Ilia
12 September 2021 07:23
1
I have installed latest manjaro XFCE 21.1.2 Unfortunately after sleep (suspend) it crashed, nothing was displayed. I checked “journalctl -p3 -b-1” this is what I get:
Journal begins at Sat 2021-09-11 16:13:55 +04, ends at Sun 2021-09-12 11:06:00 +04. –
სექ 12 09:53:48 ilia-aspirea31557g kernel: x86/cpu: SGX disabled by BIOS.
სექ 12 09:53:49 ilia-aspirea31557g kernel: intel-spi 0000:00:1f.5: invalid resource
სექ 12 09:53:49 ilia-aspirea31557g systemd-udevd[315]: could not read from ‘/sys/module/pcc_cpufreq/initstate’: No such device
სექ 12 09:54:03 ilia-aspirea31557g lightdm[854]: gkr-pam: unable to locate daemon control file
სექ 12 09:59:36 ilia-aspirea31557g systemd-coredump[2638]: [🡕] Process 2623 (panel-12-xfce4-) of user 1000 dumped core.
Stack trace of thread 2623:
#0 0x00007fd97a9f3168 n/a (libclipman.so + 0x5168)
#1 0x00007fd979da7d8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
#2 0x00007fd979dc377b n/a (libgobject-2.0.so.0 + 0x2e77b)
#3 0x00007fd979dc4c49 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fc49)
#4 0x00007fd979dc51a0 g_signal_emit (libgobject-2.0.so.0 + 0x301a0)
#5 0x00007fd97a541db9 gtk_widget_realize (libgtk-3.so.0 + 0x32fdb9)
#6 0x00007fd97a542119 gtk_widget_map (libgtk-3.so.0 + 0x330119)
#7 0x00007fd979da7d8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
#8 0x00007fd979dc31cf n/a (libgobject-2.0.so.0 + 0x2e1cf)
#9 0x00007fd979dc4c49 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fc49)
#10 0x00007fd979dc51a0 g_signal_emit (libgobject-2.0.so.0 + 0x301a0)
#11 0x00007fd97a542797 gtk_widget_show (libgtk-3.so.0 + 0x330797)
#12 0x0000564055e7e332 main (wrapper-2.0 + 0x3332)
#13 0x00007fd979aa4b25 __libc_start_main (libc.so.6 + 0x27b25)
#14 0x0000564055e7e48e _start (wrapper-2.0 + 0x348e)
Stack trace of thread 2625:
#0 0x00007fd979b70b2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007fd979cf0b39 n/a (libglib-2.0.so.0 + 0xa7b39)
#2 0x00007fd979c9c693 g_main_loop_run (libglib-2.0.so.0 + 0x53693)
#3 0x00007fd979ef28c8 n/a (libgio-2.0.so.0 + 0x1018c8)
#4 0x00007fd979ccb2d1 n/a (libglib-2.0.so.0 + 0x822d1)
#5 0x00007fd979368259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007fd979b7b5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 2624:
#2 0x00007fd979c9a871 g_main_context_iteration (libglib-2.0.so.0 + 0x51871)
#3 0x00007fd979c9a8c2 n/a (libglib-2.0.so.0 + 0x518c2)
სექ 12 09:59:40 ilia-aspirea31557g systemd-coredump[2657]: [🡕] Process 2648 (panel-12-xfce4-) of user 1000 dumped core.
Stack trace of thread 2648:
#0 0x00007f17ba754168 n/a (libclipman.so + 0x5168)
#1 0x00007f17b9b08d8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
#2 0x00007f17b9b2477b n/a (libgobject-2.0.so.0 + 0x2e77b)
#3 0x00007f17b9b25c49 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fc49)
#4 0x00007f17b9b261a0 g_signal_emit (libgobject-2.0.so.0 + 0x301a0)
#5 0x00007f17ba2a2db9 gtk_widget_realize (libgtk-3.so.0 + 0x32fdb9)
#6 0x00007f17ba2a3119 gtk_widget_map (libgtk-3.so.0 + 0x330119)
#7 0x00007f17b9b08d8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
#8 0x00007f17b9b241cf n/a (libgobject-2.0.so.0 + 0x2e1cf)
#9 0x00007f17b9b25c49 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fc49)
#10 0x00007f17b9b261a0 g_signal_emit (libgobject-2.0.so.0 + 0x301a0)
#11 0x00007f17ba2a3797 gtk_widget_show (libgtk-3.so.0 + 0x330797)
#12 0x000055c2c8750332 main (wrapper-2.0 + 0x3332)
#13 0x00007f17b9805b25 __libc_start_main (libc.so.6 + 0x27b25)
#14 0x000055c2c875048e _start (wrapper-2.0 + 0x348e)
Stack trace of thread 2650:
#0 0x00007f17b98ddcfd sendmsg (libc.so.6 + 0xffcfd)
#1 0x00007f17b9be5b7d g_socket_send_message_with_timeout (libgio-2.0.so.0 + 0x93b7d)
#2 0x00007f17b9be5e44 g_socket_send_message (libgio-2.0.so.0 + 0x93e44)
#3 0x00007f17b9c5c2da n/a (libgio-2.0.so.0 + 0x10a2da)
#4 0x00007f17b9c5c956 n/a (libgio-2.0.so.0 + 0x10a956)
#5 0x00007f17b9c5cab9 n/a (libgio-2.0.so.0 + 0x10aab9)
#6 0x00007f17b99fe015 g_main_context_dispatch (libglib-2.0.so.0 + 0x54015)
#7 0x00007f17b9a51ba9 n/a (libglib-2.0.so.0 + 0xa7ba9)
#8 0x00007f17b99fd693 g_main_loop_run (libglib-2.0.so.0 + 0x53693)
#9 0x00007f17b9c538c8 n/a (libgio-2.0.so.0 + 0x1018c8)
#10 0x00007f17b9a2c2d1 n/a (libglib-2.0.so.0 + 0x822d1)
#11 0x00007f17b90c9259 start_thread (libpthread.so.0 + 0x9259)
#12 0x00007f17b98dc5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 2649:
#0 0x00007f17b98d1b2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f17b9a51b39 n/a (libglib-2.0.so.0 + 0xa7b39)
#2 0x00007f17b99fb871 g_main_context_iteration (libglib-2.0.so.0 + 0x51871)
#3 0x00007f17b99fb8c2 n/a (libglib-2.0.so.0 + 0x518c2)
#4 0x00007f17b9a2c2d1 n/a (libglib-2.0.so.0 + 0x822d1)
#5 0x00007f17b90c9259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f17b98dc5e3 __clone (libc.so.6 + 0xfe5e3)
სექ 12 10:36:16 ilia-aspirea31557g systemd-coredump[14252]: Failed to connect to coredump service: Connection refused
სექ 12 10:36:17 ilia-aspirea31557g pulseaudio[14408]: GetManagedObjects() failed: org.freedesktop.systemd1.ShuttingDown: Refusing activation, D-Bus is shutting down.
What could possible be a reason for this? Should I increase/decrease swap usage?
I would try other power saving settings in the bios, when not succesfull try an other kernel…
also alternatively possible solution to turn in settings powersave options from hibernation to sleep
Please post the full log of the suspend process:
journalctl --boot -1 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
Ilia
12 September 2021 19:48
5
This is what I have got:
სექ 12 11:05:22 ilia-aspirea31557g systemd[1]: Starting System Suspend...
სექ 12 11:05:22 ilia-aspirea31557g wpa_supplicant[788]: nl80211: deinit ifname=p2p-dev-wlp4s0 disabled_11b_rates=0
სექ 12 11:05:22 ilia-aspirea31557g wpa_supplicant[788]: nl80211: deinit ifname=wlp4s0 disabled_11b_rates=0
სექ 12 11:05:23 ilia-aspirea31557g systemd-sleep[4163]: Suspending system...
სექ 12 11:05:23 ilia-aspirea31557g kernel: PM: suspend entry (deep)
სექ 12 11:05:37 ilia-aspirea31557g kernel: Filesystems sync: 0.012 seconds
სექ 12 11:05:37 ilia-aspirea31557g kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
სექ 12 11:05:37 ilia-aspirea31557g kernel: OOM killer disabled.
სექ 12 11:05:37 ilia-aspirea31557g kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
სექ 12 11:05:37 ilia-aspirea31557g kernel: printk: Suspending console(s) (use no_console_suspend to debug)
სექ 12 11:05:37 ilia-aspirea31557g kernel: ACPI: EC: interrupt blocked
სექ 12 11:05:37 ilia-aspirea31557g kernel: ACPI: Preparing to enter system sleep state S3
სექ 12 11:05:37 ilia-aspirea31557g kernel: ACPI: EC: event blocked
სექ 12 11:05:37 ilia-aspirea31557g kernel: ACPI: EC: EC stopped
სექ 12 11:05:37 ilia-aspirea31557g kernel: PM: Saving platform NVS memory
სექ 12 11:05:37 ilia-aspirea31557g kernel: Disabling non-boot CPUs ...
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: CPU 1 is now offline
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: CPU 2 is now offline
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: CPU 3 is now offline
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: CPU 4 is now offline
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: CPU 5 is now offline
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: CPU 6 is now offline
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: CPU 7 is now offline
სექ 12 11:05:37 ilia-aspirea31557g kernel: ACPI: Low-level resume complete
სექ 12 11:05:37 ilia-aspirea31557g kernel: ACPI: EC: EC started
სექ 12 11:05:37 ilia-aspirea31557g kernel: PM: Restoring platform NVS memory
სექ 12 11:05:37 ilia-aspirea31557g kernel: Enabling non-boot CPUs ...
სექ 12 11:05:37 ilia-aspirea31557g kernel: x86: Booting SMP configuration:
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
სექ 12 11:05:37 ilia-aspirea31557g kernel: CPU1 is up
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
სექ 12 11:05:37 ilia-aspirea31557g kernel: CPU2 is up
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
სექ 12 11:05:37 ilia-aspirea31557g kernel: CPU3 is up
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
სექ 12 11:05:37 ilia-aspirea31557g kernel: CPU4 is up
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
სექ 12 11:05:37 ilia-aspirea31557g kernel: CPU5 is up
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
სექ 12 11:05:37 ilia-aspirea31557g kernel: CPU6 is up
სექ 12 11:05:37 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
სექ 12 11:05:37 ilia-aspirea31557g kernel: CPU7 is up
სექ 12 11:05:37 ilia-aspirea31557g kernel: ACPI: Waking up from system sleep state S3
სექ 12 11:05:37 ilia-aspirea31557g kernel: ACPI: EC: interrupt unblocked
სექ 12 11:05:37 ilia-aspirea31557g kernel: ACPI: EC: event unblocked
სექ 12 11:05:37 ilia-aspirea31557g kernel: nvme nvme0: Shutdown timeout set to 10 seconds
სექ 12 11:05:37 ilia-aspirea31557g kernel: nvme nvme0: 8/0/0 default/read/poll queues
სექ 12 11:05:37 ilia-aspirea31557g kernel: usb 1-5: reset high-speed USB device number 2 using xhci_hcd
სექ 12 11:05:37 ilia-aspirea31557g kernel: ata1: SATA link down (SStatus 4 SControl 300)
სექ 12 11:05:37 ilia-aspirea31557g kernel: ata2: SATA link down (SStatus 4 SControl 300)
სექ 12 11:05:37 ilia-aspirea31557g kernel: acpi LNXPOWER:06: Turning OFF
სექ 12 11:05:37 ilia-aspirea31557g kernel: acpi LNXPOWER:05: Turning OFF
სექ 12 11:05:37 ilia-aspirea31557g kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
სექ 12 11:05:37 ilia-aspirea31557g kernel: acpi LNXPOWER:04: Turning OFF
სექ 12 11:05:37 ilia-aspirea31557g kernel: OOM killer enabled.
სექ 12 11:05:37 ilia-aspirea31557g kernel: Restarting tasks ...
სექ 12 11:05:37 ilia-aspirea31557g kernel: nouveau 0000:02:00.0: Enabling HDA controller
სექ 12 11:05:37 ilia-aspirea31557g kernel: done.
სექ 12 11:05:37 ilia-aspirea31557g kernel: PM: suspend exit
სექ 12 11:05:37 ilia-aspirea31557g systemd-sleep[4163]: System resumed.
სექ 12 11:05:37 ilia-aspirea31557g systemd[1]: systemd-suspend.service: Deactivated successfully.
სექ 12 11:05:37 ilia-aspirea31557g audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
სექ 12 11:05:37 ilia-aspirea31557g audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
სექ 12 11:05:37 ilia-aspirea31557g systemd[1]: Finished System Suspend.
სექ 12 12:18:16 ilia-aspirea31557g systemd[1]: Starting System Suspend...
სექ 12 12:18:16 ilia-aspirea31557g wpa_supplicant[788]: nl80211: deinit ifname=p2p-dev-wlp4s0 disabled_11b_rates=0
სექ 12 12:18:16 ilia-aspirea31557g wpa_supplicant[788]: nl80211: deinit ifname=wlp4s0 disabled_11b_rates=0
სექ 12 12:18:16 ilia-aspirea31557g systemd-sleep[9671]: Suspending system...
სექ 12 12:18:16 ilia-aspirea31557g kernel: PM: suspend entry (deep)
სექ 12 12:37:16 ilia-aspirea31557g kernel: Filesystems sync: 0.013 seconds
სექ 12 12:37:16 ilia-aspirea31557g kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
სექ 12 12:37:16 ilia-aspirea31557g kernel: OOM killer disabled.
სექ 12 12:37:16 ilia-aspirea31557g kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
სექ 12 12:37:16 ilia-aspirea31557g kernel: printk: Suspending console(s) (use no_console_suspend to debug)
სექ 12 12:37:16 ilia-aspirea31557g kernel: ACPI: EC: interrupt blocked
სექ 12 12:37:16 ilia-aspirea31557g kernel: ACPI: Preparing to enter system sleep state S3
სექ 12 12:37:16 ilia-aspirea31557g kernel: ACPI: EC: event blocked
სექ 12 12:37:16 ilia-aspirea31557g kernel: ACPI: EC: EC stopped
სექ 12 12:37:16 ilia-aspirea31557g kernel: PM: Saving platform NVS memory
სექ 12 12:37:16 ilia-aspirea31557g kernel: Disabling non-boot CPUs ...
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: CPU 1 is now offline
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: CPU 2 is now offline
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: CPU 3 is now offline
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: CPU 4 is now offline
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: CPU 5 is now offline
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: CPU 6 is now offline
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: CPU 7 is now offline
სექ 12 12:37:16 ilia-aspirea31557g kernel: ACPI: Low-level resume complete
სექ 12 12:37:16 ilia-aspirea31557g kernel: ACPI: EC: EC started
სექ 12 12:37:16 ilia-aspirea31557g kernel: PM: Restoring platform NVS memory
სექ 12 12:37:16 ilia-aspirea31557g kernel: Enabling non-boot CPUs ...
სექ 12 12:37:16 ilia-aspirea31557g kernel: x86: Booting SMP configuration:
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
სექ 12 12:37:16 ilia-aspirea31557g kernel: CPU1 is up
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
სექ 12 12:37:16 ilia-aspirea31557g kernel: CPU2 is up
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
სექ 12 12:37:16 ilia-aspirea31557g kernel: CPU3 is up
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
სექ 12 12:37:16 ilia-aspirea31557g kernel: CPU4 is up
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
სექ 12 12:37:16 ilia-aspirea31557g kernel: CPU5 is up
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
სექ 12 12:37:16 ilia-aspirea31557g kernel: CPU6 is up
სექ 12 12:37:16 ilia-aspirea31557g kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
სექ 12 12:37:16 ilia-aspirea31557g kernel: CPU7 is up
სექ 12 12:37:16 ilia-aspirea31557g kernel: ACPI: Waking up from system sleep state S3
სექ 12 12:37:16 ilia-aspirea31557g kernel: ACPI: EC: interrupt unblocked
სექ 12 12:37:16 ilia-aspirea31557g kernel: ACPI: EC: event unblocked
სექ 12 12:37:16 ilia-aspirea31557g kernel: nvme nvme0: Shutdown timeout set to 10 seconds
სექ 12 12:37:16 ilia-aspirea31557g kernel: nvme nvme0: 8/0/0 default/read/poll queues
სექ 12 12:37:16 ilia-aspirea31557g kernel: usb 1-5: reset high-speed USB device number 2 using xhci_hcd
სექ 12 12:37:16 ilia-aspirea31557g kernel: ata1: SATA link down (SStatus 4 SControl 300)
სექ 12 12:37:16 ilia-aspirea31557g kernel: ata2: SATA link down (SStatus 4 SControl 300)
სექ 12 12:37:16 ilia-aspirea31557g kernel: acpi LNXPOWER:06: Turning OFF
სექ 12 12:37:16 ilia-aspirea31557g kernel: acpi LNXPOWER:05: Turning OFF
სექ 12 12:37:16 ilia-aspirea31557g kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
სექ 12 12:37:16 ilia-aspirea31557g kernel: acpi LNXPOWER:04: Turning OFF
სექ 12 12:37:16 ilia-aspirea31557g kernel: OOM killer enabled.
სექ 12 12:37:16 ilia-aspirea31557g kernel: Restarting tasks ...
სექ 12 12:37:16 ilia-aspirea31557g kernel: nouveau 0000:02:00.0: Enabling HDA controller
სექ 12 12:37:16 ilia-aspirea31557g kernel: done.
სექ 12 12:37:16 ilia-aspirea31557g systemd-sleep[9671]: System resumed.
სექ 12 12:37:16 ilia-aspirea31557g kernel: PM: suspend exit
სექ 12 12:37:16 ilia-aspirea31557g systemd[1]: systemd-suspend.service: Deactivated successfully.
სექ 12 12:37:16 ilia-aspirea31557g systemd[1]: Finished System Suspend.
Both suspend and resume processes were normal without errors, so it does not crash in any way, but possible that your nvidia gpu does reinitialize correctly with the nouveau driver.
Could you post your system information?
inxi -Fazy
Ilia
12 September 2021 20:20
7
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a1c22080-aacc-43f6-a843-e4a28d899f26 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: Acer product: Aspire A315-57G v: V1.13 serial: <filter>
Mobo: IL model: Happy_IL v: V1.13 serial: <filter> UEFI: Insyde v: 1.13
date: 10/15/2020
ID-1: BAT1 charge: 24.9 Wh (75.9%) condition: 32.8/37.0 Wh (88.6%)
volts: 7.9 min: 7.7 model: PANASONIC AP16M5J type: Li-ion serial: <filter>
status: Discharging
Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
L2: 8 MiB
bogomips: 23968
Speed: 1268 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1268 2: 1305
3: 1301 4: 1289 5: 1300 6: 1300 7: 1200 8: 1300
Ilia
12 September 2021 20:22
8
Device-1: Intel Iris Plus Graphics G7 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Acer Incorporated ALI
driver: nouveau v: kernel bus-ID: 02:00.0 chip-ID: 10de:1d16 class-ID: 0302
Device-3: Quanta VGA WebCam type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 0408:a031 class-ID: 0e02 serial: <filter>
Display: x11 server: X. Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel port: 3000 bus-ID: 04:00.0
chip-ID: 168c:0042 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-10:3 chip-ID: 04ca:3015 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 13.78 GiB (2.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AA
lanes: 4 type: SSD serial: <filter> rev: ECFK52.3 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 13.78 GiB (2.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nouveau temp: 44.0 C
Processes: 285 Uptime: 1h 9m wakeups: 1 Memory: 11.47 GiB
used: 3.15 GiB (27.4%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1093 pacman: 1087 lib: 305 flatpak: 0 snap: 6
Shell: Zsh v: 5.8 running-in: xfce4-terminal inxi: 3.3.06
Not sure, if the Nvidia GPU is still supported with the legacy drivers, but you can try it:
sudo mhwd --auto pci nonfree 0300
This should select the correct driver automatically.
Ilia
12 September 2021 20:35
11
I got this: Warning: No device of class 0300~ found!
Not sure, but this should be then the correct class:
Ilia:
class-ID: 0302
sudo mhwd --auto pci nonfree 0302
Otherwise list possible drivers:
mhwd --list
mhwd --listinstalled
and install the a driver like:
sudo mhwd --install pci video-hybrid-intel-nvidia-390xx-bumblebee
or
sudo mhwd --install pci video-hybrid-intel-nvidia-prime
and reboot.
Ilia
12 September 2021 21:13
13
Thank you very much. Using correct class-ID helped.
