Greetings to all Manjaro users! I encountered an unpleasant issue with the sound when changing volume. On archlinux PulseAudio/Troubleshooting wiki page:
The first one is to unload module-suspend-on-idle
. Turned out on Manjaro this moudle is unloaded by default anyway according to ~/.config/pulse/default.pa
. So I guess this module is just irrelevant to my problem.
The second recommendation is to load module-udev-detect
like this load-module module-udev-detect tsched=0
, i.e. with timer-based audio scheduling disabled. This is what Fedora wiki recommend as well.
And here comes my main problem. This module is refusing to load with any parameters whatsoever:
$ pulseaudio -L "module-udev-detect"
E: [pulseaudio] module.c: Module "module-udev-detect" should be loaded once at most. Refusing to load.
Same thing goes on the journal every time pulseaudio starts:
$journalctl -f --user-unit pulseaudio.service
pulseaudio: Module "module-udev-detect" should be loaded once at most. Refusing to load
I use …
System: Host: eugene-laptop Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 Desktop: GNOME 3.38.3
Distro: Manjaro Linux
Machine: Type: Laptop System: Acer product: Aspire A315-53G v: V1.21
serial: <superuser required>
Mobo: KBL model: Metapod_KL v: V1.21 serial: <superuser required>
UEFI [Legacy]: Insyde v: 1.21 date: 08/08/2018
CPU: Info: Dual Core model: Intel Core i3-8130U bits: 64 type: MT MCP L2 cache: 4 MiB
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Audio: Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.10.7-3-MANJARO PulseAudio 14.0-1
Has anyone faced this problem before? Is there any known solution? Please let me know.
