Manjaro pi armv8 qt5-webengine is broken for qutebrowser
Hi, after latest update qt5-engine, the files:
-rw-r--r-- 1 alarm alarm 1.6K Apr 17 18:53 libQt5WebEngineCore.prl
-rwxr-xr-x 1 alarm alarm 117M Apr 17 18:53 libQt5WebEngineCore.so
-rwxr-xr-x 1 alarm alarm 117M Apr 17 18:53 libQt5WebEngineCore.so.5
-rwxr-xr-x 1 alarm alarm 117M Apr 17 18:53 libQt5WebEngineCore.so.5.15
-rwxr-xr-x 1 alarm alarm 117M Apr 17 18:54 libQt5WebEngineCore.so.5.15.3
-rw-r--r-- 1 alarm alarm 1.6K Apr 17 18:53 libQt5WebEngine.prl
-rwxr-xr-x 1 alarm alarm 494K Apr 17 18:53 libQt5WebEngine.so
-rwxr-xr-x 1 alarm alarm 494K Apr 17 18:53 libQt5WebEngine.so.5
-rwxr-xr-x 1 alarm alarm 494K Apr 17 18:53 libQt5WebEngine.so.5.15
-rwxr-xr-x 1 alarm alarm 494K Apr 17 18:53 libQt5WebEngine.so.5.15.3
-rw-r--r-- 1 alarm alarm 1.8K Apr 17 18:54 libQt5WebEngineWidgets.prl
-rwxr-xr-x 1 alarm alarm 306K Apr 17 18:54 libQt5WebEngineWidgets.so
-rwxr-xr-x 1 alarm alarm 306K Apr 17 18:54 libQt5WebEngineWidgets.so.5
-rwxr-xr-x 1 alarm alarm 306K Apr 17 18:54 libQt5WebEngineWidgets.so.5.15
-rwxr-xr-x 1 alarm alarm 306K Apr 17 18:54 libQt5WebEngineWidgets.so.5.15.3
are not in the library, the browser:
error message is
QtWebEngine: libQt5WebEngineWidgets.so.5: cannot open shared object file: No such file or directory
Version         : 5.15.3-4
Description     : Provides support for web applications using the Chromium browser project
Architecture    : aarch64
URL             : https://www.qt.io
Licenses        : LGPL3  LGPL2.1  BSD
Groups          : qt  qt5
Provides        : None
Depends On      : qt5-webchannel  qt5-location  libxcomposite  libxrandr  pciutils  libxss
                  libevent  snappy  nss  libxslt  minizip  ffmpeg  re2  libvpx  libxtst
                  ttf-font
Optional Deps   : libpipewire02: WebRTC desktop sharing under Wayland
Required By     : python-pyqtwebengine
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 3.39 MiB
Packager        : Arch Linux ARM Build System <builder+seattle@archlinuxarm.org>
Build Date      : Sun 18 Apr 2021 04:51:41 AM CEST
Install Date    : Mon 19 Apr 2021 06:40:25 PM CEST
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : Signature
Problem solved with update qt5-webengine
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
