Just what the title says, when I plug in a flash drive into a usb port, it disables my bluetooth and it doesn’t recognize that there is a flash drive plugged in. I can reboot the laptop and the usb works until I unplug the flash drive. This appears to disable the micro-sd slot as well. I am running Linux kernal 5.9.16-1
Hey, That is a weird problem, does the drive work on another machine?
A few things to try: use a lts kernel: MSM or mhwd-kernel
. (5.9 is no longer being updated)
For others to help some sort of error would be usefull. Try logging the error using sudo dmesg --follow
before plugging in the the drive and post the output here using these tips.
Generally when posting with these kinds of issues it is of great value to others that the system hardware is posted with it. The tips explain what is usually needed.
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=0ba5d092-d32d-4ae8-ab69-33258e964d91 ro quiet apparmor=1
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X512DAP_F512DA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X512DAP v: 1.0 serial: <filter>
UEFI: American Megatrends v: X512DAP.302 date: 08/04/2020
ID-1: BAT0 charge: 22.1 Wh (60.2%) condition: 36.7/37.1 Wh (98.7%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 2
RAM: total: 9.74 GiB used: 2.27 GiB (23.3%)
Info: Dual Core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108109 cache: L2: 1024 KiB bogomips: 20769
Speed: 1223 MHz min/max: 1400/2600 MHz boost: enabled Core speeds (MHz):
1: 1223 2: 1231 3: 1347 4: 1227
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6.2:6 chip-ID: 13d3:56dd class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 3 Graphics (RAVEN2 DRM 3.39.0
5.9.16-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.22 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: f000
bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-6.1:5 chip-ID: 13d3:3530 class-ID: e001 serial: <filter>
Local Storage: total: 238.72 GiB used: 17.02 GiB (7.1%)
ID-1: /dev/mmcblk0 maj-min: 179:0 type: USB model: SD128 size: 119.48 GiB
block-size: physical: 512 B logical: 512 B rotation: SSD serial: <filter>
scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3128GJ3
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 rotation: SSD serial: <filter> rev: E8FK11.T temp: 40.9 C
scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 116.58 GiB (98.01%)
used: 17.02 GiB (14.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 0ba5d092-d32d-4ae8-ab69-33258e964d91
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 827D-999A
ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 119.48 GiB fs: ext4 label: Files
uuid: ca977ac4-c1a9-44f0-96c8-9b804b7a3fef
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-4:2 info: Corsair Gaming HARPOON RGB Mouse type: Mouse,HID
power: 300mA chip-ID: 1b1c:1b3c class-ID: 0300 serial: <filter>
Device-2: 1-5:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-2: 1-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-6.1:5 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-2: 1-6.2:6 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-3: 1-6.3:7 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0903 class-ID: 0000
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.8 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): cpu: 2400
Processes: 212 Uptime: 16m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1256 lib: 390 flatpak: 0
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.02```
