Manjaro KDE encrypted LVM install
installation
#1
I need help with Manjaro installation with encrypted LVM.
In installer I can’t find any option to configure logical group and volumes.
I’ve also tryed to configure partitions manualy from terminal, and setup boot partition, encrypted LVM and inside I’ve created LV swap, root, home. After that I started installer and get to the point po partition, and I have only option ‘manual install’ but I can’t continue instalation because it can’t see LVM volumes.
Where I’m wrong.
Thank you in advance.
Manjaro v17.1-rc2 feedback thread
#2
Calamares doesn’t yet support LVM. See also here:
#3
Thank you for fast reply.
Is there any other way to install encrypted Manjaro aside Windows on the same drive?
#4
That would work with Manjaro-Architect.
#5
