Hi,
I had a random freeze like usual so decided to test kernel 6.1
after reboot i immediately realized that my pc connected really fast to wifi, before it takes 2-3 seconds to connect, but now its immediately connected. after that i noticed that every thing works faster than before
also i didnt had random freezes with kernel 6.1 for 3 days
is it really because kernel 6.1 ?!
typical manjaro installation with hibernation and ext4
24 gb ram 25.5gb swap
system disk: ssd nvme 512gb ext4
second disk : hdd 1tb ext4
xorg
stable branch fully updated
not using chromium based browsers
If you have noted a difference after syncing your system to 6.1 then your are correct - I assume you did
sudo pacman -Syu linux61
In that case you have also synced other packages - and then you can make no certain decision if it is the kernel or something else.
I have been using 6.0 and now 6.1 for a while - even custom build 6.0 directly from kernel.org - but I have not experienced any freezes either - so noone knows for a fact unless the kernel is verifiable the only thing synced.
The reason i was scared was because, IIRC, manjaro was dropping support for nVidia cards last time i was using Manjaro.
(But as you’ve noticed i recently came back)
I decided to try anyhow, and what ya know…
I’m now on kernel 6.0 incl. nVidea and broadcom-wl, working good so far (crosses fingers)
I just have a random problem with my wireless port not being activated/recognized, but that is same on normal kernel also since a few days, no idea why but a few reboots fixes it. (might be hardware on motherboard breaking slowly on this machine i think [hope not])
That’s a test for another day, enough excitement for today
