For
sudo mhwd-kernel -li
the output was that I have Linux 510 and 54
I did the
sudo pacman-mirrors -f3
command, but
sudo pacman -Syyu
just gave me all errors, with the final one being “failed to synchronize all databases”. So, not good
For
I did the
command, but
sudo pacman -Syyu
is there a message lock ?
then
sudo rm /var/lib/pacman/db.lck
sudo pacman -Syyu
what is a message lock?
a message lock : you have tried pacman -Syyu , and stop on errors ,
there is still a lock in this case
you dont have network internet connexion ?
check to confirm
sudo pacman -Syy
I’m still not sure what you mean by “stop on errors”, but sudo pacman -Syy
gives me the same long list of errors as well.
I think that I understand what you mean, actually. The system lost internet connection when it started freezing, which I guess is why pacman won’t work. Should I go back into the ISO usb and try these commands from there with the chroot commands? Because I’m not sure if I will be able to download the correct files with pacman otherwise. (I am able to connect to internet with the ISO booter)
yes return on USB iso manjaro
OK, just a second
OK, I’ve booted back into the ISO. Should I use the chroot
commands as before, but with the pacman -Syyu
command, or something different?
yes , go with chroot
sudo manjaro-chroot -a
pacman -Syyu
[manjaro /]# pacman -Syyu
core 166.0 KiB 2.70 MiB/s 00:00 [#########################################] 100%
extra 1980.8 KiB 21.5 MiB/s 00:00 [#########################################] 100%
community 6.6 MiB 37.8 MiB/s 00:00 [#########################################] 100%
multilib 179.5 KiB 43.8 MiB/s 00:00 [#########################################] 100%
:: Starting full system upgrade…
warning: nerd-fonts-noto-sans-mono: local (2.1.0-1) is newer than community (2.0.0-1)
warning: pulseaudio-ctl: local (1.69-1) is newer than community (1.67-1)
warning: timeshift: local (20.11.1+3+g08d0e59-3) is newer than community (20.11.1.r3.g08d0e59-2)
there is nothing to do
OK, it worked, and this is what was returned
then
pacman -Syyuu
mkinitcpio -P
exit
[manjaro /]# pacman -Syyuu
core 166.0 KiB 2.19 MiB/s 00:00 [#########################################] 100%
extra 1980.8 KiB 18.6 MiB/s 00:00 [#########################################] 100%
community 6.6 MiB 42.1 MiB/s 00:00 [#########################################] 100%
multilib 179.5 KiB 25.0 MiB/s 00:00 [#########################################] 100%
warning: nerd-fonts-noto-sans-mono: downgrading from version 2.1.0-1 to version 2.0.0-1
warning: pulseaudio-ctl: downgrading from version 1.69-1 to version 1.67-1
warning: timeshift: downgrading from version 20.11.1+3+g08d0e59-3 to version 20.11.1.r3.g08d0e59-2
resolving dependencies…
Packages (3) nerd-fonts-noto-sans-mono-2.0.0-1 pulseaudio-ctl-1.67-1 timeshift-20.11.1.r3.g08d0e59-2
Total Download Size: 1.73 MiB
Total Installed Size: 10.20 MiB
Net Upgrade Size: -0.78 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages…
nerd-fonts-noto-sans-mono-2.0.0-1-any 1043.7 KiB 6.98 MiB/s 00:00 [#########################################] 100%
pulseaudio-ctl-1.67-1-any 10.7 KiB 0.00 B/s 00:00 [#########################################] 100%
timeshift-20.11.1.r3.g08d0e59-2-x86_64 718.9 KiB 14.9 MiB/s 00:00 [#########################################] 100%
(3/3) checking keys in keyring [#########################################] 100%
(3/3) checking package integrity [#########################################] 100%
(3/3) loading package files [#########################################] 100%
(3/3) checking for file conflicts [#########################################] 100%
(3/3) checking available disk space [#########################################] 100%
:: Processing package changes…
(1/3) downgrading nerd-fonts-noto-sans-mono [#########################################] 100%
(2/3) downgrading pulseaudio-ctl [#########################################] 100%
(3/3) downgrading timeshift [#########################################] 100%
==> Attempting to enable Cronie services…Running in chroot, ignoring command ‘is-active’
:: Running post-transaction hooks…
(1/6) Arming ConditionNeedsUpdate…
(2/6) Updating fontconfig cache…
(3/6) Updating 32-bit fontconfig cache…
(4/6) Updating icon theme caches…
(5/6) Updating the desktop file MIME type cache…
(6/6) Updating X fontdir indices…
^ Got this for the first command
[manjaro /]# mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: ‘default’
→ -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.30-1-MANJARO
→ Running build hook: [base]
→ Running build hook: [udev]
→ Running build hook: [autodetect]
→ Running build hook: [modconf]
→ Running build hook: [block]
→ Running build hook: [keyboard]
→ Running build hook: [keymap]
→ Running build hook: [filesystems]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: ‘fallback’
→ -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘default’
→ -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.112-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘fallback’
→ -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
And this for the second
then exit
and reboot
The system still freezes after attempting to log in, unfortunately.
so we need more information , and i need to go to bed
so next tomorrow ( or if any one see for next )
to do
boot on USB manjaro
return in chroot , provide
inxi -Fza
journalct l-b -1 -p4
not forget exit
Ok, one moment
[manjaro /]# inxi -Fza
12System: 12Kernel 5.9.16-1-MANJARO x86_64 12bits 64 12compiler gcc 12v 10.2.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2021 quiet systemd.show_status=1 apparmor=1
security=apparmor driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
12Console N/A 12wm kwin_x11 12Distro Manjaro Linux 12base Arch Linux
12Machine: 12Type Laptop 12System Dell 12product G3 3779 12v N/A 12serial 12Chassis 12type 10
12serial
12Mobo Dell 12model 0JGKPC 12v A00 12serial 12UEFI Dell 12v 1.12.0 12date 02/13/2020
12Battery: 12ID-1 BAT0 12charge 26.8 Wh (67.5%) 12condition 39.7/56.0 Wh (71.0%) 12volts 17.1 12min 15.2
12model LGC-LGC3.553 DELL 99NF284 12type Li-ion 12serial 12status Charging
12CPU: 12Info 6-Core 12model Intel Core i7-8750H 12socket BGA1440 (U3E1) 12note check 12bits 64
12type MT MCP 12arch Kaby Lake 12note check 12family 6 12model-id 9E (158) 12stepping A (10)
12microcode DE 12cache 12L1 384 KiB 12L2 9 MiB 12L3 9 MiB
12flags avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx 12bogomips 52815
12Speed 801 MHz 12min/max 800/4100 MHz 12base/boost 3900/4100 12volts 1.0 V 12ext-clock 100 MHz
12Core speeds (MHz) 121 801 122 801 123 800 124 800 125 800 126 800 127 800 128 800 129 800 1210 800 1211 800
1212 800
12Vulnerabilities 12Type itlb_multihit 12status KVM: VMX disabled
12Type l1tf 12mitigation PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
12Type mds 12mitigation Clear CPU buffers; SMT vulnerable
12Type meltdown 12mitigation PTI
12Type spec_store_bypass
12mitigation Speculative Store Bypass disabled via prctl and seccomp
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling
12Type srbds 12mitigation Microcode
12Type tsx_async_abort 12status Not affected
12Graphics: 12Device-1 Intel UHD Graphics 630 12vendor Dell 12driver i915 12v kernel 12bus-ID 00:02.0
12chip-ID 8086:3e9b 12class-ID 0300
12Device-2 NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] 12driver nouveau 12v kernel
12bus-ID 01:00.0 12chip-ID 10de:1c8c 12class-ID 0302
12Device-3 Microdia Integrated_Webcam_HD 12type USB 12driver uvcvideo 12bus-ID 1-5:3
12chip-ID 0c45:6a06 12class-ID 0e02
12Display 12server X.Org 1.20.10 12compositor kwin_x11 12driver 12loaded modesetting,nvidia
12alternate fbdev,intel,nouveau,nv,vesa 12display-ID :0 12screens 1
12Screen-1 0 12s-res 1920x1080 12s-dpi 96 12s-size 508x285mm (20.0x11.2") 12s-diag 582mm (22.9")
12Monitor-1 eDP1 12res 1920x1080 12hz 60 12dpi 128 12size 380x210mm (15.0x8.3")
12diag 434mm (17.1")
12OpenGL 12renderer Mesa Intel UHD Graphics 630 (CFL GT2) 12v 4.6 Mesa 21.0.2
12direct render Yes
12Audio: 12Device-1 Intel Cannon Lake PCH cAVS 12vendor Dell 12driver snd_hda_intel 12v kernel
12bus-ID 00:1f.3 12chip-ID 8086:a348 12class-ID 0403
12Device-2 NVIDIA GP107GL High Definition Audio 12driver snd_hda_intel 12v kernel
12bus-ID 01:00.1 12chip-ID 10de:0fb9 12class-ID 0403
12Sound Server-1 ALSA 12v k5.9.16-1-MANJARO 12running yes
12Sound Server-2 JACK 12v 0.125.0 12running no
12Sound Server-3 PulseAudio 12v 14.2 12running yes
12Sound Server-4 PipeWire 12v 0.3.25 12running no
12Network: 12Device-1 Intel Wireless-AC 9560 [Jefferson Peak] 12driver iwlwifi 12v kernel 12port 5000
12bus-ID 00:14.3 12chip-ID 8086:a370 12class-ID 0280
12IF wlo1 12state down 12mac
12Device-2 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet 12vendor Dell
12driver r8169 12v kernel 12port 3000 12bus-ID 3b:00.0 12chip-ID 10ec:8168 12class-ID 0200
12IF enp59s0 12state down 12mac
12Bluetooth: 12Device-1 Intel Bluetooth 9460/9560 Jefferson Peak (JfP) 12type USB 12driver btusb 12v 0.8
12bus-ID 1-14:5 12chip-ID 8087:0aaa 12class-ID e001
12Report rfkill 12ID hci0 12rfk-id 1 12state up 12address see --recommends
12RAID: 12Hardware-1 Intel 82801 Mobile SATA Controller [RAID mode] 12driver ahci 12v 3.0 12port 5060
12bus-ID 00:17.0 12chip-ID 8086.282a 12rev 10 12class-ID 0104
12Drives: 12Local Storage 12total 1.04 TiB 12used 21.1 GiB (2.0%)
12ID-1 /dev/sda 12maj-min 8:0 12vendor Western Digital 12model WD10SPZX-75Z10T1
12family Blue Mobile (SMR) 12size 931.51 GiB 12block-size 12physical 4096 B 12logical 512 B
12sata 3.1 12speed 6.0 Gb/s 12rotation 5400 rpm 12serial 12rev 1A02 12temp 34 C
12SMART yes 12state enabled 12health PASSED 12on 103d 7h 12cycles 6349 12read 571.46 GiB
12written 578.69 GiB 12Old-Age 12g-sense error rate 470
12ID-2 /dev/sdb 12maj-min 8:16 12vendor SK Hynix 12model SC311 SATA 128GB 12family SATA SSDs
12size 119.24 GiB 12block-size 12physical 4096 B 12logical 512 B 12sata 3.2 12speed 6.0 Gb/s
12rotation SSD 12serial 12rev 0P10 12temp 31 C
12SMART yes 12state enabled 12health PASSED 12on 119d 1h 12cycles 6366
12ID-3 /dev/sdc 12maj-min 8:32 12type USB 12model USB DISK 3.0 12size 14.47 GiB 12block-size
12physical 512 B 12logical 512 B 12serial 12rev PMAP
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition: 12ID-1 / 12raw-size 118.95 GiB 12size 116.58 GiB (98.01%) 12used 21.1 GiB (18.1%) 12fs ext4
12block-size 4096 B 12dev /dev/sdb2 12maj-min 8:18
12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 324 KiB (0.1%) 12fs vfat
12block-size 512 B 12dev /dev/sdb1 12maj-min 8:17
12Swap: 12Alert No swap data was found.
12Sensors: 12System Temperatures 12cpu 59.0 C 12mobo N/A 12gpu nouveau 12temp 44.0 C
12Fan Speeds (RPM) N/A
12Info: 12Processes 317 12Uptime 1m 12wakeups 1 12Memory 7.64 GiB 12used 1.29 GiB (16.9%) 12Init systemd
12v 247 12tool systemctl 12Compilers 12gcc 10.2.0 12Packages 12pacman 1339 12lib 413 12flatpak 0
12Client Unknown Client: systemd 12inxi 3.3.04
^This is all the info from the first command
Apr 26 17:44:25 annmarie-dell-g33779 kernel: MDS CPU bug present and SMT on, data leak possible. See MDS - Microarchitectural Data Sampling — The Linux Kernel documentation for more details.
Apr 26 17:44:25 annmarie-dell-g33779 kernel: #7 #8 #9 #10 #11
Apr 26 17:44:25 annmarie-dell-g33779 kernel: ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’
Apr 26 17:44:25 annmarie-dell-g33779 kernel: ACPI Error: Aborting method _SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20200925/psparse-529)
Apr 26 17:44:25 annmarie-dell-g33779 kernel: ACPI Error: Method execution failed _SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20200925/uteval-68)
Apr 26 17:44:25 annmarie-dell-g33779 kernel: ACPI Error: Aborting method _SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20200925/psparse-529)
Apr 26 17:44:25 annmarie-dell-g33779 kernel: ACPI Error: Method execution failed _SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20200925/uteval-68)
Apr 26 17:44:25 annmarie-dell-g33779 kernel: hpet_acpi_add: no address or irqs in _CRS
Apr 26 17:44:25 annmarie-dell-g33779 kernel: i8042: Warning: Keylock active
Apr 26 17:44:26 annmarie-dell-g33779 kernel: nvidia: loading out-of-tree module taints kernel.
Apr 26 17:44:26 annmarie-dell-g33779 kernel: nvidia: module license ‘NVIDIA’ taints kernel.
Apr 26 17:44:26 annmarie-dell-g33779 kernel: Disabling lock debugging due to kernel taint
Apr 26 17:44:26 annmarie-dell-g33779 kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
Apr 26 17:44:26 annmarie-dell-g33779 kernel: wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
Apr 26 17:44:26 annmarie-dell-g33779 kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
Apr 26 17:44:26 annmarie-dell-g33779 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 460.67 Thu Mar 11 00:11:45 UTC 2021
Apr 26 17:44:26 annmarie-dell-g33779 kernel: i2c_hid i2c-DELL0870:00: supply vdd not found, using dummy regulator
Apr 26 17:44:26 annmarie-dell-g33779 kernel: i2c_hid i2c-DELL0870:00: supply vddl not found, using dummy regulator
Apr 26 17:44:26 annmarie-dell-g33779 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
Apr 26 17:44:26 annmarie-dell-g33779 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
Apr 26 17:44:26 annmarie-dell-g33779 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
Apr 26 17:44:26 annmarie-dell-g33779 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
Apr 26 17:44:26 annmarie-dell-g33779 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
Apr 26 17:44:26 annmarie-dell-g33779 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
^And here is the second
Thank you for helping me today, and hopefully we can fix this tomorrow. If anyone else sees this thread, please let me know if you can help
Ok well while I’m very grateful for your time and effort in trying to help me through this bug, I have to just bite the bullet and reinstall Manjaro due to time constraints with work. I hope you have a wonderful week! Again, thank you so much for your help.
