Hey guys~!
My OPENBOX polybar freezes frequently and I can’t find the reason,
But when I run polybar -r openbox-bar, everything will go fine.
Help me ; )_
System: Host: kaner-pc Kernel: 4.19.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: Openbox 3.6.1
info: tint2, polybar dm: LightDM 1.28.0 Distro: Manjaro Linux
Machine: Type: Portable System: Dell product: Inspiron N5110 v: N/A serial: <filter> Chassis: type: 8 serial: <filter>
Mobo: Dell model: 0FXK2Y v: A07 serial: <filter> BIOS: Dell v: A07 date: 07/18/2011
CPU: Topology: Dual Core model: Intel Core i5-2430M bits: 64 type: MT MCP arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19167
Speed: 1637 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 995 2: 955 3: 978 4: 1016
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0116
Device-2: NVIDIA GF108M [GeForce GT 525M] vendor: Dell driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:0df5
Display: x11 server: X.Org 1.20.3 driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
compositor: compton resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 18.3.2 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1c20
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0bea
Sound Server: ALSA v: k4.19.16-1-MANJARO
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: d000
bus ID: 05:00.0 chip ID: 10ec:8136
IF: enp5s0 state: down mac: <filter>
Device-2: Intel Centrino Wireless-N 1030 [Rainbow Peak] driver: iwlwifi v: kernel port: d000 bus ID: 09:00.0
chip ID: 8086:008a
IF: wlp9s0 state: up mac: <filter>
Drives: Local Storage: total: 465.76 GiB used: 6.35 GiB (1.4%)
ID-1: /dev/sda vendor: Toshiba model: MK5076GSX size: 465.76 GiB speed: 3.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: 2D scheme: GPT
Partition: ID-1: / size: 47.81 GiB used: 6.10 GiB (12.8%) fs: ext4 dev: /dev/sda3
ID-2: /boot size: 525.3 MiB used: 53.5 MiB (10.2%) fs: ext4 dev: /dev/sda2
ID-3: /home size: 401.17 GiB used: 202.3 MiB (0.0%) fs: ext4 dev: /dev/sda4
ID-4: swap-1 size: 7.81 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
Sensors: System Temperatures: cpu: 64.0 C mobo: N/A gpu: nouveau temp: 60 C
Fan Speeds (RPM): cpu: 3766
Info: Processes: 190 Uptime: 51m Memory: 3.76 GiB used: 1.05 GiB (27.9%) Init: systemd v: 239 Compilers: gcc: 8.2.1
Shell: zsh v: 5.6.2 running in: termite inxi: 3.0.30
