i have problem with kde she freeze after log and to
continue i choose tty then write
startx
i dont know what is problem
i install manjaro 2 times in my day
solve
all i do i just remove exec zsh from file .bashrc
startx
solve
so it doesnt really freeze, since you can enter tty and boot into it with startx command… its just stuck at a black screen?
provide formatted output from:
inxi -Fazy
mhwd -l && mhwd -li
Sorry, you can’t include links in your posts.
click this icon in editor: </> and inside it copy the output from those commands
inxi -Fazy
Kernel: 5.13.19-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8c0ce393-85f5-4be4-9848-99ce63170dd8 rw quiet
resume=UUID=6346156d-231f-4cf8-9ea2-cf5d02915b92 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId
Mobo: HP model: 84A7 v: 80.42 serial: <superuser required>
UEFI-[Legacy]: Insyde v: F.23 date: 11/29/2019
ID-1: BAT1 charge: 19.6 Wh (100.0%) condition: 19.6/41.9 Wh (46.7%)
volts: 12.8 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 709 high: 757 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 700 3: 700 4: 700
5: 700 6: 757 7: 719 8: 700 bogomips: 28808
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard
driver: N/A alternate: nouveau non-free: 515.xx+
status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 01:00.0
chip-ID: 10de:174d class-ID: 0302
Device-3: Quanta HP Webcam type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 0408:5321 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x71ec built: 2015 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:b822 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 29.12 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SPZX-60Z10T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A04 scheme: MBR
ID-1: / raw-size: 249 GiB size: 244.03 GiB (98.01%) used: 29.12 GiB (11.9%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-1: swap-1 type: partition size: 1024 MiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 52.0 C pch: 47.5 C mobo: N/A
Processes: 257 Uptime: 3m wakeups: 1 Memory: 7.68 GiB used: 1.04 GiB (13.5%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1387 lib: 358 flatpak: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.19
mhwd -l && mhwd -li
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0302:10de:174d) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.12.18 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-nvidia-390xx 2021.12.18 false PCI
> 0000:00:02.0 (0300:8086:5917) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
Warning: No installed USB configs
this is very likely the reason:
it seems you didnt install the latest manjaro iso… provide also output from:
mhwd-kernel -li
yes this iso i install is from 2 years
beacuse since 2 years i had install manjaro to today
you installed manjaro today from a 2 year old iso?
output from:
mhwd-kernel -li
yes
you have balls i give you that… download the latest iso from here
dont even waste your time on trying to fix such old iso…
wait, how could you have installed a 2 years old iso if you are running the latest plasma 5.24.5?
so did you do a clean install of manjaro today or not?
after install manjaro
update upgrade
install i3wm
then
sudo pacman -Syyu
install android studio
install vscode
install chrome
install i3wm inside kde
that i do and she works will
then when i log write my pass dont log just cursor
so log to tty and startx
kde work
i see so its probably the old kernel. post output from:
mhwd-kernel -li
manjaro-kde-21.1.6-minimal-211017-linux513
that iso
thats old, but if it works …
so post output from:
mhwd-kernel -li
linux513
so install the following kernels:
sudo pacman -S linux515 linux510
the linux510 as a backup
then reboot and select the 515 in the grub menu, and see if you can boot normally
i will do it … and download lts iso for manjaro i3wm
yes do it, its because you are running 5.13 kernel which is end of life, you stuck up on the black screen
