Manjaro-openrc will be discontinued
openrc
artix
#250
Looking at the output of pacman -Qm, it seems that you have many lib32 packages that are becoming foreign… Have you set up Arch’s [multilib] repo properly in your pacman.conf?
#251
i had it there but thought maybe i should disable it, that it might not be supported given a comment i saw abobe (?) about multilib support coming eventually… can i go ahead and enable it then?
#252
Until artix provides repo for multilib, you can enable the arch’s repo for a while. Otherwise, some packages that requires multilib will not work in the next batch of updates…I think
#253
so what do you have listed for multilib? i tried to enable it and got 404 errors
@thefallenrat
error: failed retrieving file 'multilib.db' from netcologne.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from artix.mief.nl : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from freefr.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from 10gbps-io.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from netix.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from kent.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from superb-dca2.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from pilotfiber.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from iweb.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from managedway.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from cfhcable.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from svwh.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from versaweb.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from cytranet.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from gigenet.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from excellmedia.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from liquidtelecom.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from phoenixnap.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from superb-sea2.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from ayera.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from ufpr.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from razaoinfo.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from jaist.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from ncu.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from nchc.dl.sourceforge.net : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from vorboss.dl.sourceforge.net : The requested URL returned error: 404
error: failed to update multilib (unexpected error)
#254
Enable the multilib for the arch’s repos (mirrorlist-arch), not the artix ones…
Assumed that you followed the guide :
[multilib]
Include   = /etc/pacman.d/mirrorlist-arch
Not much…
~ >>> pacman -Qsq lib32-
lib32-acl
lib32-alsa-lib
lib32-alsa-plugins
lib32-atk
lib32-attr
lib32-bzip2
lib32-cairo
lib32-cracklib
lib32-curl
lib32-dbus
lib32-dbus-glib
lib32-e2fsprogs
lib32-expat
lib32-flac
lib32-fontconfig
lib32-freeglut
lib32-freetype2
lib32-gcc-libs
lib32-gconf
lib32-gdk-pixbuf2
lib32-gettext
lib32-giflib
lib32-glew
lib32-glew1.10
lib32-glib2
lib32-glibc
lib32-glu
lib32-gmp
lib32-gnutls
lib32-gtk2
lib32-harfbuzz
lib32-icu
lib32-imlib2
lib32-keyutils
lib32-krb5
lib32-lcms2
lib32-libappindicator-gtk2
lib32-libasyncns
lib32-libcaca
lib32-libcanberra
lib32-libcanberra-pulse
lib32-libcap
lib32-libcups
lib32-libcurl-compat
lib32-libcurl-gnutls
lib32-libdatrie
lib32-libdbusmenu-glib
lib32-libdbusmenu-gtk2
lib32-libdrm
lib32-libelf
lib32-libffi
lib32-libgcrypt
lib32-libgcrypt15
lib32-libglvnd
lib32-libgpg-error
lib32-libgudev
lib32-libice
lib32-libid3tag
lib32-libidn
lib32-libindicator-gtk2
lib32-libjpeg-turbo
lib32-libjpeg6-turbo
lib32-libldap
lib32-libltdl
lib32-libmikmod
lib32-libmodplug
lib32-libnl
lib32-libnm-glib
lib32-libogg
lib32-libpcap
lib32-libpciaccess
lib32-libpng
lib32-libpng12
lib32-libpsl
lib32-libpulse
lib32-librtmp0
lib32-libsm
lib32-libsndfile
lib32-libssh2
lib32-libtasn1
lib32-libthai
lib32-libtheora
lib32-libtiff
lib32-libtiff4
lib32-libtirpc
lib32-libtxc_dxtn
lib32-libudev0-shim
lib32-libusb
lib32-libva
lib32-libvorbis
lib32-libvpx1.3
lib32-libwebp
lib32-libwrap
lib32-libx11
lib32-libxau
lib32-libxcb
lib32-libxcomposite
lib32-libxcursor
lib32-libxdamage
lib32-libxdmcp
lib32-libxext
lib32-libxfixes
lib32-libxft
lib32-libxi
lib32-libxinerama
lib32-libxml2
lib32-libxmu
lib32-libxrandr
lib32-libxrender
lib32-libxshmfence
lib32-libxss
lib32-libxt
lib32-libxtst
lib32-libxxf86vm
lib32-llvm-libs
lib32-lm_sensors
lib32-mesa
lib32-mesa-demos
lib32-ncurses
lib32-nettle
lib32-nspr
lib32-nss
lib32-openal
lib32-openssl
lib32-openssl-1.0
lib32-p11-kit
lib32-pam
lib32-pango
lib32-pcre
lib32-pixman
lib32-polkit
lib32-readline
lib32-sdl
lib32-sdl2
lib32-sdl2_image
lib32-sdl2_mixer
lib32-sdl2_ttf
lib32-sdl_image
lib32-sdl_mixer
lib32-sdl_ttf
lib32-smpeg
lib32-smpeg2
lib32-speex
lib32-speexdsp
lib32-sqlite
lib32-systemd
lib32-tdb
lib32-util-linux
lib32-wayland
lib32-xz
lib32-zlib
#255
mine looks about the same
also now i have only those built from the aur lsted here:
pacman -Qm
etcher 1.1.1-1
google-chrome-dev 61.0.3163.13-1
manjaro-keyring 20170603-1
mintstick-git r173.22e8d64-1
neofetch 3.2.0-1
opera-ffmpeg-codecs 59.0.3071.115-1
pithos 1.3.1-1
python2-pyparted 3.10.7-1
ungoogled-chromium-bin 55.0.2883.75-4
maybe i don’t need manjaro keyring anymore?
you got way more 32 bit files there than me…
lib32-alsa-lib
lib32-attr
lib32-bzip2
lib32-dbus
lib32-expat
lib32-flac
lib32-gcc-libs
lib32-glew
lib32-glib2
lib32-glibc
lib32-glu
lib32-icu
lib32-libasyncns
lib32-libcanberra
lib32-libcap
lib32-libdrm
lib32-libelf
lib32-libffi
lib32-libgcrypt
lib32-libglvnd
lib32-libgpg-error
lib32-libice
lib32-libltdl
lib32-libogg
lib32-libpciaccess
lib32-libpulse
lib32-libsm
lib32-libsndfile
lib32-libtxc_dxtn
lib32-libva
lib32-libva-mesa-driver
lib32-libva-vdpau-driver
lib32-libvdpau
lib32-libvorbis
lib32-libx11
lib32-libxau
lib32-libxcb
lib32-libxdamage
lib32-libxdmcp
lib32-libxext
lib32-libxfixes
lib32-libxi
lib32-libxml2
lib32-libxmu
lib32-libxshmfence
lib32-libxt
lib32-libxtst
lib32-libxxf86vm
lib32-llvm-libs
lib32-lm_sensors
lib32-mesa
lib32-mesa-demos
lib32-mesa-vdpau
lib32-ncurses
lib32-pcre
lib32-readline
lib32-systemd
lib32-tdb
lib32-util-linux
lib32-vulkan-radeon
lib32-wayland
lib32-xz
lib32-zlib
#256
Hi @artoo
Congrats on consolidating the efforts of many devs into a single project for providing a truly systemd-free [core]-replacement for Arch/Manjaro.
Personally I don’t think this nor the dropping of i686 arch is a bad thing for Manjaro. I’ve always been in favour of the Manjaro repos being as lean as possible and the project not pushing the scope too far beyond it’s original intent.
For any project, when hours spent on maintenance are reduced, it means those hours can be spent on innovation and ensuring quality.
#257
If you are not using manjaro repos, then you are safe to remove the keyring. But I don’t , cause I’m still using it as there are many some good stuff in manjaro repo :grin: (*Note : Don’t try this at home)
#258
ok, now you have to spill… you’re using mhwd-chroot-shell i bet… what else? pamac… what else?
#259
@artoo
The point above about manjaro-keyring: can you include it in your [system] repo too so Manjaro repos can more easily be used with Artix?
EDIT: Is it safe to enable Arch or Manjaro [core] repo behind Artix’s repos? Just pondering if using Phil’s kernels and mhwd is possible…
#260
Oh god, I sholdn’t have said that :joy:
And no, no manjaro related tools in here, as I have uninstalled them all. But I managed to grab some goodies like :
#261
the manjaro kernels work? even with the different grub?
#262
Seems like it…
~ >>> uname -r
4.12.4-2-MANJARO
~ >>> pacman -Ss grub
system/grub 2.02-4 [installed]
    GNU GRand Unified Bootloader (2)
#263
so you have the core repo enabled then?
#264
Yes
#265
yes you do…
@thefallenrat i don’t suppose you have an amd graphics card running catalyst do you?
#266
Sadly, I don’t… :confused:
@LizziAS But if I do, I would like to try using catalyst …
#267
As far as my experience. I think it is safe enough enabling manjaro/arch core repo behind artix repo, as long as you be more careful when it comes to updating. Or else, you accidentally update some of the core packages that are not coming from artix repo
But, I’m still against of everyone to try enabling core repo unless they have enough experience doing it…
As for mhwd, I have just tried to reinstall mhwd. And I think it is still usable (Note that I didn’t try to download the kernel as I’m trying to save my bandwidth… Maybe next time)
~ >>> sudo mhwd-kernel -i linux49
 system        158.3 KiB   335K/s 00:00 [-----------------------------------------------------------] 100%
 world        86.7 KiB  1045K/s 00:00 [-----------------------------------------------------------] 100%
 galaxy        20.9 KiB  0.00B/s 00:00 [-----------------------------------------------------------] 100%
 core        139.9 KiB   202K/s 00:01 [-----------------------------------------------------------] 100%
 extra        1799.3 KiB   833K/s 00:02 [-----------------------------------------------------------] 100%
 community        4.3 MiB   869K/s 00:05 [-----------------------------------------------------------] 100%
 multilib        177.7 KiB  1708K/s 00:00 [-----------------------------------------------------------] 100%
 manjaro-strit                                                               18.5 KiB   369K/s 00:00 [-----------------------------------------------------------] 100%
 nulogic        8.8 KiB   630K/s 00:00 [-----------------------------------------------------------] 100%
resolving dependencies...
Package (1)   New Version  Net Change  Download Size
core/linux49  4.9.40-1      82.85 MiB      60.27 MiB
Total Download Size:   60.27 MiB
Total Installed Size:  82.85 MiB
:: Proceed with installation? [Y/n] n
~ >>> mhwd -l        [1]
> 0000:00:02.0 (0300:8086:0106) Display controller Intel Corporation:
           video-intel            2017.03.24                true            PCI
#268
now that’s interesting… i reinstalled the linux412 kernel and headers (manjarosettings-manager never installs the headers for some reason) and it booted but i must also say that even with all the majaro stuff removed my grub still showed manjaro on the boot menu… not Artix
#269
what’s those about?
