Hi,
I updated via package manager a couple of weeks ago and it updated from 5.8.18-1 to 5.9.11-3. I did a reboot after updating and the OS wouldn’t boot, screen just stayed black.
I realised this morning that there were alternative kernels I could boot from and I managed to boot into 5.8.18-1 without issue. I noticed in package manager that a new kernel update was available, so tried running the update in the hope that it would work. However it’s giving some nvidia package dependency errors. This is the error:
Failed to Prepare Transaction
could not satisfy dependencies:
removing linux58-nvidia-440xx breaks dependency ‘linux58-nvidia-440xx’ required by linux-latest-nvidia-440xx,
if possible, remove linux-latest-nvidia-440xx and retry
Not sure how to proceed?
Thanks All,
Sunny
can you return
inxi -Fza --no-host
sudo mhwd-kernel -li
sudo mhwd -li
sudo ls /etc/mkinitcpio.d/*.preset
sudo ls /usr/lib/modules/
Hi Stephane,
Apologies for taking ages to reply, linux is my secondary boot device and I rarely use it (but will be changing this!)
~ >>> inxi -Fza --no-host
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=efc747a7-09fb-4b17-ab85-6f223719f6ed rw quiet apparmor=1
security=apparmor resume=UUID=c3c9213d-a251-4cf2-b411-9587898ab8f4 udev.log_priority=3
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: ROG ZENITH EXTREME v: Rev 1.xx serial: <filter> UEFI: American Megatrends
v: 2001 date: 07/31/2019
CPU: Info: 8-Core model: AMD Ryzen Threadripper 1950X bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1
stepping: 1 microcode: 8001137 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 128031
Speed: 2200 MHz min/max: 2200/4000 MHz boost: disabled Core speeds (MHz): 1: 2204 2: 2198 3: 2200 4: 2200 5: 2200
6: 2200 7: 3999 8: 2000 9: 2200 10: 2200 11: 2200 12: 2200 13: 3999 14: 2000 15: 2729 16: 2139
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ZOTAC driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm
bus ID: 42:00.0 chip ID: 10de:1b81
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver: nvidia resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 09:00.3 chip ID: 1022:1457
Device-2: NVIDIA GP104 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus ID: 42:00.1
chip ID: 10de:10f0
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: 5.6.0-k port: 1000 bus ID: 03:00.0
chip ID: 8086:1539
Device-2: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion] vendor: ASUSTeK driver: atlantic v: kernel
port: 1000 bus ID: 05:00.0 chip ID: 1d6a:d107
IF: enp5s0 state: down mac: <filter>
Drives: Local Storage: total: 8.12 TiB used: 3.61 TiB (44.4%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 953.87 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: S0118C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 960 EVO 250GB size: 232.89 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 3B7QCXE7 scheme: GPT
ID-3: /dev/sda vendor: Samsung model: SSD 840 EVO 250GB size: 232.89 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: DB6Q scheme: GPT
ID-4: /dev/sdb vendor: Seagate model: ST6000DM003-2CY186 size: 5.46 TiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
ID-5: /dev/sdc vendor: Samsung model: HD401LJ size: 372.61 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s serial: <filter> rev: 0-15 scheme: GPT
ID-6: /dev/sdd vendor: Western Digital model: WD10EAVS-00D7B0 size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1A01 scheme: MBR
Partition: ID-1: / raw size: 53.71 GiB size: 52.62 GiB (97.96%) used: 27.92 GiB (53.1%) fs: ext4 dev: /dev/sda3
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
Sensors: System Temperatures: cpu: 33.4 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
Info: Processes: 414 Uptime: 3m Memory: 31.28 GiB used: 3.85 GiB (12.3%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1430 pacman: 1422 lib: 406 flatpak: 0 snap: 8 Shell: Zsh v: 5.8 running in: terminator inxi: 3.1.08
~ >>> sudo mhwd-kernel -li [1]
[sudo] password for sunil:
Currently running: 5.8.18-1-MANJARO (linux58)
* linux57
* linux58
* linux59
~ >>> sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-440xx 2020.10.04 false PCI
~ >>> sudo ls /etc/mkinitcpio.d/*.preset
/etc/mkinitcpio.d/linux57.preset /etc/mkinitcpio.d/linux58.preset /etc/mkinitcpio.d/linux59.preset
~ >>> sudo ls /usr/lib/modules/
5.7.19-2-MANJARO 5.8.18-1-MANJARO 5.9.11-3-MANJARO extramodules-5.7-MANJARO extramodules-5.8-MANJARO extramodules-5.9-MANJARO
Thanks for your help!!!
Sunny
pobrn
30 January 2021 13:07
4
The 5.7, 5.8, and 5.9 kernels have reached their end-of-life. You should install 5.4 or 5.10, reboot into the newly installed kernel, then remove the end-of-life kernels. After that you should be able to install the NVIDIA drivers with the auto installer.
Ah gotcha. Thanks Probrn.
I cannot ‘update’ via package manager to 5.10, so I guess I need to downgrade. Do you know how I can do that? I’m running 5.8 at the moment
Thanks
S
pobrn
30 January 2021 13:26
6
What do you mean you cannot? sudo mhwd-kernel -i linux510
shows an error?
Actually that command didn’t error (but i don’t get option to install 5.10 from package manager)
Is it safe to chose Y to install this?
~ >>> sudo mhwd-kernel -i linux510 [127]
:: Synchronising package databases...
core 167.6 KiB 3.81 MiB/s 00:00 [####################################################################] 100%
extra 1992.1 KiB 20.3 MiB/s 00:00 [####################################################################] 100%
community 6.4 MiB 25.5 MiB/s 00:00 [####################################################################] 100%
multilib 181.8 KiB 29.6 MiB/s 00:00 [####################################################################] 100%
The following packages are out of date, please update your system first: adobe-source-code-pro-fonts adwaita-maia adwaita-qt alacarte alsa-card-profiles amd-ucode aom apparmor archlinux-appstream-data archlinux-keyring asciidoc atkmm attica audit avahi bash bashrc-manjaro boost-libs brave breeze-icons brotli btrfs-progs ca-certificates-mozilla caffeine-ng cairo cantarell-fonts chrome-gnome-shell cifs-utils confuse cpupower cronie cups-filters curl dhcpcd discord djvulibre duplicity elfutils enchant etcher evolution-data-server faudio ffmpeg fftw firefox flatpak fluidsynth foomatic-db-gutenprint-ppds fprintd fuse-common fuse3 fzf game-devices-udev gcc gcc-libs gcr gdbm gdk-pixbuf2 gdm geany gedit gestures git gjs glade glib2 glibmm glslang gmp gnome-calendar gnome-control-center gnome-desktop gnome-disk-utility gnome-keyring gnome-layout-switcher gnome-maps gnome-session gnome-shell gnome-shell-extension-arcmenu gnome-shell-extension-material-shell gnome-shell-extension-nightthemeswitcher gnome-shell-extension-pop-shell gnome-shell-extension-unite gnome-shell-extensions gnome-terminal gnome-tweaks gnupg gnutls gobject-introspection-runtime gom gpgme gptfdisk grub gssproxy gst-editing-services gst-libav gst-plugin-gtk gst-plugins-bad gst-plugins-bad-libs gst-plugins-base gst-plugins-base-libs gst-plugins-good gst-plugins-ugly gst-python gstreamer gtk-update-icon-cache gtk2 gtk3 gtkmm3 gufw gutenprint gvfs gvfs-afc gvfs-goa gvfs-google gvfs-mtp gvfs-smb harfbuzz harfbuzz-icu highlight hplip htop hwinfo hwloc iana-etc ibus icu imagemagick imlib2 inkscape inxi iproute2 js78 kaccounts-integration karchive kauth kbookmarks kcmutils kcodecs kcompletion kconfig kconfigwidgets kcoreaddons kcrash kdbusaddons kdeclarative kded kdenlive kfilemetadata kglobalaccel kguiaddons ki18n kiconthemes kio kirigami2 kitemmodels kitemviews kjobwidgets kmod knewstuff knotifications knotifyconfig kpackage krita kservice ktextwidgets kvantum-qt5 kwallet kwidgetsaddons kwindowsystem kxmlgui ldb lensfun lib32-cairo lib32-curl lib32-faudio lib32-fluidsynth lib32-gcc-libs lib32-glib2 lib32-gmp lib32-gnutls lib32-gstreamer lib32-harfbuzz lib32-icu lib32-krb5 lib32-libcap lib32-libdrm lib32-libgpg-error lib32-libldap lib32-libpcap lib32-libpulse lib32-libtiff lib32-libtirpc lib32-libusb lib32-libxml2 lib32-llvm-libs lib32-lz4 lib32-mesa lib32-mesa-vdpau lib32-nss lib32-openssl lib32-p11-kit lib32-readline lib32-systemd lib32-vulkan-icd-loader lib32-vulkan-intel lib32-vulkan-radeon lib32-zstd libaccounts-glib libarchive libblockdev libbytesize libcap libcap-ng libcdr libcmis libdrm libe-book libebml libelf libepoxy libevdev libfprint libftdi libgdm libgexiv2 libgpg-error libhandy libheif libibus libical libieee1284 libimobiledevice libinput-gestures libixion libldap liblouis libmagick6 libmfx libmicrohttpd libmm-glib libmpc libmspub libnewt libnm liborcus libp11-kit libpcap libpeas libphonenumber libplist libproxy libpulse libpwquality libqmi libqxp libreoffice-still libseccomp libsynctex libteam libtirpc libtorrent-rasterbar libusb libva libva-mesa-driver libva-vdpau-driver libvisio libvoikko libwacom libx11 libxml2 libxnvctrl libzmf lilv linux-firmware linux-latest linux59 lirc llvm-libs logrotate lollypop lua lz4 man-pages manjaro-alsa manjaro-hello manjaro-pulse manjaro-release manjaro-settings-manager manjaro-settings-manager-notifier manjaro-system manjaro-zsh-config matcha-gtk-theme mbedtls md4c mesa mesa-vdpau meson mhwd-db mhwd-nvidia-390xx mkinitcpio-busybox mlt mobile-broadband-provider-info modemmanager mutter nano nautilus-admin ndctl nerd-fonts-terminus net-snmp netctl nettle networkmanager ninja node-gyp nodejs noto-fonts noto-fonts-cjk npm nss nvtop obs-studio ocl-icd openexr openjpeg2 openresolv openssl opera-ffmpeg-codecs p11-kit p7zip pacman-mirrors pam pamac-cli pamac-common pamac-flatpak-plugin pamac-gnome-integration pamac-gtk pamac-snap-plugin pangomm papirus-icon-theme pcre2 pepper-flash perl-alien-build perl-file-listing perl-http-cookies perl-http-message perl-libwww perl-net-http pipewire poppler poppler-glib poppler-qt5 protobuf psmisc pulseaudio pulseaudio-bluetooth pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-zeroconf purpose python python-appdirs python-asn1crypto python-attrs python-bcrypt python-beaker python-beautifulsoup4 python-cachecontrol python-cachetools python-cairo python-cffi python-chardet python-colorama python-configobj python-contextlib2 python-cryptography python-dbus python-dbus-common python-distlib python-distro python-docopt python-ewmh python-fasteners python-future python-gobject python-google-api-core python-google-api-python-client python-google-auth python-google-auth-httplib2 python-googleapis-common-protos python-html5lib python-httplib2 python-idna python-mako python-markupsafe python-monotonic python-msgpack python-nautilus python-npyscreen python-oauth2client python-ordered-set python-packaging python-paramiko python-pep517 python-pillow python-pip python-ply python-progress python-protobuf python-psutil python-pyasn1 python-pyasn1-modules python-pycparser python-pydrive python-pynacl python-pyopenssl python-pyparsing python-pyqt5 python-pyqt5-sip python-pysmbc python-pytoml python-pytz python-pyxdg python-reportlab python-requests python-resolvelib python-retrying python-rsa python-setproctitle python-setuptools python-six python-soupsieve python-toml python-uritemplate python-urllib3 python-webencodings python-wheel python-xlib python-yaml python2-dbus python2-gobject qgnomeplatform qpdf qt5-base qt5-location qt5-webengine qt5-webkit ranger raptor rav1e re2 readline rsync rygel s-nail sbc sdl2 semver serd shared-mime-info signon-kwallet-extension simple-scan smbclient snapd solid sonnet sord sqlite sratom steam-manjaro sudo suil systemd systemd-libs systemd-sysvcompat talloc tcl tdb tepl terminator tevent tracker tracker-miners tracker3 tracker3-miners ttf-liberation tzdata ueberzug ufw unrar util-linux util-linux-libs volume_key vte-common vte3 vulkan-headers vulkan-icd-loader vulkan-intel vulkan-radeon wavpack webkit2gtk wget wine winetricks wxgtk-common wxgtk3 xapp xcb-proto xf86-video-intel xfsprogs xorg-server xorg-server-common zbar zita-resampler
Do you want to continue anyway? [y/N]
pobrn
30 January 2021 13:29
8
It seems you missed some updates… does sudo pacman -Syu
work?
command runs, should I proceed?
~ >>> sudo pacman -Syu [1]
:: Synchronising package databases…
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Some packages should be upgraded first…
resolving dependencies…
Packages (2) archlinux-keyring-20210110-1 manjaro-system-20210121-1
Total Download Size: 0.95 MiB
Total Installed Size: 1.31 MiB
Net Upgrade Size: 0.01 MiB
I have got a timeshift backup from october 2020 which I could use potentially to roll back to. But I’ve not used timeshift before to rollback a boot drive like that, so not sure if it’s safe to do so. I’m assuming that that was the last time the system was working properly, so upgrading from that point may work
Is it worth a shot?
Looks like it worked but there is a small warnings at the end and it’s asking if I should continue with a full system upgrade, okay to proceed?
-> Disabling key 1A60DC44245D06FEF90623D6EEEEE2EEEE2EEEEE...
-> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
-> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
-> Disabling key 5357F3B111688D88C1D88119FCF2CB179205AC90...
-> Disabling key 4D913AECD81726D9A6C74F0ADA6426DD215B37AD...
-> Disabling key FB871F0131FEA4FB5A9192B4C8880A6406361833...
-> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
-> Disabling key 487EACC08557AD082088DABA1EB2638FF56C0C53...
-> Disabling key B1F2C889CB2CCB2ADA36D963097D629E437520BD...
-> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
-> Disabling key 76B4192E902C0A52642C63C273B8ED52F1D357C1...
-> Disabling key 40776A5221EF5AD468A4906D42A1DB15EC133BAD...
-> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
-> Disabling key 44D4A033AC140143927397D47EFD567D4C7EA887...
==> Updating trust database...
gpg: next trustdb check due at 2021-08-02
(2/2) upgrading manjaro-system [####################################################################] 100%
==> Checking if MHWD is needing an update ...
warning: mhwd-0.6.5-2 is up to date -- reinstalling
resolving dependencies...
Packages (3) mhwd-nvidia-460.32.03-1 mhwd-0.6.5-2 mhwd-db-0.6.5-7
Total Download Size: 0.04 MiB
Total Installed Size: 0.27 MiB
Net Upgrade Size: -0.05 MiB
:: Retrieving packages...
downloading mhwd-nvidia-460.32.03-1-any.pkg.tar.zst...
downloading mhwd-db-0.6.5-7-x86_64.pkg.tar.zst...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing mhwd-nvidia...
upgrading mhwd-db...
reinstalling mhwd...
xorg configuration symlink valid...
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'default'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64.img
==> Starting build: 5.7.19-2-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.7-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'fallback'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.7-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'default'
-> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64.img
==> Starting build: 5.8.18-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'fallback'
-> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
==> Starting build: 5.9.11-3-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
==> Checking if graphic drivers need an update ...
==> Removing EOL kernel 5.7.x
checking dependencies...
Packages (2) linux57-nvidia-440xx-440.100-18 linux57-5.7.19-2
Total Removed Size: 159.76 MiB
:: Do you want to remove these packages? [Y/n]
(1/1) Removing linux initcpios...
removing linux57-nvidia-440xx...
removing linux57...
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.8-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.8-x86_64.img
Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
done
==> Removing EOL kernel 5.8.x
Packages (3) linux-latest-nvidia-440xx-5.8-2 linux58-nvidia-440xx-440.100-27 linux58-5.8.18-1
Total Removed Size: 163.57 MiB
removing linux-latest-nvidia-440xx...
removing linux58-nvidia-440xx...
removing linux58...
done
==> Installing 5.4 LTS kernel
Packages (1) linux54-5.4.89-1
Total Download Size: 82.37 MiB
Total Installed Size: 140.17 MiB
downloading linux54-5.4.89-1-x86_64.pkg.tar.zst...
checking keyring...
installing linux54...
Optional dependencies for linux54
crda: to set the correct wireless channels of your country [installed]
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.89-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
(4/4) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
done
==> Installing 5.10 LTS kernel
Packages (1) linux510-5.10.7-3
Total Download Size: 84.41 MiB
Total Installed Size: 149.60 MiB
downloading linux510-5.10.7-3-x86_64.pkg.tar.zst...
checking keyring...
installing linux510...
Optional dependencies for linux510
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.7-3-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
done
==> Maintaining video driver nvidia-440xx
Packages (4) lib32-nvidia-440xx-utils-440.100-1 mhwd-nvidia-440xx-440.100-1 nvidia-440xx-utils-440.100-1 opencl-nvidia-440xx-440.100-1
Total Removed Size: 416.77 MiB
removing lib32-nvidia-440xx-utils...
removing mhwd-nvidia-440xx...
removing nvidia-440xx-utils...
removing opencl-nvidia-440xx...
(1/3) Reloading system manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Updating the desktop file MIME type cache...
==> Installing Nvidia drivers for you ...
> Using config 'video-nvidia' for device: 0000:42:00.0 (0300:10de:1b81) Display controller nVidia Corporation GP104 [GeForce GTX 1070]
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core is up to date
extra is up to date
Packages (5) lib32-nvidia-utils-460.32.03-1 linux510-nvidia-460.32.03-6 linux54-nvidia-460.32.03-3 linux59-nvidia-460.32.03-1 nvidia-utils-460.32.03-1
Total Download Size: 221.45 MiB
Total Installed Size: 497.52 MiB
downloading nvidia-utils-460.32.03-1-x86_64.pkg.tar.zst...
downloading linux510-nvidia-460.32.03-6-x86_64.pkg.tar.zst...
downloading linux54-nvidia-460.32.03-3-x86_64.pkg.tar.zst...
downloading linux59-nvidia-460.32.03-1-x86_64.pkg.tar.zst...
downloading lib32-nvidia-utils-460.32.03-1-x86_64.pkg.tar.zst...
checking keyring...
installing nvidia-utils...
==> If you run into trouble with CUDA not being available, run nvidia-modprobe first.
Optional dependencies for nvidia-utils
gtk3: nvidia-settings [installed]
xorg-server-devel: nvidia-xconfig
opencl-nvidia: OpenCL support
installing lib32-nvidia-utils...
Optional dependencies for lib32-nvidia-utils
lib32-opencl-nvidia
installing linux510-nvidia...
In order to use nvidia module, reboot the system.
installing linux54-nvidia...
installing linux59-nvidia...
(1/6) Creating system user accounts...
(2/6) Reloading system manager configuration...
(3/6) Arming ConditionNeedsUpdate...
(4/6) Updating module dependencies...
(5/6) Updating Kernel initcpios for Nvidia-DRM...
(6/6) Updating the desktop file MIME type cache...
nvidia-utils: install reason has been set to 'explicitly installed'
lib32-nvidia-utils: install reason has been set to 'explicitly installed'
linux510-nvidia: install reason has been set to 'explicitly installed'
linux54-nvidia: install reason has been set to 'explicitly installed'
linux59-nvidia: install reason has been set to 'explicitly installed'
xorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
> Successfully installed video-nvidia
Warning: No device of class 0302 found!
Warning: No device of class 0380 found!
(1/1) Arming ConditionNeedsUpdate...
:: Replace mhwd-nvidia-418xx with core/mhwd-nvidia? [Y/n]
FYI I went ahead with the upgrade as you said, it’s worked perfectly…
Thanks for your help Pobrn…
system
Closed
14 February 2021 14:56
14
