I’ve followed the steps from the Arch Wiki to install jellyfin-bin
❯ yay -S jellyfin-bin
❯ sudo systemctl enable --now jellyfin.service
❯ sudo systemctl status jellyfin.service
● jellyfin.service - Jellyfin Media Server
Loaded: loaded (/usr/lib/systemd/system/jellyfin.service; enabled; preset: disabled)
Active: active (running) since Sun 2023-07-09 18:45:17 CEST; 31min ago
Main PID: 184106 (jellyfin)
Tasks: 27 (limit: 37755)
Memory: 333.3M
CPU: 9.106s
CGroup: /system.slice/jellyfin.service
└─184106 /usr/lib/jellyfin/bin/jellyfin --datadir /var/lib/jellyfin --cachedir /var/cache/jellyfin --webdi>
I visit http://localhost:8096 select the available server and I get the error
We're unable to connect to the selected server right now. Please ensure it is running and try again.
The wiki says
Note: Check if any firewall settings are obstructing connection to Jellyfin if issues arise at this point.
but I don’t think I have a firewall enabled:
❯ sudo ufw status
[sudo] password for user:
Status: inactive
