Manjaro KDE : Konsole and some applications which based on KDE display problems
JPEG_20190705_192059|666x500
Like this. Not only konsole has this bug,but krita has it too.
I have tried many solutions, such as renewing my video drivers, using non-free drivers, but it's all useless.
Other applications are normal,such as settings,vscode,vmware and so on.
My computer is GIGABYTE AERO 15 Classic XA ,i7-9750H,NVIDIA GeForce RTX2070 with MAX-Q Design.
Isn't that theme thingy?
Yeah , I have tried all the themes inside in KDE.
I also closed all window effects,but it is useless .
Change your compositor to opengl 3.1 and see if that fixes it.
System Settings -> Display and Monitor -> look on the right and you'll see Rendering Backend, use the drop down and select OpenGL 3.1. -> click Apply.
Thank you for your solution but it is useless either.
Another weird thing is ,when I want to print screen, it will disappear,so only can I use my phone to take a photo.
Output of
inxi -Fxxxz
OUTPUT:
System: Host: DS-10001-RX Kernel: 4.19.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: KDE Plasma 5.16.2
tk: Qt 5.12.4 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: GIGABYTE product: AERO 15 Classic-XA v: N/A serial: Chassis: type: 10 v: y.y
serial:
Mobo: GIGABYTE model: AERO 15 Classic-XA serial: UEFI: American Megatrends v: B02 date: 03/28/2019
Battery: ID-1: BAT1 charge: 66.6 Wh condition: 94.2/94.2 Wh (100%) volts: 16.4/15.2 model: GIGABYTE Aero 15 type: Li-ion
serial: status: Charging
CPU: Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62232
Speed: 1742 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 3124 2: 3057 3: 3689 4: 3134 5: 3428 6: 3378 7: 3365
8: 3256 9: 3170 10: 3436 11: 2896 12: 3093
Graphics: Device-1: Intel UHD Graphics 630 vendor: Gigabyte driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] driver: nvidia v: 430.26 bus ID: 01:00.0 chip ID: 10de:1f10
Display: x11 server: X.Org 1.20.5 driver: intel compositor: kwin_x11 resolution: 1920x1080~240Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2) v: 4.5 Mesa 19.1.1 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA TU106 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:10f9
Device-3: SteelSeries ApS type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-2.2:25 chip ID: 1038:1282
serial:
Sound Server: ALSA v: k4.19.56-1-MANJARO
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] vendor: Bigfoot Networks driver: iwlwifi v: kernel port: 5000
bus ID: 00:14.3 chip ID: 8086:a370
IF: wlo1 state: up mac:
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte driver: alx v: kernel port: 3000
bus ID: 02:00.0 chip ID: 1969:e0b1
IF: enp2s0 state: down mac:
Drives: Local Storage: total: 476.94 GiB used: 51.69 GiB (10.8%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKKW512G8 size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial:
rev: 004C scheme: GPT
Partition: ID-1: / size: 229.70 GiB used: 51.61 GiB (22.5%) fs: ext4 dev: /dev/nvme0n1p6
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A
Info: Processes: 297 Uptime: 3h 39m Memory: 15.52 GiB used: 1.65 GiB (10.7%) Init: systemd v: 242 Compilers: gcc: 9.1.0
alt: 4.9/4.9.3/8 clang: 8.0.0 Shell: bash v: 5.0.7 running in: konsole inxi: 3.0.34
Since its laptop are you using
Optimus manager or optimus switch to use nvidia??
No,I haven't used it before.
Then you are on bumblebee so you won't get to use nvidia to its potential
OK,I have installed the optimus-manager and the problem is solved,
Thank you very much!!
I am sorry to disturb you, but the problem comes back again..
I have reinstalled bumblebee and potimus-manager, and I haven't upgraded the kernel recently.
when I firstly noticed the problem coming again, I have run $ oprirun ,
and it shows:
[ 45.102151] [ERROR]The Bumblebee daemon has not been started yet or th
e socket path /var/run/bumblebee.socket was incorrect.
[ 45.102232] [ERROR]Could not connect to bumblebee daemon - is it running?
Then I reinstalled the software and checked my drivers.
and run $ systemctl enable bumblebeed
and reboot serval times,
but the bug exists anyway!
Recently I renewed my disk partition on Windows and grub has been broken, linux partition has changed its ID, but I fixed it. Is this something related to this thing?
I use the optirun to run Krita,and I recieved this:
If using optimus manager
Install optimus-manager-qt
Disable bumblebee.
I get this as well on my computer.
I think it might be the nvidia driver itself and how it's working with Plasma or how Plasma handles transparency maybe?
I haven't found any kind of fix for it. It wasn't doing it before on my machine with the previous nvidia driver.
I disabled bumblebee and it couldn't poweron now ...... I have reinstalled Manjaro linux.
I know how to solve this problem !
Disable your window zoom setting and all problems dissappeared .
But we can just set the font size to adapt screen.
Glad you found a fix. Unfortunately, it doesn't work for me. :frowning:
I'm pretty convinced it's, in my case, the propietary nonsense from nvidia. I have two systems running the exact same Manjaro KDE. One has nvidia graphics, the other AMD.
Actually, I do have a fix. As soon as the AMD 5700 XTs come out from AIBs with better coolers (Not that stupid blower) I'll get one of those. Problem solved for me. :wink:
