I’ve been trying to install Manjaro KDE Plasma on my PC, but after having a plethora of issues with successfully installed copies (which I may need to come back to later), my install USB now hangs on “Reached target Graphical Interface”.
Specs:
Ryzen 5 2600
GTX 1660 Super
Gigabyte B450 Aorus Elite
I’ve already checked a closely related post where someone had a similar issue, and have already gone through a lot of the steps they were suggested.
The ID of my GPU from lspci -nnkkvt
NVIDIA Corporation TU116 [GeForce GTX 1660 SUPER] [10de:21c4]
For some reason, the output of grep -o "10de" /var/lib/mhwd/ids/pci/nvidia.ids
is blank. After manually scouting the file, there appears to be no value between 103c
and 1180
I have attempted sudo mhwd -f --install pci video-nvidia --pmconfig /opt/mhwd/pacman-mhwd.conf
(-f
as the install complained the drivers were already installed) and the results of the above commands have not changed.
The iso I’m using is manjaro-kde-21.0.7-minimal-210614-linux510
Really hoping the information provided here is of some use! I’ve been tearing my hair out trying to get this thing to work and it’s getting me fed up to the point of throwing my hands up and just installing Win10…
