Hi
After a clean install, I’m trying to enable wayland again following the steps in the following thread:
Problem being that after a reboot I’m still on x11 when I try echo $XDG_SESSION_TYPE
The only thing that isn’t working from those steps is:
gsettings set org.gnome.mutter experimental-features [\"kms-modifiers\"]
Which outputs:
zsh: no matches found: ["kms-modifiers"]
But I don’t know if that should prevent me from having Wayland up & running
I’ve been on Wayland for a couple of weeks now so I know it works, I just can’t seem to figure out why it doesn’t right now after this clean install.
Nvidia drivers are on 470.57.02
Xwayland is on 21.1.2-1
I’m currently on the stable branch and have no pending updates (updated right after the clean install).
inxi output
Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=221560a5-3f1c-47a5-972c-a19c5b904970 rw quiet
cryptdevice=UUID=217d51cf-60d8-41d9-baf9-4cfe69b36363:luks-217d51cf-60d8-41d9-baf9-4cfe69b36363
root=/dev/mapper/luks-217d51cf-60d8-41d9-baf9-4cfe69b36363
resume=/dev/mapper/luks-c5808056-670f-494e-8d35-2bb6fdfab985
udev.log_priority=3 nvidia-drm.modeset=1
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: Dell product: Precision 5540 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0FMYX6 v: A00 serial: <filter> UEFI: Dell v: 1.10.0
date: 03/04/2021
ID-1: BAT0 charge: 28.5 Wh (37.3%) condition: 76.4/97.0 Wh (78.8%)
volts: 10.7 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: Discharging
RAM: total: 30.99 GiB used: 2.72 GiB (8.8%)
Info: 8-Core model: Intel Core i9-9880H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: D (13)
microcode: EA cache: L2: 16 MiB bogomips: 73625
Speed: 4532 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 4532 2: 4447
3: 4567 4: 4201 5: 4501 6: 4193 7: 4529 8: 4207 9: 4500 10: 4192 11: 4501
12: 4186 13: 4187 14: 4597 15: 4501 16: 4445
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1fb8 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:4 chip-ID: 0c45:6723 class-ID: 0e02
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting unloaded: nvidia alternate: fbdev,intel,nouveau,nv,vesa
display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.5
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 3000
bus-ID: 3b:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-4:2 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Device-1: luks-217d51cf-60d8-41d9-baf9-4cfe69b36363 maj-min: 254:0
type: LUKS dm: dm-0 size: 919.47 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 919.47 GiB
Device-2: luks-c5808056-670f-494e-8d35-2bb6fdfab985 maj-min: 254:1
type: LUKS dm: dm-1 size: 34.09 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 34.1 GiB
Local Storage: total: 953.87 GiB used: 11.23 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel
model: SSDPEMKF010T8 NVMe 1024GB size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 7003 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 919.47 GiB size: 903.97 GiB (98.31%)
used: 11.23 GiB (1.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-217d51cf-60d8-41d9-baf9-4cfe69b36363 label: N/A
uuid: 221560a5-3f1c-47a5-972c-a19c5b904970
used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 5B48-3958
ID-1: swap-1 type: partition size: 34.09 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-c5808056-670f-494e-8d35-2bb6fdfab985 label: N/A
uuid: faa93ca4-13ae-4470-adb8-ebe0e33a2722
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-4:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Device-2: 1-7:3 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
serial: <filter>
Device-3: 1-12:4 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 339 Uptime: 17m wakeups: 1918 Init: systemd v: 248
tool: systemctl Compilers: gcc: N/A Packages: pacman: 961 lib: 270
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
