Hello,
I’m using now 21.1.4 : how to upgrade to 21.1.5 ?
Best regards.
You must have your numbers mixed up or are referring to something other than Plasma, which is currently at 5.22.5 from the Manjaro repos.
Manjaro is a rolling release so as long as you keep it updated you will be on the latest version.
If it’s a fresh install and you have not updated yet before…
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
