I am here to show what works and what don’t work on this laptop Teclast F5 - TECLAST
Installation went without problem.
I needed to upgrade the kernel to have wifi working fine, now I am using kernel 5.13.11-1 and I have only this warning in dmesg
rtw_8821ce 0000:01:00.0: timed out to flush queue 1
Bluetooth works fine but using it to connect to my cell phone via tethering/bluetooth was not affordable.
Sound is not working as I cannot see the sound board. In dmesg I see these lines
[ 4.012906] snd_hda_intel 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 4.418863] snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
The command
inxi -A
gives this result
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: snd_hda_intel
Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.33 running: yes
lspci -v
00:0e.0 Multimedia audio controller [0401]: Intel Corporation Celeron/Pentium Silver Processor High Definition Audio [8086:3198] (rev 03)
DeviceName: Onboard - Sound
Subsystem: Intel Corporation Device [8086:7270]
Flags: bus master, fast devsel, latency 0, IRQ 128
Memory at a1210000 (64-bit, non-prefetchable) [size=16K]
Memory at a1000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [50] Power Management version 3
Capabilities: [80] Vendor Specific Information: Len=14 <?>
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_apl
But alsamixer shows only hdmi output and this does not work: I found something in 213065 – Gemini Lake snd-hda-intel no HDMI audio but I cannot check more.
Touchpad works fine but sometimes after the suspend it did not work.
I found some help in in this page about ubuntu on this laptop GitHub - ijonglin/teclast-f5-ubuntu-finalizer: Current HW/SW Kernel/System/ACPI Modifications To Get a $400 Dream Ubuntu Linux Laptop but trying to remove (along with i2c_hid_acpi) and reinsert i2c_hid module did not work
