Manjaro KDE keyboard doesn't work correctly
Hey everyone
i am using manjaro kde kernel 5.6.19-2 on my hp probook 450g6 keyboard has brightness control keys and microphone mute key but somehow all of them do the same thing they mute microphone so i can't control my brightness also can't change keyboard shortcuts correctly from settings
hope you can help
Try experimenting with keyboard models. Usually the default, generic one works correct but in some cases you must adjust it manually.
Go to System Settings -> Keyboard -> Keyboard model
I'm not sure if changes will be applied instantly or you need to relogg your session.
