported image format
Feb 12 09:42:36 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 09:42:37 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 09:43:00 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 09:43:02 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 293, resource id: 92274689, major code: 15 (QueryTree), minor code: 0
Feb 12 09:43:02 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 440, resource id: 35652384, major code: 18 (ChangeProperty), minor code: 0
Feb 12 09:43:03 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Feb 12 09:43:03 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1127, resource id: 35652386, major code: 18 (ChangeProperty), minor code: 0
Feb 12 09:43:03 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:379: Unable to assign [undefined] to QString
Feb 12 09:43:03 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 09:43:03 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the xesam:url entry of the "Metadata" property
Feb 12 09:43:03 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:69:5: Unable to assign QStringList to QString
Feb 12 09:43:03 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02440d945636b7c8672ba93600: Unsupported image format
Feb 12 09:43:03 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02440d945636b7c8672ba93600: Unsupported image format
Feb 12 09:43:26 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
Feb 12 09:43:34 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25152, resource id: 104857605, major code: 18 (ChangeProperty), minor code: 0
Feb 12 09:43:34 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25162, resource id: 104857605, major code: 18 (ChangeProperty), minor code: 0
Feb 12 09:48:20 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02eea81b9f1bf4cd0755c32b6f: Unsupported image format
Feb 12 09:48:20 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02eea81b9f1bf4cd0755c32b6f: Unsupported image format
Feb 12 09:48:39 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02d5b5668efa693a7c5a7c656f: Unsupported image format
Feb 12 09:48:39 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02d5b5668efa693a7c5a7c656f: Unsupported image format
Feb 12 09:48:43 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26773, resource id: 35652601, major code: 15 (QueryTree), minor code: 0
Feb 12 09:51:10 amos plasmashell[1482]: org.kde.plasma.notifications: Trying to replace notification with id 1641 which doesn't exist, creating a new one. This is an application bug!
Feb 12 09:51:54 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4733, resource id: 104857605, major code: 18 (ChangeProperty), minor code: 0
Feb 12 09:51:54 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4738, resource id: 104857606, major code: 18 (ChangeProperty), minor code: 0
Feb 12 09:51:54 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4744, resource id: 104857607, major code: 18 (ChangeProperty), minor code: 0
Feb 12 09:52:42 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02d5b5668efa693a7c5a7c656f: Unsupported image format
Feb 12 09:52:42 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02d5b5668efa693a7c5a7c656f: Unsupported image format
Feb 12 09:57:02 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02f9469a76f74d4a32ab55b9c3: Unsupported image format
Feb 12 09:57:02 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02f9469a76f74d4a32ab55b9c3: Unsupported image format
Feb 12 09:59:35 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 10:00:05 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 10:01:19 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02cec95ecc36b59b77ca9d1558: Unsupported image format
Feb 12 10:01:19 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02cec95ecc36b59b77ca9d1558: Unsupported image format
Feb 12 10:01:24 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
Feb 12 10:04:22 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17009, resource id: 35652706, major code: 15 (QueryTree), minor code: 0
Feb 12 10:06:25 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02ae0a2dce1e0ae9fde32c4671: Unsupported image format
Feb 12 10:06:25 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02ae0a2dce1e0ae9fde32c4671: Unsupported image format
Feb 12 10:11:16 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 10:11:46 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 10:12:17 amos plasmashell[1482]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.spotify" has an invalid URL for the mpris:artUrl entry of the "Metadata" property
Feb 12 10:12:52 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22469, resource id: 35652736, major code: 15 (QueryTree), minor code: 0
Feb 12 10:12:56 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02c62aa44990518f4271a30f09: Unsupported image format
Feb 12 10:12:56 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02c62aa44990518f4271a30f09: Unsupported image format
Feb 12 10:13:16 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48234, resource id: 35652781, major code: 15 (QueryTree), minor code: 0
Feb 12 10:25:09 amos kdeconnectd[1519]: QMetaObject::invokeMethod: No such method KIO::StoredTransferJob::slotDataReqFromDevice()
Feb 12 10:30:46 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02890d72e0655a820e8aba7113: Unsupported image format
Feb 12 10:30:46 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02890d72e0655a820e8aba7113: Unsupported image format
Feb 12 10:30:52 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02890d72e0655a820e8aba7113: Unsupported image format
Feb 12 10:30:52 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02890d72e0655a820e8aba7113: Unsupported image format
Feb 12 11:24:42 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02890d72e0655a820e8aba7113: Unsupported image format
Feb 12 11:24:42 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02890d72e0655a820e8aba7113: Unsupported image format
Feb 12 11:45:08 amos kdeconnectd[1519]: QMetaObject::invokeMethod: No such method KIO::StoredTransferJob::slotDataReqFromDevice()
Feb 12 11:52:21 amos kwin_x11[1405]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2422, resource id: 73401754, major code: 15 (QueryTree), minor code: 0
Feb 12 12:17:26 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:209:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02890d72e0655a820e8aba7113: Unsupported image format
Feb 12 12:17:26 amos plasmashell[1482]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:194:9: QML Image: Error decoding: https://open.spotify.com/image/ab67616d00001e02890d72e0655a820e8aba7113: Unsupported image format
