Hi all,
I’m new to Manjaro passed from Fedora. However I got an issue which is:
https:// ibb. co/ TBmMwTM (I had to put spaces)
How can I solve this problem thanks for your help.
Hello,
Form what i gather you installed gtk3-classic
I did not get what you mean. What should I do?
Describe better what your issue is. From the screenshot i can see:
- duplicate close, maximize, minimize buttons but
- the browser seem like Firefox with the mix of nocsd and csd …
- check whatever custom extension you have started or if you installed the
gtk3-classic
