Manjaro is installed as a dual boot with Ubuntu and displays in GParted but does not display in grub on start-up or in grub-customizer.
Is os-prober
installed and enabled?
os-prober
In a multiboot scenario, another OS may not appear in the GRUB menu due to os-prober
not being enabled. The os-prober package is responsible for detecting another OS during boot. Due to an apparent GRUB (v2.06) security recommendation, os-prober is often disabled in some distributions, or removed completely.
Install/Enable OS-Prober
While there is/was a valid security reason for this decision, it’s incredibly inconvenient when multibooting. Here’s how to solve the annoyance (if needed):
01. Verify that os-prober is installed; install it, if it isn’t:
# Verify os-prober is installed
pacman -Qi os-prober
# Install os-prober (if needed)
sudo pacman -S os-prober
02. Check the status of os-prober;
cat /etc/default/grub | grep -i 'OS_PROBER'
# The output should include this line:
#GRUB_DISABLE_OS_PROBER=false
03. If the line is commented (#
), uncomment it:
sudo nano /etc/default/grub
# UNCOMMENT this line to enable OS-Prober:
04. Update GRUB:
sudo update-grub
On the next reboot, os-prober should function as expected and any other OS should be automatically detected and listed in the GRUB 2 menu.
I hope this helps.
Cheers.
Welcome to the forum!
Please don’t use that. It completely messes up Manjaro’s GRUB.
