Manjaro partition keeps freezing up
Are you sure this is an actual software issue? It could be that the location Manjaro is installed on your drive is going bad. Check out SMART data
How do I do this? I have an SSD by the way, if that matters
I believe like this:
sudo smartctl -a /dev/sdX
Replacing "sdX" with the one of your drive. You can find the one for your drive by doing
lsblk
