Manjaro problem it take up to 2-3 minutes to get mice and keyboard working
Hi guys
I’m totally inexperienced guy in relation to linux. I 've just installed Manjaro on dual boot with Windows. The problem i noticed is that after Majaro is loaded and i see login screen it takes about 2-3 minutes to get mice and keyboard working. Does anyone knows what can cause this issue
Hi and welcome to the forum :wave:
Please read this thread on how to supply information and edit your first post with the required info so users can have some data to give you the best advice:
One think I can think of to add to your query:
Do the keyboard and mouse work when selecting the OS to boot?
yes at boot stage it works fine. i can make a choice windows or linux. Then when Majaro login screen appears it takes up to 2-3 minutes to get them working (which seems to be weird as At the first boot after installation it worked straight away)
