[manjaro@manjaro ~]$ sudo parted -l
Model: ATA ST1000LM035-1RK1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 524MB 523MB ntfs Basic data partition hidden, diag
2 524MB 629MB 105MB fat32 EFI system partition boot, esp
3 629MB 646MB 16.8MB Microsoft reserved partition msftres
4 646MB 318GB 317GB ntfs Basic data partition msftdata
5 318GB 319GB 544MB ntfs hidden, diag
6 319GB 581GB 262GB ntfs Basic data partition msftdata
7 581GB 895GB 315GB ntfs Basic data partition msftdata
8 895GB 896GB 537MB fat32 legacy_boot, msftdata
9 896GB 900GB 4245MB linux-swap(v1) swap, legacy_boot
10 900GB 1000GB 100GB ext4
Model: MXT-USB Storage Device (scsi)
Disk /dev/sdb: 16.5GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2369MB 2374MB 4194kB primary esp
[manjaro@manjaro ~]$ sudo blkid
/dev/sda1: LABEL="Recovery" BLOCK_SIZE="512" UUID="F2F863E4F863A617" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="f104340d-f9dc-4ed6-9cd6-7dea18a6dd41"
/dev/sda2: LABEL="SYSPART" UUID="6687-3F69" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="fb73161f-a78f-4f29-9ea4-a208255354a7"
/dev/sda3: PARTLABEL="Microsoft reserved partition" PARTUUID="1988606b-2de0-413e-b8fa-a01117e66f2a"
/dev/sda4: BLOCK_SIZE="512" UUID="5662CC4162CC2817" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="f78334af-892c-4811-82d2-fdfb1a36f4fb"
/dev/sda5: BLOCK_SIZE="512" UUID="30F88711F886D48E" TYPE="ntfs" PARTUUID="f4c867c9-f240-4b00-b414-e0ee4ac03992"
/dev/sda6: LABEL="Dhruv" BLOCK_SIZE="512" UUID="D2EECF3FEECF1A9D" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="525722d3-6e86-42fd-9eea-663e85c5861e"
/dev/sda7: BLOCK_SIZE="512" UUID="346EF27A6EF23468" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="6df9e7f5-9df4-49b2-b148-6504af1434c6"
/dev/sda8: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="3206-0784" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="0007fb8d-e632-fb45-b550-4072dc89c9f2"
/dev/sda9: UUID="711b6e6b-5484-410c-a8c7-c2340ec81294" TYPE="swap" PARTUUID="8dc265bb-561f-0349-a70c-210b52fceebf"
/dev/sda10: UUID="d4d282d0-771a-42c1-8441-903aa6e9f1a1" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="e3087787-75b4-224a-9a2d-baeb10937e76"
/dev/sdb1: BLOCK_SIZE="2048" UUID="2021-04-10-10-28-19-00" LABEL="MANJARO_KDEM_2101" TYPE="iso9660"
/dev/sdb2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="99A3-05D0" BLOCK_SIZE="512" TYPE="vfat"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
[manjaro@manjaro ~]$ cat /etc/fstab
# /etc/fstab: static file system information
# <file system> <dir> <type> <options> <dump> <pass>
/dev/mapper/root-image / auto defaults 0 0
type manjaro-chroot -a
before. It will âloginâ into you local drive and execute the commands there and not on the live session.
yeah sorry I forgot to chroot it âŚthis one doesnât seem different.
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda10]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
[manjaro /]# sudo blkid
[manjaro /]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=3206-0784 /boot/efi vfat umask=0077 0 2
UUID=711b6e6b-5484-410c-a8c7-c2340ec81294 swap swap defaults,noatime 0 0
UUID=d4d282d0-771a-42c1-8441-903aa6e9f1a1 / ext4 defaults,noatime 0 1
OK UUID is correct. You did not choose the windows efi partition:
However, run gparted or kparted and rightclick on the efi partition, click on âmanage flagsâ and change it to âbootâ. Not âlegacy_bootâ. It have to be âboot, espâ at the end.
can you explain this a bit step by step ?
which one do i have to change?
edit : i got it
okay so i managed to change the flag but the ext4 partition is mounted in /mnt but the fat32(efi) is not mounted in/mnt/boot/efi so is it okay?
It is mounted that way on the live session. On the real disk it is without /mnt
thanks a bunch broo it workedâŚfinally!!!
I am so happy
