Nothing happened. with that command…is ti suppose to give an output?
Now it froze when I tried to update the Worldwide mirrors…
[jesuslinux@T-2310 ~]$ pamac checkupdates
Your system is up-to-date.
[jesuslinux@T-2310 ~]$ pacman -Qi pamac
Version : 10.0.5-1
Description : A Package Manager based on libalpm with AUR and Appstream support
Architecture : x86_64
URL : https://gitlab.manjaro.org/applications/pamac
Licenses : GPL3
Groups : None
Provides : pamac=10.0.5-1 pamac-gtk=10.0.5-1
Depends On : pamac-cli=10.0.5-1 gtk3>=3.22
Optional Deps : pamac-gnome-integration
Required By : web-installer-url-handler
Optional For : None
Conflicts With : pamac pamac-aur pamac-gtk-dev
Replaces : pamac
Installed Size : 2,97 MiB
Packager : Helmut Stult <helmut@manjaro.org>
Build Date : dom 07 mar 2021 18:01:52
Install Date : qua 24 mar 2021 13:16:27
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
** (pamac-manager:5172): WARNING **: 23:11:47.938: flatpak_plugin.vala:342: Error updating appstream2: No such ref 'appstream2/x86_64' in remote flathub; Error updating appstream: No such ref 'appstream/x86_64' in remote flathub
