I need some help.
Linux manjaro 5.9.16-1-MANJARO KDE
I am running Manjaro KDE and after a software update, the system doesn’t boot anymore. I had the same issue before on a different system, and in short, I just reinstalled the OS. I am thinking there must be a better way, I started searching and see my log-file below to understand what the forum was suggesting.
Bottom-line, I can’t boot the system, whatever I do and I am tripping over the “Check your device.map” but i am not seeming to be able to fix it.
Please take a look at my log, is there a different way to check or re-arrange the device.map other than I used (see below)?
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
=== here is full log-file ===
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
==> Detected systems:
--> 0) ManjaroLinux
==> Select system to mount [0-0] :
1
==> Mounting (ManjaroLinux) [/dev/sda4]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
[manjaro /]#
[manjaro /]# pacman -Syy
core 168.3 KiB 468 KiB/s 00:00 [##########################################################] 100%
extra 1921.5 KiB 1046 KiB/s 00:02 [##########################################################] 100%
community 6.6 MiB 794 KiB/s 00:09 [##########################################################] 100%
multilib 179.3 KiB 996 KiB/s 00:00 [##########################################################] 100%
[manjaro /]#
[manjaro /]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=9C10-A0FF /boot/efi vfat umask=0077 0 2
UUID=3e51b486-dbe2-4306-8ea9-b58e55b8cab0 / ext4 defaults,noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
[manjaro /]#
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.9-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.9-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-rt-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-rt-x86_64-fallback.img
It's output will be used to detect bootable binaries on them and create new boot entries.
done
[manjaro /]#
[manjaro /]# mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.41-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux54-rt.preset: 'default'
-> -k /boot/vmlinuz-5.4-rt-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-rt-x86_64.img
==> Starting build: 5.4.115-rt57-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-rt-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54-rt.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-rt-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-rt-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-rt-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.123-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux59-rt.preset: 'default'
-> -k /boot/vmlinuz-5.9-rt-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-rt-x86_64.img
==> Starting build: 5.9.1-1-rt20-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-rt-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux59-rt.preset: 'fallback'
-> -k /boot/vmlinuz-5.9-rt-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-rt-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-rt-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
==> Starting build: 5.9.16-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
[manjaro /]#
[manjaro /]# update-grub
done
[manjaro /]#
