Hello, fellow linux users.
I had been plagued for a looooong time by an annoying bug of system-not-shutting-down-properly when told to do so in the KDE interface. It happens sometimes, not always and I can’t really get why that happens. I had read other forum posts about this topic and I think that my case is a bit different.
Couple of points: I use xorg-server-bug865 package from aur, which is basically an identical xorg-server, but with one library patched. I suspected that it may be the offender in this case, but I had this bug in non-patched xorg-server on a newly installed system recently, so the trouble is not there I assume.
Usually the behaviour is such that I click on a start menu button and click “shut down”, then it presents a menu with shut down, restart, etc. options and a countdown, I press Enter and basically roll the dice on what will happen next. Sometimes it just shuts down normally, but other times it returns to the KDE desktop and just stalls somewhat. I can move my cursor, but I can’t click on anything. I can bring up the start menu by pressing the windows key on a keyboard, but nothing more, it seems. If left unattended, the PC would just stay in this state for hours - monitors glaring and everything. Usually I just switch to a next terminal session and systemctl poweroff the thing - that works. Caveat: this problem is not limited to shutting down - reboot or something else may be failed too in such a manner.
I have no dmesg, because I forget about it last time, but in all cases journalctl shows nothing of value. Xorg.log is not much of a help, either, to me at least.
I hope that you - more bright and knowledgeable people can guide me through this annoying problem. Thanks!
inxi, journalctl and xorg.log included
~ inxi --full --verbosity=7 --filter --no-host
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B85M-D3H v: x.x
serial: <superuser required> UEFI: American Megatrends v: F12
date: 05/02/2014
RAM: total: 15.57 GiB used: 4.07 GiB (26.1%)
RAM Report:
Info: quad core model: Intel Core i5-4430 bits: 64 type: MCP
smt: <unsupported> arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB
L3: 6 MiB
Speed (MHz): avg: 2315 high: 2868 min/max: 800/3200 cores: 1: 2628
2: 1253 3: 2868 4: 2514 bogomips: 23957
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: ASUSTeK
driver: amdgpu v: kernel pcie: speed: 8 GT/s lanes: 16 ports:
active: DP-1,DP-2 empty: DVI-D-1,HDMI-A-1,HDMI-A-2 bus-ID: 03:00.0
chip-ID: 1002:687f class-ID: 0300
Device-2: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-10:5 chip-ID: 046d:082b class-ID: 0102
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 952x285mm (37.48x11.22")
s-diag: 994mm (39.12")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: AOC 2590G4
serial: <filter> res: 1920x1080 dpi: 90 size: 544x303mm (21.42x11.93")
diag: 623mm (24.5") modes: max: 1920x1080 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: Acer V203W
serial: <filter> res: 1680x1050 hz: 60 dpi: 90
size: 474x296mm (18.66x11.65") diag: 508mm (20") modes: max: 1680x1050
min: 720x400
OpenGL: renderer: AMD Radeon RX Vega (VEGA10 DRM 3.42.0 5.15.32-1-MANJARO
LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:aaf8
class-ID: 0403
Device-3: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo
Device-4: Samson Meteor condenser microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-9:4 chip-ID: 17a0:0310
class-ID: 0300
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Gigabyte driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: luks-018b4010-295e-4a0c-adde-d5f0e5f4e818 type: LUKS dm: dm-1
Components: p-1: sda5
Device-2: luks-759e4834-4e1b-40c4-a226-cd461e14b565 type: LUKS dm: dm-0
Components: p-1: sda7
Local Storage: total: 3.64 TiB used: 1.96 TiB (53.8%)
ID-1: /dev/sda vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 043 scheme: GPT
ID-2: /dev/sdb vendor: Toshiba model: HDWD110 size: 931.51 GiB
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A8R0 scheme: GPT
ID-3: /dev/sdc vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC47 scheme: MBR
ID-1: / size: 1.19 TiB used: 131.29 GiB (10.8%) fs: ext4 dev: /dev/dm-0
mapped: luks-759e4834-4e1b-40c4-a226-cd461e14b565 label: linux
uuid: 4c2d6f15-f360-4815-aa8c-c64af410b7c9
ID-2: /boot/efi size: 499 MiB used: 440 KiB (0.1%) fs: vfat
dev: /dev/sda6 label: N/A uuid: 2E50-3F82
ID-3: /mnt/Backup size: 931.51 GiB used: 884.51 GiB (95.0%) fs: ntfs
dev: /dev/sdb1 label: Backup n Stuff uuid: 7153514F47912B69
ID-4: /mnt/Data size: 931.51 GiB used: 903.8 GiB (97.0%) fs: ntfs
dev: /dev/sdc2 label: Data uuid: D634548034546591
ID-5: /run/media/george/90CE9502CE94E1B0 size: 599.39 GiB
used: 85.96 GiB (14.3%) fs: ntfs dev: /dev/sda3 label: N/A
uuid: 90CE9502CE94E1B0
ID-1: swap-1 type: partition size: 24 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 mapped: luks-018b4010-295e-4a0c-adde-d5f0e5f4e818
label: swap uuid: 5b73309b-7b80-42e4-9517-75a2bf2a202a
ID-1: /dev/sda1 size: 100 MiB fs: vfat label: N/A uuid: 228D-0452
ID-2: /dev/sda2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-3: /dev/sda4 size: 509 MiB fs: ntfs label: N/A uuid: 46CE1A1FCE1A0837
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-7:2 info: Logitech Corded Keyboard K280e type: Keyboard,HID
power: 98mA chip-ID: 046d:c328 class-ID: 0300
Device-2: 3-8:3 info: Logitech G502 Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c07d class-ID: 0300 serial: <filter>
Device-3: 3-9:4 info: Samson Meteor condenser microphone type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 17a0:0310 class-ID: 0300
Device-4: 3-10:5 info: Logitech Webcam C170 type: Video,Audio
power: 500mA chip-ID: 046d:082b class-ID: 0102
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 53.0 C
mem: 53.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1
Processes: 281 Uptime: 31m wakeups: 0 Init: systemd v: 250 Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1373 pacman: 1356 flatpak: 17
Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
Journal shows a billion firefox crashes
journalctl -p3 -b -1
may 06 06:22:39 george-lpc kernel: ntfs3: Unknown parameter 'windows_names'
may 06 01:23:06 george-lpc pulseaudio[809]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
may 06 01:25:03 george-lpc systemd-coredump[3254]: [🡕] Process 3160 (RDD Process) of user 1000 dumped core.
Module /usr/lib/firefox/liblgpllibs.so with build-id 4114a1b1ad0f0df815b307b1dfab23942eaca488
Module linux-vdso.so.1 with build-id 8106bf494dae10daeabb297533ca613cae822188
Module libncursesw.so.6 with build-id 1f873ddb2c32ab39d0b7d8646d03680ffe99de7c
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libxcb-dri2.so.0 with build-id 2dd6e65129a809dab828a1d26215a3f7a363fcc8
Module libdrm_nouveau.so.2 with build-id af8afb2331ac08c52132102ecbdc6076a8eb4c6f
Module libdrm_amdgpu.so.1 with build-id 8eb3977b830f3012d9ead7b4def5f4d2f38ec688
Module libelf.so.1 with build-id 4cf96cb4785e1ca233693ae17fa0d62971ee09c2
Module libdrm_radeon.so.1 with build-id 43e0aecc70c4ce905ba35c948e1c9a5d999b14c0
Module libLLVM-13.so with build-id 76d1fe97dbdca6d6891c6a1a7c06a388aa247154
Module libxcb-dri3.so.0 with build-id 9407a2480e09dc5a1dd9d9a0652fa8d32b328c91
Module libxcb-xfixes.so.0 with build-id a6b197ace5b9b59f913f5969eb419a88d1194f47
Module libxshmfence.so.1 with build-id 8876d9ccf620858795724ca24b9e567585a77cec
Module libxcb-present.so.0 with build-id 68f5465258750e2397b1333b3ffc01ee33caa4e1
Module libxcb-sync.so.1 with build-id dda14591103b01b1311906053bf1ca9e82ade35c
Module radeonsi_drv_video.so with build-id 8b3f7e0fd528030ac4dda64a734bb83411188aa4
Module libgomp.so.1 with build-id 75d4bedf51d8d7bc41d78a1189d780a82c8ebaaf
Module libmvec.so.1 with build-id 760a099552c4783b979e942bf839c2bbc5ff603d
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
Module libva-x11.so.2 with build-id 61e734cd9bd8265d76a73698e94b891539801ec1
Module libsoxr.so.0 with build-id 9e49936ed807c1e52705b88d5d71706fe11d9ed1
Module libmfx.so.1 with build-id d5b3fccbc5270caa7074598c8f108a2b3f5681e7
Module libxvidcore.so.4 with build-id 43bc390a7842a7ca3a0302e93442ea561d7f013a
Module libx265.so.199 with build-id 4fd2d7155725df753c6b32274c442349fc05e632
Module libx264.so.164 with build-id 1ebb8708f2101bd1c95b701142163133e8dac465
Module libvorbisenc.so.2 with build-id 2b1ce7fcdcc925bc663ebe2c1c008c0dd96e5bd0
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libtheoradec.so.1 with build-id 19d321fd5455c7b7611ca9602a804b496124e06f
Module libtheoraenc.so.1 with build-id cde750f0621140f313e4ef4e5f212e662f24a38b
Module libSvtAv1Enc.so.0 with build-id e9143f88be53d2aebfa4f9249295869f09e22be4
Module libspeex.so.1 with build-id 39721dbe21b62978562c2943279f6dffbffe8946
Module librav1e.so.0 with build-id 5f8fc2c271f0d96480ab1c71447e038a66aa1c57
Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
Module libopenjp2.so.7 with build-id 0a329c12468c33c92ecbc3968f4dc9c79cc5db96
Module libopencore-amrnb.so.0 with build-id a3d78948c85fa235e66549119b2f130e69af7b70
Module libmp3lame.so.0 with build-id 48c901805551a3dd58d02502c4cd67f6aa848107
Module libgsm.so.1 with build-id 1cc6240f7eaedaaac302bc7c0f64ebbeae596f22
Module libaom.so.3 with build-id 3c057fe8c5fa7033366274352148acb4dbb42728
Module librsvg-2.so.2 with build-id c86713d419ff747afe6cac4b276bfacdc80af2ad
Module libopencore-amrwb.so.0 with build-id 28da8ed3dfca59280e835c46bd40da295dae99e2
Module libdav1d.so.5 with build-id 82862181dbe48302fde94240f68e17fb6f9a03c7
Module libwebp.so.7 with build-id 0add7a572705244ed810b7e722cce7da0dcfb62c
Module libwebpmux.so.3 with build-id 4232d5263a45719ba12f58ed7d8cae3a0fc887de
Module libvpx.so.7 with build-id 347ca2580a23a6da7347be245c72585415bfa8e2
Module libavutil.so.57 with build-id 5ead4c7d60a6063d382d23a53e253c879dd4d3c0
Module libswresample.so.4 with build-id 4d48618e2741ffb88409e04795797c773a2fa8b8
Module libavcodec.so.59 with build-id 8f59ceada81ac689f4a84ca636ff815b7f703e84
Module libmozavcodec.so with build-id da93525aa2eb233373af95f56fbc64eb212b114c
Module libmozavutil.so with build-id ba80d12ec9d701c71d3d5baa33af4bb670223d6d
Module libdrm.so.2 with build-id 00816f0a71c7e4e388c10db6245dbb9c031732a9
Module libva.so.2 with build-id 7636f0d16fc8cb315f9274e487bd226d1236891e
Module libva-drm.so.2 with build-id 7a02a127b38763e2ec9a2503f0ae4c3d57c20327
Module libplds4.so with build-id e915f74a1aff6a20d65b5f03f5ee2e0197153a33
Module libX11-xcb.so.1 with build-id f6beacd41cd16a23f53e5e56bb599e98f039d0d6
Module libdbus-glib-1.so.2 with build-id 9b483ffff76251ff057e007a0b960bff84ce34a8
Module libnssutil3.so with build-id 06a43c3ce2b400d69516e9bd009f491b6f098051
Module libnss3.so with build-id 34dd7da87e41dc61c77e01bae89e68466b8c2eea
Module libsmime3.so with build-id 81f7eb3b22510320a46a692316102976b2447e46
Module libssl3.so with build-id 1f070c8bf378386c9dd0a9805060990bf356f8be
Module libplc4.so with build-id 44dcd42fb72cc8aab586dbf4000293590bb19e67
Module libasound.so.2 with build-id b17fc1317a484842433c772360376623b64ec3d8
Module libxul.so with build-id 656c10f2b956dbbadb74161ff84aafd2fdd73614
Module libmozwayland.so with build-id ea81497dbf04ac0810f0a7e1ea7421c2784bfe62
Module libgpg-error.so.0 with build-id 82524ee3d1c4c2244d7cfdcc1e6eea5f9855f6c6
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id eb6dae97527fc89dbb0d5bb581a15acd02ae9f56
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
Module libsystemd.so.0 with build-id 05d0460efefd339d315812f9506aecc5a5d22200
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libzstd.so.1 with build-id 3bccb8fe08e48d5ea135b1d0f99de0d771dd752f
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libxml2.so.2 with build-id 34aa03d6fadb52a051964f0e50a977efaea9482e
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libsqlite3.so.0 with build-id ba4ef02cdb2e6057b4cb91b6de42c1fdb26d6776
Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libatspi.so.0 with build-id 51e18f1bebc8220a742aea6b26c6016aa2bfbb01
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libtiff.so.5 with build-id 9e8868622f8b7144fd82dabfa8ac2fcaf6d45a34
Module libjpeg.so.8 with build-id 324d9d66f01707241e31af5cc104db3c9122f4c4
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libfreetype.so.6 with build-id 2c4fc9c3e3c6324e6a495e760c2b9b62559d695c
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libz.so.1 with build-id 1fb800ce60ddb605ebe23f9702adcd341c7c8970
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libwayland-egl.so.1 with build-id ac45e227422559ff92c4d04851fffb8452874713
Module libwayland-cursor.so.0 with build-id 647d92328111682fb15bff1c20a4c9368414857c
Module libwayland-client.so.0 with build-id 95e7368b400dd57e3db2a5c385de71c7dca08879
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id b4e5b8fe466888a3125965bc20cd6741700f9b85
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libX11.so.6 with build-id 1bf9c2f1c9e2f823a1200b41ffa6b09943edf886
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
Module libcairo-gobject.so.2 with build-id 44a907a31fa6d2b6d359280ccfe70e50900d8eee
Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b781114
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpangoft2-1.0.so.0 with build-id 5ade8d7816bfbda4884f726246bbc1e7050c48df
Module libcairo.so.2 with build-id 254ac8421ae2a823be8ff4eaa219fd220b015bba
Module libharfbuzz.so.0 with build-id ac8220c9649822c84097ad58e80b97a86f3b4f7f
Module libpango-1.0.so.0 with build-id 068b92fa9ba77ac899fd10b29779c07a20c279ed
Module libpangocairo-1.0.so.0 with build-id 427c905657c2d8a521066b507b4fe2e69df4ba32
Module libgio-2.0.so.0 with build-id 3f16bee59e25c8bfbb70c4e78a3c90ee79ba4469
Module libgobject-2.0.so.0 with build-id f5126c30685462884948f1048f2039305c67f5c5
Module libglib-2.0.so.0 with build-id d6c7c03d71a1b71f59e10016323136de55f43266
Module libgmodule-2.0.so.0 with build-id 5d0db204364cefb16d6d80f9e40df7c3d86023b3
Module libgdk-3.so.0 with build-id deb8ef1b4d664de56af9e42ca1e49ae872f6461b
Module libgtk-3.so.0 with build-id b4b2e4bf4fd977314b8d6b529ea498d5a0725d0a
Module libmozgtk.so with build-id a6a30f9a046abfb2d5cc98b1134fa8dc04b89af3
Module libmozsqlite3.so with build-id 6d6ad397b3adf74c36fc16e55415c3e19e6a4160
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libnspr4.so with build-id c5d12234f7975d11a11e67646533657d014d9540
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libstdc++.so.6 with build-id 88ad4eff81a00c684abfe0f863e87434123d8943
Module libmozsandbox.so with build-id 37fb1ee4b53858b73e9ab2c8cf4d5d7e1a3c89c2
Module firefox with build-id 2d70b73e285313aa524895983094d1d059357327
Stack trace of thread 3240:
#0 0x00007f02a7b4699d __nss_lookup (libc.so.6 + 0x13c99d)
#1 0x00007f02a7ae6dc5 getpwuid_r@@GLIBC_2.2.5 (libc.so.6 + 0xdcdc5)
#2 0x00007f028ab1566e n/a (radeonsi_drv_video.so + 0x59866e)
#3 0x00007f028a8c5b90 n/a (radeonsi_drv_video.so + 0x348b90)
#4 0x00007f028a8cce2b n/a (radeonsi_drv_video.so + 0x34fe2b)
#5 0x00007f028a95f0d7 amdgpu_winsys_create (radeonsi_drv_video.so + 0x3e20d7)
#6 0x00007f028a6fbcb3 n/a (radeonsi_drv_video.so + 0x17ecb3)
#7 0x00007f028a7bb3d5 n/a (radeonsi_drv_video.so + 0x23e3d5)
#8 0x00007f028a6f9564 __vaDriverInit_1_13 (radeonsi_drv_video.so + 0x17c564)
#9 0x00007f0298e74c9f n/a (libva.so.2 + 0x3c9f)
#10 0x00007f0298e7a8ba vaInitialize (libva.so.2 + 0x98ba)
#11 0x00007f029fe3822b n/a (libxul.so + 0x6be822b)
#12 0x00007f029fe385fb n/a (libxul.so + 0x6be85fb)
#13 0x00007f029fe3987a n/a (libxul.so + 0x6be987a)
#14 0x00007f029e375ba2 n/a (libxul.so + 0x5125ba2)
#15 0x00007f029dd1e819 n/a (libxul.so + 0x4ace819)
#16 0x00007f029d474f07 n/a (libxul.so + 0x4224f07)
#17 0x00007f029cfdffb5 n/a (libxul.so + 0x3d8ffb5)
#18 0x00007f029d7727ee n/a (libxul.so + 0x45227ee)
#19 0x00007f029de7d3a1 n/a (libxul.so + 0x4c2d3a1)
#20 0x00007f029de7ce1f n/a (libxul.so + 0x4c2ce1f)
#21 0x00007f02a79f2008 n/a (libnspr4.so + 0x2b008)
#22 0x0000561a7b52a1a0 _Z30set_alt_signal_stack_and_startP19PthreadCreateParams (firefox + 0x671a0)
#23 0x00007f02a7a975c2 start_thread (libc.so.6 + 0x8d5c2)
#24 0x00007f02a7b1c584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 3194:
#0 0x00007f02a7a9415a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007f02a7a96960 pthread_cond_wait@@GLIBC_2.3.2 (libc.so.6 + 0x8c960)
#2 0x0000561a7b5579ee _ZN7mozilla6detail21ConditionVariableImpl4waitERNS0_9MutexImplE (firefox + 0x949ee)
#3 0x00007f029cfdf689 n/a (libxul.so + 0x3d8f689)
#4 0x00007f029d7728ba n/a (libxul.so + 0x45228ba)
#5 0x00007f029de7d3a1 n/a (libxul.so + 0x4c2d3a1)
#6 0x00007f029de7ce1f n/a (libxul.so + 0x4c2ce1f)
#7 0x00007f02a79f2008 n/a (libnspr4.so + 0x2b008)
#8 0x0000561a7b52a1a0 _Z30set_alt_signal_stack_and_startP19PthreadCreateParams (firefox + 0x671a0)
#9 0x00007f02a7a975c2 start_thread (libc.so.6 + 0x8d5c2)
#10 0x00007f02a7b1c584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 3160:
#0 0x00007f02a7b102af __poll (libc.so.6 + 0x1062af)
#1 0x00007f02a03251ff n/a (libxul.so + 0x70d51ff)
#2 0x00007f02a6488976 n/a (libglib-2.0.so.0 + 0xab976)
#3 0x00007f02a642f6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#4 0x00007f029cfdf1df n/a (libxul.so + 0x3d8f1df)
#5 0x00007f029cfde25e n/a (libxul.so + 0x3d8e25e)
#6 0x00007f029de7d3a1 n/a (libxul.so + 0x4c2d3a1)
#7 0x00007f02a02d837d n/a (libxul.so + 0x708837d)
#8 0x00007f029cfddf05 n/a (libxul.so + 0x3d8df05)
#9 0x00007f029de7d3a1 n/a (libxul.so + 0x4c2d3a1)
#10 0x00007f029e2622c6 n/a (libxul.so + 0x50122c6)
#11 0x0000561a7b51dd15 n/a (firefox + 0x5ad15)
#12 0x00007f02a7a37310 __libc_start_call_main (libc.so.6 + 0x2d310)
#13 0x00007f02a7a373c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#14 0x0000561a7b56dec5 _start (firefox + 0xaaec5)
Stack trace of thread 3187:
#0 0x00007f02a7b15a9d syscall (libc.so.6 + 0x10ba9d)
#1 0x00007f029d463043 n/a (libxul.so + 0x4213043)
#2 0x00007f029d462309 n/a (libxul.so + 0x4212309)
#3 0x00007f029de7d3a1 n/a (libxul.so + 0x4c2d3a1)
#4 0x00007f029e473359 n/a (libxul.so + 0x5223359)
#5 0x00007f02a22bbc5e n/a (libxul.so + 0x906bc5e)
#6 0x0000561a7b52a1a0 _Z30set_alt_signal_stack_and_startP19PthreadCreateParams (firefox + 0x671a0)
#7 0x00007f02a7a975c2 start_thread (libc.so.6 + 0x8d5c2)
#8 0x00007f02a7b1c584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 3195:
#1 0x00007f02a7a96c64 pthread_cond_timedwait@@GLIBC_2.3.2 (libc.so.6 + 0x8cc64)
#2 0x0000561a7b557b2f _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (>
#3 0x00007f029d474d74 n/a (libxul.so + 0x4224d74)
#4 0x00007f029cfdffb5 n/a (libxul.so + 0x3d8ffb5)
#5 0x00007f029d7727ee n/a (libxul.so + 0x45227ee)
#7 0x00007f029de7ce1f n/a (libxul.so + 0x4c2ce1f)
#8 0x00007f02a79f2008 n/a (libnspr4.so + 0x2b008)
#9 0x0000561a7b52a1a0 _Z30set_alt_signal_stack_and_startP19PthreadCreateParams (firefox + 0x671a0)
#10 0x00007f02a7a975c2 start_thread (libc.so.6 + 0x8d5c2)
#11 0x00007f02a7b1c584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 3242:
#2 0x00007f028ab0e5fc n/a (radeonsi_drv_video.so + 0x5915fc)
#3 0x00007f028ab0dd7c n/a (radeonsi_drv_video.so + 0x590d7c)
#4 0x0000561a7b52a1a0 _Z30set_alt_signal_stack_and_startP19PthreadCreateParams (firefox + 0x671a0)
#5 0x00007f02a7a975c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f02a7b1c584 __clone (libc.so.6 + 0x112584)
may 06 10:53:17 george-lpc systemd-coredump[40081]: Failed to connect to coredump service: Connection refused
may 06 10:53:17 george-lpc systemd-coredump[40095]: Failed to connect to coredump service: Connection refused
may 06 10:53:17 george-lpc systemd-cryptsetup[40243]: Device luks-759e4834-4e1b-40c4-a226-cd461e14b565 is still in use.
may 06 10:53:17 george-lpc systemd-cryptsetup[40243]: Failed to deactivate: Device or resource busy
The tail of journalctl -b -1 shows that it just sits on it’s ass from 04:36 to 10:53 without any suspicion that it needs to poweroff. At 10:53 I log into another terminal session.
journalctl -b -1
may 06 04:36:09 george-lpc dbus-daemon[681]: [session uid=1000 pid=681] Activating service name='org.kde.LogoutPrompt' requested by ':1.17' (uid=1000 pid=778 comm="/usr/bin/plasmashell")
may 06 04:36:09 george-lpc dbus-daemon[681]: [session uid=1000 pid=681] Successfully activated service 'org.kde.LogoutPrompt'
may 06 04:36:12 george-lpc dbus-daemon[681]: [session uid=1000 pid=681] Activating service name='org.kde.Shutdown' requested by ':1.413' (uid=1000 pid=35081 comm="/usr/lib/ksmserver-logout-greeter")
may 06 04:36:12 george-lpc dbus-daemon[681]: [session uid=1000 pid=681] Successfully activated service 'org.kde.Shutdown'
may 06 04:36:12 george-lpc kwin_x11[733]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41829, resource id: 132120638, major code: 18 (ChangeProperty), minor code: 0
may 06 04:45:42 george-lpc kdeconnectd[792]: kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
may 06 04:45:42 george-lpc kdeconnectd[792]: kdeconnect.plugin.battery: Total quantity of batteries found: 0
may 06 05:01:01 george-lpc CROND[35395]: (root) CMD (run-parts /etc/cron.hourly)
may 06 05:01:01 george-lpc CROND[35394]: (root) CMDEND (run-parts /etc/cron.hourly)
may 06 05:16:06 george-lpc plasmashell[778]: libkcups: Renew-Subscription last error: 0 successful-ok
may 06 05:22:43 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.685' (uid=1000 pid=35679 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
may 06 05:22:43 george-lpc kernel: kauditd_printk_skb: 10 callbacks suppressed
may 06 05:22:43 george-lpc kernel: audit: type=1334 audit(1651796563.776:800): prog-id=253 op=LOAD
may 06 05:22:43 george-lpc kernel: audit: type=1334 audit(1651796563.776:801): prog-id=254 op=LOAD
may 06 05:22:43 george-lpc kernel: audit: type=1334 audit(1651796563.776:802): prog-id=255 op=LOAD
may 06 05:22:43 george-lpc audit: BPF prog-id=253 op=LOAD
may 06 05:22:43 george-lpc audit: BPF prog-id=254 op=LOAD
may 06 05:22:43 george-lpc audit: BPF prog-id=255 op=LOAD
may 06 05:22:43 george-lpc systemd[1]: Starting Locale Service...
may 06 05:22:43 george-lpc dbus-daemon[473]: [system] Successfully activated service 'org.freedesktop.locale1'
may 06 05:22:43 george-lpc systemd[1]: Started Locale Service.
may 06 05:22:43 george-lpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 05:22:43 george-lpc kernel: audit: type=1130 audit(1651796563.819:803): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 05:23:13 george-lpc systemd[1]: systemd-localed.service: Deactivated successfully.
may 06 05:23:13 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 05:23:13 george-lpc kernel: audit: type=1131 audit(1651796593.843:804): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 05:23:13 george-lpc audit: BPF prog-id=0 op=UNLOAD
may 06 05:23:13 george-lpc kernel: audit: type=1334 audit(1651796593.929:805): prog-id=0 op=UNLOAD
may 06 05:23:13 george-lpc kernel: audit: type=1334 audit(1651796593.929:806): prog-id=0 op=UNLOAD
may 06 05:23:13 george-lpc kernel: audit: type=1334 audit(1651796593.929:807): prog-id=0 op=UNLOAD
may 06 05:32:22 george-lpc rtkit-daemon[817]: Supervising 12 threads of 5 processes of 1 users.
may 06 05:56:59 george-lpc kernel: perf: interrupt took too long (3938 > 3927), lowering kernel.perf_event_max_sample_rate to 50700
may 06 06:01:01 george-lpc CROND[36198]: (root) CMD (run-parts /etc/cron.hourly)
may 06 06:01:01 george-lpc CROND[36197]: (root) CMDEND (run-parts /etc/cron.hourly)
may 06 06:12:50 george-lpc plasmashell[778]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
may 06 06:12:50 george-lpc plasmashell[778]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
may 06 06:12:50 george-lpc plasmashell[778]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:37:27: QML ScrollBar: Binding loop detected for property "visible"
may 06 06:12:50 george-lpc plasmashell[778]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
may 06 06:14:26 george-lpc plasmashell[778]: libkcups: Renew-Subscription last error: 0 successful-ok
may 06 06:22:43 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.690' (uid=1000 pid=36493 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
may 06 06:22:43 george-lpc kernel: audit: type=1334 audit(1651800163.750:808): prog-id=256 op=LOAD
may 06 06:22:43 george-lpc kernel: audit: type=1334 audit(1651800163.750:809): prog-id=257 op=LOAD
may 06 06:22:43 george-lpc kernel: audit: type=1334 audit(1651800163.750:810): prog-id=258 op=LOAD
may 06 06:22:43 george-lpc audit: BPF prog-id=256 op=LOAD
may 06 06:22:43 george-lpc audit: BPF prog-id=257 op=LOAD
may 06 06:22:43 george-lpc audit: BPF prog-id=258 op=LOAD
may 06 06:22:43 george-lpc systemd[1]: Starting Locale Service...
may 06 06:22:43 george-lpc dbus-daemon[473]: [system] Successfully activated service 'org.freedesktop.locale1'
may 06 06:22:43 george-lpc systemd[1]: Started Locale Service.
may 06 06:22:43 george-lpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 06:22:43 george-lpc kernel: audit: type=1130 audit(1651800163.793:811): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 06:23:13 george-lpc systemd[1]: systemd-localed.service: Deactivated successfully.
may 06 06:23:13 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 06:23:13 george-lpc kernel: audit: type=1131 audit(1651800193.830:812): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 06:23:13 george-lpc audit: BPF prog-id=0 op=UNLOAD
may 06 06:23:13 george-lpc kernel: audit: type=1334 audit(1651800193.927:813): prog-id=0 op=UNLOAD
may 06 06:23:13 george-lpc kernel: audit: type=1334 audit(1651800193.927:814): prog-id=0 op=UNLOAD
may 06 06:23:13 george-lpc kernel: audit: type=1334 audit(1651800193.927:815): prog-id=0 op=UNLOAD
may 06 06:32:23 george-lpc rtkit-daemon[817]: Supervising 12 threads of 5 processes of 1 users.
may 06 06:59:51 george-lpc kdeconnectd[792]: kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
may 06 06:59:51 george-lpc kdeconnectd[792]: kdeconnect.plugin.battery: Total quantity of batteries found: 0
may 06 07:01:01 george-lpc CROND[36986]: (root) CMD (run-parts /etc/cron.hourly)
may 06 07:01:01 george-lpc CROND[36985]: (root) CMDEND (run-parts /etc/cron.hourly)
may 06 07:12:46 george-lpc plasmashell[778]: libkcups: Renew-Subscription last error: 0 successful-ok
may 06 07:22:44 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.695' (uid=1000 pid=37235 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
may 06 07:22:44 george-lpc audit: BPF prog-id=259 op=LOAD
may 06 07:22:44 george-lpc audit: BPF prog-id=260 op=LOAD
may 06 07:22:44 george-lpc audit: BPF prog-id=261 op=LOAD
may 06 07:22:44 george-lpc systemd[1]: Starting Locale Service...
may 06 07:22:44 george-lpc kernel: audit: type=1334 audit(1651803764.049:816): prog-id=259 op=LOAD
may 06 07:22:44 george-lpc kernel: audit: type=1334 audit(1651803764.049:817): prog-id=260 op=LOAD
may 06 07:22:44 george-lpc kernel: audit: type=1334 audit(1651803764.049:818): prog-id=261 op=LOAD
may 06 07:22:44 george-lpc dbus-daemon[473]: [system] Successfully activated service 'org.freedesktop.locale1'
may 06 07:22:44 george-lpc systemd[1]: Started Locale Service.
may 06 07:22:44 george-lpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 07:22:44 george-lpc kernel: audit: type=1130 audit(1651803764.092:819): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 07:23:14 george-lpc systemd[1]: systemd-localed.service: Deactivated successfully.
may 06 07:23:14 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 07:23:14 george-lpc kernel: audit: type=1131 audit(1651803794.126:820): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 07:23:14 george-lpc audit: BPF prog-id=0 op=UNLOAD
may 06 07:23:14 george-lpc kernel: audit: type=1334 audit(1651803794.232:821): prog-id=0 op=UNLOAD
may 06 07:23:14 george-lpc kernel: audit: type=1334 audit(1651803794.232:822): prog-id=0 op=UNLOAD
may 06 07:23:14 george-lpc kernel: audit: type=1334 audit(1651803794.232:823): prog-id=0 op=UNLOAD
may 06 07:32:23 george-lpc rtkit-daemon[817]: Supervising 12 threads of 5 processes of 1 users.
may 06 08:01:01 george-lpc CROND[37757]: (root) CMD (run-parts /etc/cron.hourly)
may 06 08:01:01 george-lpc CROND[37756]: (root) CMDEND (run-parts /etc/cron.hourly)
may 06 08:11:06 george-lpc plasmashell[778]: libkcups: Renew-Subscription last error: 0 successful-ok
may 06 08:22:43 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.700' (uid=1000 pid=38020 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
may 06 08:22:43 george-lpc kernel: audit: type=1334 audit(1651807363.969:824): prog-id=262 op=LOAD
may 06 08:22:43 george-lpc kernel: audit: type=1334 audit(1651807363.972:825): prog-id=263 op=LOAD
may 06 08:22:43 george-lpc kernel: audit: type=1334 audit(1651807363.972:826): prog-id=264 op=LOAD
may 06 08:22:43 george-lpc audit: BPF prog-id=262 op=LOAD
may 06 08:22:43 george-lpc audit: BPF prog-id=263 op=LOAD
may 06 08:22:43 george-lpc audit: BPF prog-id=264 op=LOAD
may 06 08:22:43 george-lpc systemd[1]: Starting Locale Service...
may 06 08:22:44 george-lpc dbus-daemon[473]: [system] Successfully activated service 'org.freedesktop.locale1'
may 06 08:22:44 george-lpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 08:22:44 george-lpc systemd[1]: Started Locale Service.
may 06 08:22:44 george-lpc kernel: audit: type=1130 audit(1651807364.012:827): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 08:23:14 george-lpc systemd[1]: systemd-localed.service: Deactivated successfully.
may 06 08:23:14 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 08:23:14 george-lpc kernel: audit: type=1131 audit(1651807394.045:828): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 08:23:14 george-lpc audit: BPF prog-id=0 op=UNLOAD
may 06 08:23:14 george-lpc kernel: audit: type=1334 audit(1651807394.129:829): prog-id=0 op=UNLOAD
may 06 08:23:14 george-lpc kernel: audit: type=1334 audit(1651807394.129:830): prog-id=0 op=UNLOAD
may 06 08:23:14 george-lpc kernel: audit: type=1334 audit(1651807394.129:831): prog-id=0 op=UNLOAD
may 06 08:32:24 george-lpc rtkit-daemon[817]: Supervising 12 threads of 5 processes of 1 users.
may 06 09:01:01 george-lpc CROND[38549]: (root) CMD (run-parts /etc/cron.hourly)
may 06 09:01:01 george-lpc CROND[38548]: (root) CMDEND (run-parts /etc/cron.hourly)
may 06 09:09:26 george-lpc plasmashell[778]: libkcups: Renew-Subscription last error: 0 successful-ok
may 06 09:22:43 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.705' (uid=1000 pid=38820 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
may 06 09:22:43 george-lpc kernel: audit: type=1334 audit(1651810963.426:832): prog-id=265 op=LOAD
may 06 09:22:43 george-lpc kernel: audit: type=1334 audit(1651810963.426:833): prog-id=266 op=LOAD
may 06 09:22:43 george-lpc kernel: audit: type=1334 audit(1651810963.426:834): prog-id=267 op=LOAD
may 06 09:22:43 george-lpc audit: BPF prog-id=265 op=LOAD
may 06 09:22:43 george-lpc audit: BPF prog-id=266 op=LOAD
may 06 09:22:43 george-lpc audit: BPF prog-id=267 op=LOAD
may 06 09:22:43 george-lpc systemd[1]: Starting Locale Service...
may 06 09:22:43 george-lpc dbus-daemon[473]: [system] Successfully activated service 'org.freedesktop.locale1'
may 06 09:22:43 george-lpc systemd[1]: Started Locale Service.
may 06 09:22:43 george-lpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 09:22:43 george-lpc kernel: audit: type=1130 audit(1651810963.466:835): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 09:23:13 george-lpc systemd[1]: systemd-localed.service: Deactivated successfully.
may 06 09:23:13 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 09:23:13 george-lpc kernel: audit: type=1131 audit(1651810993.487:836): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 09:23:13 george-lpc audit: BPF prog-id=0 op=UNLOAD
may 06 09:23:13 george-lpc kernel: audit: type=1334 audit(1651810993.587:837): prog-id=0 op=UNLOAD
may 06 09:23:13 george-lpc kernel: audit: type=1334 audit(1651810993.587:838): prog-id=0 op=UNLOAD
may 06 09:23:13 george-lpc kernel: audit: type=1334 audit(1651810993.587:839): prog-id=0 op=UNLOAD
may 06 09:32:24 george-lpc rtkit-daemon[817]: Supervising 12 threads of 5 processes of 1 users.
may 06 10:01:01 george-lpc CROND[39327]: (root) CMD (run-parts /etc/cron.hourly)
may 06 10:01:01 george-lpc CROND[39326]: (root) CMDEND (run-parts /etc/cron.hourly)
may 06 10:07:46 george-lpc plasmashell[778]: libkcups: Renew-Subscription last error: 0 successful-ok
may 06 10:22:44 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.710' (uid=1000 pid=39589 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
may 06 10:22:44 george-lpc audit: BPF prog-id=268 op=LOAD
may 06 10:22:44 george-lpc audit: BPF prog-id=269 op=LOAD
may 06 10:22:44 george-lpc audit: BPF prog-id=270 op=LOAD
may 06 10:22:44 george-lpc systemd[1]: Starting Locale Service...
may 06 10:22:44 george-lpc kernel: audit: type=1334 audit(1651814564.027:840): prog-id=268 op=LOAD
may 06 10:22:44 george-lpc kernel: audit: type=1334 audit(1651814564.027:841): prog-id=269 op=LOAD
may 06 10:22:44 george-lpc kernel: audit: type=1334 audit(1651814564.027:842): prog-id=270 op=LOAD
may 06 10:22:44 george-lpc dbus-daemon[473]: [system] Successfully activated service 'org.freedesktop.locale1'
may 06 10:22:44 george-lpc systemd[1]: Started Locale Service.
may 06 10:22:44 george-lpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:22:44 george-lpc kernel: audit: type=1130 audit(1651814564.070:843): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:23:14 george-lpc systemd[1]: systemd-localed.service: Deactivated successfully.
may 06 10:23:14 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:23:14 george-lpc kernel: audit: type=1131 audit(1651814594.101:844): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:23:14 george-lpc audit: BPF prog-id=0 op=UNLOAD
may 06 10:23:14 george-lpc kernel: audit: type=1334 audit(1651814594.177:845): prog-id=0 op=UNLOAD
may 06 10:23:14 george-lpc kernel: audit: type=1334 audit(1651814594.177:846): prog-id=0 op=UNLOAD
may 06 10:23:14 george-lpc kernel: audit: type=1334 audit(1651814594.177:847): prog-id=0 op=UNLOAD
may 06 10:32:25 george-lpc rtkit-daemon[817]: Supervising 12 threads of 5 processes of 1 users.
may 06 10:52:59 george-lpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:52:59 george-lpc kernel: audit: type=1130 audit(1651816379.862:848): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:52:59 george-lpc systemd[1]: Started Getty on tty2.
may 06 10:53:08 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.713' (uid=0 pid=40023 comm="/bin/login -p -- ")
may 06 10:53:08 george-lpc dbus-daemon[473]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
may 06 10:53:08 george-lpc login[40023]: pam_systemd_home(login:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
may 06 10:53:10 george-lpc audit[40023]: USER_AUTH pid=40023 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:10 george-lpc audit[40023]: USER_ACCT pid=40023 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:10 george-lpc audit[40023]: CRED_ACQ pid=40023 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:10 george-lpc audit[40023]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffdb9c23a50 a2=4 a3=0 items=0 ppid=1 pid=40023 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=4 comm="login" exe="/usr/bin/login" subj==unconfined key=(null)
may 06 10:53:10 george-lpc kernel: audit: type=1100 audit(1651816390.595:849): pid=40023 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:10 george-lpc kernel: audit: type=1101 audit(1651816390.595:850): pid=40023 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:10 george-lpc kernel: audit: type=1103 audit(1651816390.595:851): pid=40023 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:10 george-lpc kernel: audit: type=1006 audit(1651816390.595:852): pid=40023 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=4 res=1
may 06 10:53:10 george-lpc kernel: audit: type=1300 audit(1651816390.595:852): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffdb9c23a50 a2=4 a3=0 items=0 ppid=1 pid=40023 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=4 comm="login" exe="/usr/bin/login" subj==unconfined key=(null)
may 06 10:53:10 george-lpc kernel: audit: type=1327 audit(1651816390.595:852): proctitle=2F62696E2F6C6F67696E002D70002D2D
may 06 10:53:10 george-lpc audit: PROCTITLE proctitle=2F62696E2F6C6F67696E002D70002D2D
may 06 10:53:10 george-lpc login[40023]: pam_unix(login:session): session opened for user george(uid=1000) by LOGIN(uid=0)
may 06 10:53:10 george-lpc systemd-logind[476]: New session 4 of user george.
may 06 10:53:10 george-lpc systemd[1]: Started Session 4 of User george.
may 06 10:53:10 george-lpc login[40023]: pam_env(login:session): deprecated reading of user environment enabled
may 06 10:53:10 george-lpc audit[40023]: USER_START pid=40023 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:10 george-lpc audit[40023]: CRED_REFR pid=40023 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:10 george-lpc login[40023]: LOGIN ON tty2 BY george
may 06 10:53:10 george-lpc kernel: audit: type=1105 audit(1651816390.615:853): pid=40023 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:10 george-lpc kernel: audit: type=1110 audit(1651816390.615:854): pid=40023 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:16 george-lpc polkitd[474]: Registered Authentication Agent for unix-process:40035:3425718 (system bus name :1.715 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
may 06 10:53:16 george-lpc systemd-logind[476]: System is rebooting.
may 06 10:53:16 george-lpc systemd[1]: Stopping Session 2 of User george...
may 06 10:53:16 george-lpc systemd[1]: Stopping Session 4 of User george...
may 06 10:53:16 george-lpc systemd[1]: Removed slice Slice /system/modprobe.
may 06 10:53:16 george-lpc systemd[1]: Removed slice Slice /system/systemd-coredump.
may 06 10:53:16 george-lpc systemd[1]: system-systemd\x2dcoredump.slice: Consumed 32.040s CPU time.
may 06 10:53:16 george-lpc systemd[1]: Stopped target Block Device Preparation for /dev/mapper/luks-759e4834-4e1b-40c4-a226-cd461e14b565.
may 06 10:53:16 george-lpc systemd[1]: Stopped target Graphical Interface.
may 06 10:53:16 george-lpc systemd[1]: Stopped target Multi-User System.
may 06 10:53:16 george-lpc systemd[1]: Stopped target Login Prompts.
may 06 10:53:16 george-lpc systemd[1]: Stopped target Network is Online.
may 06 10:53:16 george-lpc kernel: audit: type=1131 audit(1651816396.929:855): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:16 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:16 george-lpc avahi-daemon[471]: Got SIGTERM, quitting.
may 06 10:53:16 george-lpc systemd[1]: Stopped target Sound Card.
may 06 10:53:16 george-lpc avahi-daemon[471]: Leaving mDNS multicast group on interface enp5s0.IPv6 with address fe80::438f:ccdc:d55c:b25c.
may 06 10:53:16 george-lpc systemd[1]: Stopped target Timer Units.
may 06 10:53:16 george-lpc avahi-daemon[471]: Leaving mDNS multicast group on interface enp5s0.IPv4 with address 192.168.1.130.
may 06 10:53:16 george-lpc systemd[1]: logrotate.timer: Deactivated successfully.
may 06 10:53:16 george-lpc avahi-daemon[471]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
may 06 10:53:16 george-lpc systemd[1]: Stopped Daily rotation of log files.
may 06 10:53:16 george-lpc avahi-daemon[471]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
may 06 10:53:16 george-lpc systemd[1]: man-db.timer: Deactivated successfully.
may 06 10:53:16 george-lpc avahi-daemon[471]: avahi-daemon 0.8 exiting.
may 06 10:53:16 george-lpc systemd[1]: Stopped Daily man-db regeneration.
may 06 10:53:16 george-lpc systemd[1]: pamac-cleancache.timer: Deactivated successfully.
may 06 10:53:16 george-lpc systemd[1]: Stopped Monthly clean packages cache.
may 06 10:53:16 george-lpc systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
may 06 10:53:16 george-lpc systemd[1]: Stopped Generate mirrorlist weekly.
may 06 10:53:16 george-lpc systemd[1]: pkgfile-update.timer: Deactivated successfully.
may 06 10:53:16 george-lpc systemd[1]: Stopped pkgfile database update timer.
may 06 10:53:16 george-lpc systemd[1]: shadow.timer: Deactivated successfully.
may 06 10:53:16 george-lpc systemd[1]: Stopped Daily verification of password and group files.
may 06 10:53:16 george-lpc systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
may 06 10:53:16 george-lpc systemd[1]: Stopped Daily Cleanup of Temporary Directories.
may 06 10:53:16 george-lpc systemd[1]: Stopped target System Time Set.
may 06 10:53:16 george-lpc systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
may 06 10:53:16 george-lpc ModemManager[530]: <info> caught signal, shutting down...
may 06 10:53:16 george-lpc systemd[1]: Closed LVM2 poll daemon socket.
may 06 10:53:16 george-lpc systemd[1]: systemd-coredump.socket: Deactivated successfully.
may 06 10:53:16 george-lpc systemd[1]: Closed Process Core Dump Socket.
may 06 10:53:16 george-lpc systemd[1]: systemd-rfkill.socket: Deactivated successfully.
may 06 10:53:16 george-lpc systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
may 06 10:53:16 george-lpc systemd[1]: Stopping Modem Manager...
may 06 10:53:16 george-lpc systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
may 06 10:53:16 george-lpc systemd[1]: Stopped Network Manager Wait Online.
may 06 10:53:16 george-lpc systemd[1]: Stopping Accounts Service...
may 06 10:53:16 george-lpc kernel: audit: type=1104 audit(1651816396.939:856): pid=40023 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:16 george-lpc kernel: audit: type=1701 audit(1651816396.939:857): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1256 comm="@joplinapp-desk" exe="/tmp/.mount_Joplin7j3H8B/@joplinapp-desktop" sig=7 res=1
may 06 10:53:16 george-lpc audit[40023]: CRED_DISP pid=40023 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:16 george-lpc audit[1256]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1256 comm="@joplinapp-desk" exe="/tmp/.mount_Joplin7j3H8B/@joplinapp-desktop" sig=7 res=1
may 06 10:53:16 george-lpc systemd[1]: Stopping Save/Restore Sound Card State...
may 06 10:53:16 george-lpc login[40023]: pam_unix(login:session): session closed for user george
may 06 10:53:16 george-lpc systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
may 06 10:53:16 george-lpc crond[472]: (CRON) INFO (Shutting down)
may 06 10:53:17 george-lpc kernel: audit: type=1701 audit(1651816397.019:858): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=9116 comm="gogglesmm" exe="/usr/bin/gogglesmm" sig=6 res=1
may 06 10:53:17 george-lpc audit[9116]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=9116 comm="gogglesmm" exe="/usr/bin/gogglesmm" sig=6 res=1
may 06 10:53:17 george-lpc kernel: audit: type=1131 audit(1651816397.052:859): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc kernel: audit: type=1131 audit(1651816397.055:860): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc kernel: audit: type=1131 audit(1651816397.055:861): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc kernel: audit: type=1131 audit(1651816397.055:862): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc kernel: audit: type=1131 audit(1651816397.055:863): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc kernel: audit: type=1131 audit(1651816397.055:864): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:16 george-lpc systemd[1]: Stopping Periodic Command Scheduler...
may 06 10:53:17 george-lpc at-spi-bus-launcher[1096]: X connection to :0 broken (explicit kill or server shutdown).
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=packagekit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:16 george-lpc ntfs-3g[862]: Unmounting /dev/sda3 ()
may 06 10:53:16 george-lpc systemd[1]: Stopping CUPS Scheduler...
may 06 10:53:17 george-lpc at-spi-bus-launcher[1094]: dbus-daemon[1094]: Activating service name='org.a11y.atspi.Registry' requested by ':1.47' (uid=1000 pid=31499 comm="/usr/bin/yakuake")
may 06 10:53:17 george-lpc at-spi-bus-launcher[1094]: dbus-daemon[1094]: Successfully activated service 'org.a11y.atspi.Registry'
may 06 10:53:16 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.716' (uid=1000 pid=6484 comm="/usr/lib/gvfsd-dnssd --spawner :1.36 /org/gtk/gvfs")
may 06 10:53:16 george-lpc systemd[1]: Stopping Getty on tty2...
may 06 10:53:17 george-lpc audit: BPF prog-id=0 op=UNLOAD
may 06 10:53:17 george-lpc at-spi-bus-launcher[40071]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:16 george-lpc ModemManager[530]: <info> ModemManager is shut down
may 06 10:53:16 george-lpc systemd[1]: Starting Generate shutdown-ramfs...
may 06 10:53:16 george-lpc systemd[1]: Stopping PackageKit Daemon...
may 06 10:53:16 george-lpc systemd[1]: Stopping Pamac Daemon...
may 06 10:53:16 george-lpc systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
may 06 10:53:16 george-lpc systemd[1]: Stopping Simple Desktop Display Manager...
may 06 10:53:16 george-lpc systemd[1]: Stopping Load/Save Random Seed...
may 06 10:53:16 george-lpc systemd[1]: Stopping Disk Manager...
may 06 10:53:16 george-lpc systemd[1]: Stopping Daemon for power management...
may 06 10:53:16 george-lpc udisksd[628]: Cleaning up mount point /run/media/george/90CE9502CE94E1B0 (device 8:3 is not mounted)
may 06 10:53:16 george-lpc systemd[1]: run-media-george-90CE9502CE94E1B0.mount: Deactivated successfully.
may 06 10:53:16 george-lpc systemd[1]: Unmounted /run/media/george/90CE9502CE94E1B0.
may 06 10:53:16 george-lpc krunner[4286]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:16 george-lpc sddm[533]: Signal received: SIGTERM
may 06 10:53:16 george-lpc kglobalaccel5[742]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:16 george-lpc NetworkManager[508]: <info> [1651816396.9652] modem-manager: ModemManager no longer available
may 06 10:53:16 george-lpc sddm[533]: Socket server stopping...
may 06 10:53:16 george-lpc sddm[533]: Socket server stopped.
may 06 10:53:16 george-lpc sddm[533]: Display server stopping...
may 06 10:53:16 george-lpc kactivitymanagerd[829]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:16 george-lpc kscreen_backend_launcher[853]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:16 george-lpc baloorunner[4314]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:16 george-lpc krunner[4286]: file:///usr/lib/qt/qml/org/kde/milou/ResultsView.qml:56: TypeError: Cannot read property 'iconSizes' of null
may 06 10:53:16 george-lpc xdg-desktop-portal-kde[1139]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:17 george-lpc pulseaudio[809]: X11 I/O error handler called
may 06 10:53:17 george-lpc pulseaudio[809]: X11 I/O error exit handler called, preparing to tear down X11 modules
may 06 10:53:17 george-lpc dbus-daemon[473]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Refusing activation, D-Bus is shutting down.
may 06 10:53:17 george-lpc ksmserver[759]: org.kde.kf5.ksmserver: ksmserver: Fatal IO error: client killed
may 06 10:53:17 george-lpc udisksd[628]: udisks daemon version 2.9.4 exiting
may 06 10:53:17 george-lpc systemd[1]: avahi-daemon.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
may 06 10:53:17 george-lpc systemd[1]: cronie.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Periodic Command Scheduler.
may 06 10:53:17 george-lpc systemd[1]: cups.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped CUPS Scheduler.
may 06 10:53:17 george-lpc systemd[1]: ModemManager.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Modem Manager.
may 06 10:53:17 george-lpc systemd[1]: upower.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Daemon for power management.
may 06 10:53:17 george-lpc systemd[1]: rtkit-daemon.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
may 06 10:53:17 george-lpc systemd[1]: accounts-daemon.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Accounts Service.
may 06 10:53:17 george-lpc systemd[658]: plasma-kglobalaccel.service: Consumed 2.330s CPU time.
may 06 10:53:17 george-lpc systemd[658]: plasma-kactivitymanagerd.service: Main process exited, code=exited, status=1/FAILURE
may 06 10:53:17 george-lpc systemd[658]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
may 06 10:53:17 george-lpc polkitd[474]: Unregistered Authentication Agent for unix-process:40035:3425718 (system bus name :1.715, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
may 06 10:53:17 george-lpc systemd[658]: plasma-kactivitymanagerd.service: Consumed 2.598s CPU time.
may 06 10:53:17 george-lpc systemd[658]: plasma-kscreen.service: Main process exited, code=exited, status=1/FAILURE
may 06 10:53:17 george-lpc systemd[658]: plasma-kscreen.service: Failed with result 'exit-code'.
may 06 10:53:17 george-lpc systemd[658]: plasma-kscreen.service: Consumed 1.288s CPU time.
may 06 10:53:17 george-lpc systemd[658]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=exited, status=1/FAILURE
may 06 10:53:17 george-lpc systemd[658]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
may 06 10:53:17 george-lpc systemd[658]: plasma-xdg-desktop-portal-kde.service: Consumed 1.366s CPU time.
may 06 10:53:17 george-lpc systemd[658]: plasma-baloorunner.service: Main process exited, code=exited, status=1/FAILURE
may 06 10:53:17 george-lpc systemd[658]: plasma-baloorunner.service: Failed with result 'exit-code'.
may 06 10:53:17 george-lpc systemd[658]: plasma-baloorunner.service: Consumed 1.518s CPU time.
may 06 10:53:17 george-lpc unknown[40071]: Could not open X display
may 06 10:53:17 george-lpc systemd[1]: pamac-daemon.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Pamac Daemon.
may 06 10:53:17 george-lpc systemd[1]: pamac-daemon.service: Consumed 5.950s CPU time.
may 06 10:53:17 george-lpc systemd[1]: packagekit.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped PackageKit Daemon.
may 06 10:53:17 george-lpc systemd[1]: alsa-restore.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Save/Restore Sound Card State.
may 06 10:53:17 george-lpc systemd[1]: systemd-random-seed.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Load/Save Random Seed.
may 06 10:53:17 george-lpc unknown[40071]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc systemd[1]: udisks2.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Disk Manager.
may 06 10:53:17 george-lpc systemd[1]: udisks2.service: Consumed 11.940s CPU time.
may 06 10:53:17 george-lpc systemd-logind[476]: Session 2 logged out. Waiting for processes to exit.
may 06 10:53:17 george-lpc systemd[1]: Stopping Authorization Manager...
may 06 10:53:17 george-lpc systemd[1]: polkit.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Authorization Manager.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: getty@tty2.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Getty on tty2.
may 06 10:53:17 george-lpc audit[40023]: USER_END pid=40023 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="george" exe="/usr/bin/login" hostname=george-lpc addr=? terminal=/dev/tty2 res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc keepassxc[799]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
may 06 10:53:17 george-lpc at-spi2-registr[40077]: Could not open X display
may 06 10:53:17 george-lpc systemd[1]: session-4.scope: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Session 4 of User george.
may 06 10:53:17 george-lpc systemd[1]: Removed slice Slice /system/getty.
may 06 10:53:17 george-lpc at-spi-bus-launcher[40077]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc systemd-logind[476]: Session 4 logged out. Waiting for processes to exit.
may 06 10:53:17 george-lpc mkinitcpio[40045]: ==> Starting build: none
may 06 10:53:17 george-lpc systemd-logind[476]: Removed session 4.
may 06 10:53:17 george-lpc at-spi2-registr[40077]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc mkinitcpio[40045]: -> Running build hook: [sd-shutdown]
may 06 10:53:17 george-lpc at-spi2-registr[40100]: Could not open X display
may 06 10:53:17 george-lpc at-spi2-registr[40100]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40100]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc keepassxc[799]: The X11 connection broke: I/O error (code 1)
may 06 10:53:17 george-lpc at-spi2-registr[40109]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40109]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40109]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc kded5[730]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:17 george-lpc at-spi2-registr[40117]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40117]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40117]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc sddm[533]: Display server stopped.
may 06 10:53:17 george-lpc sddm[533]: Running display stop script "/usr/share/sddm/scripts/Xstop"
may 06 10:53:17 george-lpc plasma-shutdown[35099]: org.kde.plasma.shutdown: ksmserver failed to complete logout
may 06 10:53:17 george-lpc at-spi2-registr[40125]: Could not open X display
may 06 10:53:17 george-lpc sddm[533]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
may 06 10:53:17 george-lpc at-spi-bus-launcher[40125]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40125]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40141]: Could not open X display
may 06 10:53:17 george-lpc at-spi2-registr[40141]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40141]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc yakuake[31499]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:17 george-lpc at-spi-bus-launcher[1094]: dbus-daemon[1094]: Activating service name='org.a11y.atspi.Registry' requested by ':1.25' (uid=1000 pid=849 comm="/usr/bin/corectrl")
may 06 10:53:17 george-lpc at-spi2-registr[40146]: Could not open X display
may 06 10:53:17 george-lpc systemd[658]: plasma-krunner.service: Consumed 9.079s CPU time.
may 06 10:53:17 george-lpc at-spi-bus-launcher[40146]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40146]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc systemd[1]: sddm.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Simple Desktop Display Manager.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: sddm.service: Consumed 28min 14.950s CPU time.
may 06 10:53:17 george-lpc at-spi2-registr[40151]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40151]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40151]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc systemd[658]: app-org.kde.yakuake-e50b92247fa4437e9e498ed4835cafe7.scope: Consumed 6.479s CPU time.
may 06 10:53:17 george-lpc at-spi2-registr[40158]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40158]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40158]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc corectrl[849]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:17 george-lpc systemd[658]: app-io.github.sharkwouter.Minigalaxy-189b61401c7a44d8898d2c14e64fd5f6.scope: Consumed 30.255s CPU time.
may 06 10:53:17 george-lpc mkinitcpio[40045]: ==> Build complete.
may 06 10:53:17 george-lpc systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Finished Generate shutdown-ramfs.
may 06 10:53:17 george-lpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc at-spi-bus-launcher[1094]: dbus-daemon[1094]: Activating service name='org.a11y.atspi.Registry' requested by ':1.32' (uid=1000 pid=7985 comm="/usr/bin/qbittorrent /home/george/.local/share/tor")
may 06 10:53:17 george-lpc at-spi2-registr[40185]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40185]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40185]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40187]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40187]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40187]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40189]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40189]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40189]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.202' (uid=1000 pid=6829 comm="/usr/bin/dolphin")
may 06 10:53:17 george-lpc dbus-daemon[473]: [system] Activation via systemd failed for unit 'udisks2.service': Refusing activation, D-Bus is shutting down.
may 06 10:53:17 george-lpc at-spi2-registr[40192]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40192]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40192]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40194]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40194]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40194]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc kwin_x11[733]: The X11 connection broke: I/O error (code 1)
may 06 10:53:17 george-lpc kwin_x11[733]: file:///usr/share/kwin/outline/plasma/outline.qml:14: TypeError: Cannot read property 'longDuration' of null
may 06 10:53:17 george-lpc at-spi2-registr[40196]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40196]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40196]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40198]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40198]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40198]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40200]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40200]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40200]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc qbittorrent[7985]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:17 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.3' (uid=0 pid=476 comm="/usr/lib/systemd/systemd-logind")
may 06 10:53:17 george-lpc dbus-daemon[473]: [system] Activation via systemd failed for unit 'polkit.service': Refusing activation, D-Bus is shutting down.
may 06 10:53:17 george-lpc at-spi-bus-launcher[1094]: dbus-daemon[1094]: Activating service name='org.a11y.atspi.Registry' requested by ':1.31' (uid=1000 pid=6829 comm="/usr/bin/dolphin")
may 06 10:53:17 george-lpc at-spi2-registr[40202]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40202]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40202]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40204]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40204]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40204]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40218]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40218]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40218]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40220]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40220]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40220]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40222]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40222]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40222]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc at-spi2-registr[40224]: Could not open X display
may 06 10:53:17 george-lpc at-spi-bus-launcher[40224]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
may 06 10:53:17 george-lpc at-spi2-registr[40224]: AT-SPI: Cannot open default display
may 06 10:53:17 george-lpc dolphin[6829]: The X11 connection broke (error 1). Did the X11 server die?
may 06 10:53:17 george-lpc systemd[658]: app-firefox-3948746c382a44048e39bb1076c75d53.scope: Consumed 1h 52min 43.222s CPU time.
may 06 10:53:17 george-lpc systemd[1]: session-2.scope: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Session 2 of User george.
may 06 10:53:17 george-lpc systemd[1]: session-2.scope: Consumed 1h 12min 26.719s CPU time.
may 06 10:53:17 george-lpc systemd[1]: Stopping User Login Management...
may 06 10:53:17 george-lpc systemd[1]: Stopping User Manager for UID 1000...
may 06 10:53:17 george-lpc systemd-logind[476]: Removed session 2.
may 06 10:53:17 george-lpc systemd[658]: Activating special unit Exit the Session...
may 06 10:53:17 george-lpc systemd[658]: Stopping Dolphin - File Manager...
may 06 10:53:17 george-lpc obexd[871]: Terminating
may 06 10:53:17 george-lpc systemd[658]: Stopping qBittorrent - BitTorrent client...
may 06 10:53:17 george-lpc systemd[658]: Removed slice User Background Tasks Slice.
may 06 10:53:17 george-lpc systemd[658]: background.slice: Consumed 16.815s CPU time.
may 06 10:53:17 george-lpc systemd[658]: Stopped target Main User Target.
may 06 10:53:17 george-lpc systemd[658]: Stopping AppImageLauncher daemon...
may 06 10:53:17 george-lpc systemd[658]: Stopping Accessibility services bus...
may 06 10:53:17 george-lpc systemd[658]: Stopping D-Bus User Message Bus...
may 06 10:53:17 george-lpc systemd[658]: Stopping User preferences database...
may 06 10:53:17 george-lpc systemd[658]: Stopping Virtual filesystem service - Apple File Conduit monitor...
may 06 10:53:17 george-lpc systemd[658]: Stopping Virtual filesystem service...
may 06 10:53:17 george-lpc systemd[658]: Stopping Virtual filesystem service - digital camera monitor...
may 06 10:53:17 george-lpc systemd[658]: Stopping Virtual filesystem metadata service...
may 06 10:53:17 george-lpc systemd[658]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
may 06 10:53:17 george-lpc systemd[658]: Stopping Virtual filesystem service - disk device monitor...
may 06 10:53:17 george-lpc systemd[658]: Stopping Bluetooth OBEX service...
may 06 10:53:17 george-lpc systemd[658]: Stopping PipeWire Media Session Manager...
may 06 10:53:17 george-lpc systemd[658]: Stopping Portal service...
may 06 10:53:17 george-lpc systemd[658]: Stopping flatpak document portal service...
may 06 10:53:17 george-lpc systemd[658]: Stopping sandboxed app permission store...
may 06 10:53:17 george-lpc systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Unmounted /run/user/1000/gvfs.
may 06 10:53:17 george-lpc systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Unmounted /run/user/1000/doc.
may 06 10:53:17 george-lpc systemd[658]: Stopped D-Bus User Message Bus.
may 06 10:53:17 george-lpc systemd[658]: dbus.service: Consumed 11.550s CPU time.
may 06 10:53:17 george-lpc systemd[658]: Stopped User preferences database.
may 06 10:53:17 george-lpc systemd[658]: Stopped Bluetooth OBEX service.
may 06 10:53:17 george-lpc systemd[658]: Stopped Virtual filesystem service.
may 06 10:53:17 george-lpc systemd[658]: Stopped PipeWire Media Session Manager.
may 06 10:53:17 george-lpc systemd[658]: Stopped Virtual filesystem metadata service.
may 06 10:53:17 george-lpc systemd[658]: Stopped Virtual filesystem service - disk device monitor.
may 06 10:53:17 george-lpc systemd[658]: Stopped Virtual filesystem service - digital camera monitor.
may 06 10:53:17 george-lpc systemd[658]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
may 06 10:53:17 george-lpc systemd[658]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
may 06 10:53:17 george-lpc systemd[658]: xdg-document-portal.service: Failed with result 'exit-code'.
may 06 10:53:17 george-lpc systemd[658]: Stopped flatpak document portal service.
may 06 10:53:17 george-lpc systemd[658]: Stopped Virtual filesystem service - Apple File Conduit monitor.
may 06 10:53:17 george-lpc systemd[658]: Stopped AppImageLauncher daemon.
may 06 10:53:17 george-lpc systemd[658]: appimagelauncherd.service: Consumed 11.958s CPU time.
may 06 10:53:17 george-lpc systemd[658]: Stopping PipeWire Multimedia Service...
may 06 10:53:17 george-lpc systemd[658]: Stopped sandboxed app permission store.
may 06 10:53:17 george-lpc pipewire[1152]: Asked to handle disabled watch: 0x5574cffbdae0 19
may 06 10:53:17 george-lpc systemd[658]: Stopped PipeWire Multimedia Service.
may 06 10:53:17 george-lpc systemd[658]: Stopped Accessibility services bus.
may 06 10:53:17 george-lpc systemd[658]: at-spi-dbus-bus.service: Consumed 4.204s CPU time.
may 06 10:53:17 george-lpc systemd[658]: Stopped Portal service.
may 06 10:53:17 george-lpc systemd[658]: Stopped Sound Service.
may 06 10:53:17 george-lpc systemd[658]: pulseaudio.service: Consumed 2min 49.926s CPU time.
may 06 10:53:17 george-lpc systemd[658]: Removed slice User Core Session Slice.
may 06 10:53:17 george-lpc systemd[658]: session.slice: Consumed 3min 5.390s CPU time.
may 06 10:53:17 george-lpc systemd[658]: Stopped target Basic System.
may 06 10:53:17 george-lpc systemd[658]: Stopped target Paths.
may 06 10:53:17 george-lpc systemd[658]: Stopped target Sockets.
may 06 10:53:17 george-lpc systemd[658]: Stopped target Timers.
may 06 10:53:17 george-lpc systemd[658]: Closed D-Bus User Message Bus Socket.
may 06 10:53:17 george-lpc systemd[658]: Closed GnuPG network certificate management daemon.
may 06 10:53:17 george-lpc systemd[658]: Closed GCR ssh-agent wrapper.
may 06 10:53:17 george-lpc systemd[658]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
may 06 10:53:17 george-lpc systemd[658]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
may 06 10:53:17 george-lpc systemd[658]: Closed GnuPG cryptographic agent (ssh-agent emulation).
may 06 10:53:17 george-lpc systemd[658]: Closed GnuPG cryptographic agent and passphrase cache.
may 06 10:53:17 george-lpc systemd[658]: Closed p11-kit server.
may 06 10:53:17 george-lpc systemd[658]: Closed PipeWire Multimedia System Socket.
may 06 10:53:17 george-lpc systemd[658]: Closed Sound System.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: systemd-logind.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped User Login Management.
may 06 10:53:17 george-lpc systemd[658]: Stopped Dolphin - File Manager.
may 06 10:53:17 george-lpc systemd[658]: app-org.kde.dolphin-258ae0bc5e274ee397bfa0a8e79098a6.scope: Consumed 5min 12.551s CPU time.
may 06 10:53:17 george-lpc systemd[658]: Stopped qBittorrent - BitTorrent client.
may 06 10:53:17 george-lpc systemd[658]: app-org.qbittorrent.qBittorrent-0370982cf28e4459918d81ef545375ad.scope: Consumed 28min 51.967s CPU time.
may 06 10:53:17 george-lpc systemd[658]: Removed slice User Application Slice.
may 06 10:53:17 george-lpc systemd[658]: app.slice: Consumed 3h 24min 44.269s CPU time.
may 06 10:53:17 george-lpc systemd[658]: Reached target Shutdown.
may 06 10:53:17 george-lpc systemd[658]: Finished Exit the Session.
may 06 10:53:17 george-lpc systemd[658]: Reached target Exit the Session.
may 06 10:53:17 george-lpc systemd[659]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[george] ruser=[<unknown>] rhost=[<unknown>]
may 06 10:53:17 george-lpc systemd[1]: user@1000.service: Deactivated successfully.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: Stopped User Manager for UID 1000.
may 06 10:53:17 george-lpc systemd[1]: user@1000.service: Consumed 3h 28min 7.372s CPU time.
may 06 10:53:17 george-lpc systemd[1]: Stopping User Runtime Directory /run/user/1000...
may 06 10:53:17 george-lpc systemd[1]: run-user-1000.mount: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Unmounted /run/user/1000.
may 06 10:53:17 george-lpc systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped User Runtime Directory /run/user/1000.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: Removed slice User Slice of UID 1000.
may 06 10:53:17 george-lpc systemd[1]: user-1000.slice: Consumed 4h 40min 34.168s CPU time.
may 06 10:53:17 george-lpc systemd[1]: Stopping Permit User Sessions...
may 06 10:53:17 george-lpc systemd[1]: systemd-user-sessions.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Permit User Sessions.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: Stopped target Network.
may 06 10:53:17 george-lpc systemd[1]: Stopped target User and Group Name Lookups.
may 06 10:53:17 george-lpc systemd[1]: Stopped target Remote File Systems.
may 06 10:53:17 george-lpc systemd[1]: Stopping Network Manager...
may 06 10:53:17 george-lpc NetworkManager[508]: <info> [1651816397.7968] caught SIGTERM, shutting down normally.
may 06 10:53:17 george-lpc NetworkManager[508]: <info> [1651816397.8141] dhcp4 (enp5s0): canceled DHCP transaction
may 06 10:53:17 george-lpc NetworkManager[508]: <info> [1651816397.8142] dhcp4 (enp5s0): activation: beginning transaction (timeout in 45 seconds)
may 06 10:53:17 george-lpc NetworkManager[508]: <info> [1651816397.8142] dhcp4 (enp5s0): state changed no lease
may 06 10:53:17 george-lpc NetworkManager[508]: <info> [1651816397.8145] manager: NetworkManager state is now CONNECTED_SITE
may 06 10:53:17 george-lpc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=508 comm="/usr/bin/NetworkManager --no-daemon")
may 06 10:53:17 george-lpc dbus-daemon[473]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
may 06 10:53:17 george-lpc NetworkManager[508]: <info> [1651816397.8292] exiting (success)
may 06 10:53:17 george-lpc systemd[1]: NetworkManager.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Network Manager.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: Stopping D-Bus System Message Bus...
may 06 10:53:17 george-lpc systemd[1]: dbus.service: Deactivated successfully.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: Stopped D-Bus System Message Bus.
may 06 10:53:17 george-lpc systemd[1]: dbus.service: Consumed 5.512s CPU time.
may 06 10:53:17 george-lpc systemd[1]: Stopped target Basic System.
may 06 10:53:17 george-lpc systemd[1]: Stopped target Path Units.
may 06 10:53:17 george-lpc systemd[1]: cups.path: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped target Slice Units.
may 06 10:53:17 george-lpc systemd[1]: Removed slice User and Session Slice.
may 06 10:53:17 george-lpc systemd[1]: user.slice: Consumed 4h 40min 36.157s CPU time.
may 06 10:53:17 george-lpc systemd[1]: Stopped target Socket Units.
may 06 10:53:17 george-lpc systemd[1]: avahi-daemon.socket: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
may 06 10:53:17 george-lpc systemd[1]: cups.socket: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Closed CUPS Scheduler.
may 06 10:53:17 george-lpc systemd[1]: dbus.socket: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Closed D-Bus System Message Bus Socket.
may 06 10:53:17 george-lpc systemd[1]: snapd.socket: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Closed Socket activation for snappy daemon.
may 06 10:53:17 george-lpc systemd[1]: Stopped target System Initialization.
may 06 10:53:17 george-lpc systemd[1]: Stopped target Local Encrypted Volumes.
may 06 10:53:17 george-lpc systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
may 06 10:53:17 george-lpc systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
may 06 10:53:17 george-lpc systemd[1]: Stopped target Local Integrity Protected Volumes.
may 06 10:53:17 george-lpc systemd[1]: Stopped target Local Verity Protected Volumes.
may 06 10:53:17 george-lpc systemd[1]: Stopping Set Up Additional Binary Formats...
may 06 10:53:17 george-lpc systemd[1]: Stopping Cryptography Setup for luks-759e4834-4e1b-40c4-a226-cd461e14b565...
may 06 10:53:17 george-lpc systemd[1]: systemd-sysctl.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Apply Kernel Variables.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: systemd-modules-load.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Load Kernel Modules.
may 06 10:53:17 george-lpc systemd[1]: Stopping Network Time Synchronization...
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: systemd-update-done.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Update is Completed.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: ldconfig.service: Deactivated successfully.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: Stopped Rebuild Dynamic Linker Cache.
may 06 10:53:17 george-lpc systemd[1]: systemd-journal-catalog-update.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Rebuild Journal Catalog.
may 06 10:53:17 george-lpc systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
may 06 10:53:17 george-lpc systemd[1]: systemd-binfmt.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Set Up Additional Binary Formats.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
may 06 10:53:17 george-lpc audit[40244]: SYSTEM_SHUTDOWN pid=40244 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
may 06 10:53:17 george-lpc systemd-cryptsetup[40243]: Device luks-759e4834-4e1b-40c4-a226-cd461e14b565 is still in use.
may 06 10:53:17 george-lpc systemd-cryptsetup[40243]: Failed to deactivate: Device or resource busy
may 06 10:53:17 george-lpc systemd[1]: systemd-cryptsetup@luks\x2d759e4834\x2d4e1b\x2d40c4\x2da226\x2dcd461e14b565.service: Control process exited, code=exited, status=1/FAILURE
may 06 10:53:17 george-lpc systemd[1]: systemd-cryptsetup@luks\x2d759e4834\x2d4e1b\x2d40c4\x2da226\x2dcd461e14b565.service: Failed with result 'exit-code'.
may 06 10:53:17 george-lpc systemd[1]: Stopped Cryptography Setup for luks-759e4834-4e1b-40c4-a226-cd461e14b565.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-cryptsetup@luks\x2d759e4834\x2d4e1b\x2d40c4\x2da226\x2dcd461e14b565 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
may 06 10:53:17 george-lpc systemd[1]: systemd-update-utmp.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: systemd-timesyncd.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Network Time Synchronization.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped Create Volatile Files and Directories.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: Stopped target Local File Systems.
may 06 10:53:17 george-lpc systemd[1]: Unmounting /boot/efi...
may 06 10:53:17 george-lpc systemd[1]: Unmounting /mnt/Backup...
may 06 10:53:17 george-lpc systemd[1]: Unmounting /mnt/Data...
may 06 10:53:17 george-lpc systemd[1]: Unmounting /run/credentials/systemd-sysusers.service...
may 06 10:53:17 george-lpc ntfs-3g[458]: Unmounting /dev/sdb1 (Backup n Stuff)
may 06 10:53:17 george-lpc systemd[1]: Unmounting /tmp/.mount_Joplin7j3H8B...
may 06 10:53:17 george-lpc ntfs-3g[450]: Unmounting /dev/sdc2 (Data)
may 06 10:53:17 george-lpc systemd[1]: boot-efi.mount: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Unmounted /boot/efi.
may 06 10:53:17 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-2E50\x2d3F82 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:17 george-lpc systemd[1]: systemd-fsck@dev-disk-by\x2duuid-2E50\x2d3F82.service: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Stopped File System Check on /dev/disk/by-uuid/2E50-3F82.
may 06 10:53:17 george-lpc systemd[1]: Removed slice Slice /system/systemd-fsck.
may 06 10:53:17 george-lpc systemd[1]: mnt-Backup.mount: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Unmounted /mnt/Backup.
may 06 10:53:17 george-lpc systemd[1]: run-credentials-systemd\x2dsysusers.service.mount: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Unmounted /run/credentials/systemd-sysusers.service.
may 06 10:53:17 george-lpc systemd[1]: tmp-.mount_Joplin7j3H8B.mount: Deactivated successfully.
may 06 10:53:17 george-lpc systemd[1]: Unmounted /tmp/.mount_Joplin7j3H8B.
may 06 10:53:17 george-lpc systemd[1]: Unmounting /tmp...
may 06 10:53:18 george-lpc systemd[1]: tmp.mount: Deactivated successfully.
may 06 10:53:18 george-lpc systemd[1]: Unmounted /tmp.
may 06 10:53:18 george-lpc systemd[1]: Stopped target Swaps.
may 06 10:53:18 george-lpc systemd[1]: Deactivating swap /dev/disk/by-id/dm-name-luks-018b4010-295e-4a0c-adde-d5f0e5f4e818...
may 06 10:53:18 george-lpc systemd[1]: dev-disk-by\x2duuid-5b73309b\x2d7b80\x2d42e4\x2d9517\x2d75a2bf2a202a.swap: Deactivated successfully.
may 06 10:53:18 george-lpc systemd[1]: Deactivated swap /dev/disk/by-uuid/5b73309b-7b80-42e4-9517-75a2bf2a202a.
may 06 10:53:18 george-lpc systemd[1]: dev-disk-by\x2dlabel-swap.swap: Deactivated successfully.
may 06 10:53:18 george-lpc systemd[1]: Deactivated swap /dev/disk/by-label/swap.
may 06 10:53:18 george-lpc systemd[1]: dev-disk-by\x2did-dm\x2dname\x2dluks\x2d018b4010\x2d295e\x2d4a0c\x2dadde\x2dd5f0e5f4e818.swap: Deactivated successfully.
may 06 10:53:18 george-lpc systemd[1]: Deactivated swap /dev/disk/by-id/dm-name-luks-018b4010-295e-4a0c-adde-d5f0e5f4e818.
may 06 10:53:18 george-lpc systemd[1]: dev-disk-by\x2did-dm\x2duuid\x2dCRYPT\x2dLUKS1\x2d018b4010295e4a0cadded5f0e5f4e818\x2dluks\x2d018b4010\x2d295e\x2d4a0c\x2dadde\x2dd5f0e5f4e818.swap: Deactivated successfully.
may 06 10:53:18 george-lpc systemd[1]: Deactivated swap /dev/disk/by-id/dm-uuid-CRYPT-LUKS1-018b4010295e4a0cadded5f0e5f4e818-luks-018b4010-295e-4a0c-adde-d5f0e5f4e818.
may 06 10:53:18 george-lpc systemd[1]: dev-dm\x2d1.swap: Deactivated successfully.
may 06 10:53:18 george-lpc systemd[1]: Deactivated swap /dev/dm-1.
may 06 10:53:18 george-lpc systemd[1]: dev-mapper-luks\x2d018b4010\x2d295e\x2d4a0c\x2dadde\x2dd5f0e5f4e818.swap: Deactivated successfully.
may 06 10:53:18 george-lpc systemd[1]: Deactivated swap /dev/mapper/luks-018b4010-295e-4a0c-adde-d5f0e5f4e818.
may 06 10:53:18 george-lpc systemd[1]: Stopped target Block Device Preparation for /dev/mapper/luks-018b4010-295e-4a0c-adde-d5f0e5f4e818.
may 06 10:53:18 george-lpc systemd[1]: Stopping Cryptography Setup for luks-018b4010-295e-4a0c-adde-d5f0e5f4e818...
may 06 10:53:18 george-lpc systemd[1]: systemd-cryptsetup@luks\x2d018b4010\x2d295e\x2d4a0c\x2dadde\x2dd5f0e5f4e818.service: Deactivated successfully.
may 06 10:53:18 george-lpc systemd[1]: Stopped Cryptography Setup for luks-018b4010-295e-4a0c-adde-d5f0e5f4e818.
may 06 10:53:18 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-cryptsetup@luks\x2d018b4010\x2d295e\x2d4a0c\x2dadde\x2dd5f0e5f4e818 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:19 george-lpc systemd[1]: mnt-Data.mount: Deactivated successfully.
may 06 10:53:19 george-lpc systemd[1]: Unmounted /mnt/Data.
may 06 10:53:19 george-lpc systemd[1]: mnt-Data.mount: Consumed 19min 45.071s CPU time.
may 06 10:53:19 george-lpc systemd[1]: Stopped target Preparation for Local File Systems.
may 06 10:53:19 george-lpc systemd[1]: Reached target Unmount All Filesystems.
may 06 10:53:19 george-lpc systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
may 06 10:53:19 george-lpc systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
may 06 10:53:19 george-lpc systemd[1]: Stopped Create Static Device Nodes in /dev.
may 06 10:53:19 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:19 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:19 george-lpc systemd[1]: systemd-sysusers.service: Deactivated successfully.
may 06 10:53:19 george-lpc systemd[1]: Stopped Create System Users.
may 06 10:53:19 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:19 george-lpc systemd[1]: systemd-remount-fs.service: Deactivated successfully.
may 06 10:53:19 george-lpc systemd[1]: Stopped Remount Root and Kernel File Systems.
may 06 10:53:19 george-lpc systemd[1]: lvm2-monitor.service: Deactivated successfully.
may 06 10:53:19 george-lpc systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
may 06 10:53:19 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:19 george-lpc systemd[1]: Reached target System Shutdown.
may 06 10:53:19 george-lpc systemd[1]: Reached target Late Shutdown Services.
may 06 10:53:19 george-lpc systemd[1]: systemd-reboot.service: Deactivated successfully.
may 06 10:53:19 george-lpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:19 george-lpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 06 10:53:19 george-lpc systemd[1]: Finished System Reboot.
may 06 10:53:19 george-lpc systemd[1]: Reached target System Reboot.
may 06 10:53:19 george-lpc systemd[1]: Shutting down.
may 06 10:53:19 george-lpc audit: BPF prog-id=0 op=UNLOAD
may 06 10:53:19 george-lpc systemd[1]: Using hardware watchdog 'iamt_wdt', version 1, device /dev/watchdog0
may 06 10:53:19 george-lpc systemd[1]: Watchdog running with a timeout of 10min.
may 06 10:53:19 george-lpc systemd-shutdown[1]: Using hardware watchdog 'iamt_wdt', version 1, device /dev/watchdog0
may 06 10:53:19 george-lpc systemd-shutdown[1]: Watchdog running with a timeout of 10min.
may 06 10:53:19 george-lpc systemd-shutdown[1]: Syncing filesystems and block devices.
may 06 10:53:19 george-lpc systemd-shutdown[1]: Sending SIGTERM to remaining processes...
may 06 10:53:19 george-lpc systemd-journald[324]: Journal stopped
A tail of Xorg log
~ cat /var/log/Xorg.0.log.old
[ 53.699] (II) AMDGPU(0): EDID vendor "ACR", prod id 84
[ 53.699] (II) AMDGPU(0): Using hsync ranges from config file
[ 53.699] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 53.699] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 53.699] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 -hsync -vsync (64.7 kHz eP)
[ 53.699] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 53.699] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 4906.550] (EE) event2 - Logitech USB Keyboard: client bug: event processing lagging behind by 22ms, your system is too slow
[ 7292.341] (II) AMDGPU(0): EDID vendor "ACR", prod id 84
[ 7292.341] (II) AMDGPU(0): Using hsync ranges from config file
[ 7292.341] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 7292.341] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 7292.341] (II) AMDGPU(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 -hsync -vsync (64.7 kHz eP)
[ 7292.341] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 7292.341] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 7850.390] (EE) event2 - Logitech USB Keyboard: client bug: event processing lagging behind by 32ms, your system is too slow
[ 34239.670] (II) event1 - Power Button: device removed
[ 34239.691] (II) event0 - Power Button: device removed
[ 34239.715] (II) event9 - Webcam C170: Webcam C170: device removed
[ 34239.762] (II) event2 - Logitech USB Keyboard: device removed
[ 34239.779] (II) event4 - Logitech USB Keyboard System Control: device removed
[ 34239.798] (II) event5 - Logitech Gaming Mouse G502: device removed
[ 34239.856] (II) event7 - Samson Technologies Samson Meteor Mic Consumer Control: device removed
[ 34239.891] (II) event3 - Logitech USB Keyboard Consumer Control: device removed
[ 34239.927] (II) event6 - Logitech Gaming Mouse G502 Keyboard: device removed
[ 34239.953] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 34240.181] (EE) AMDGPU(0): failed to set mode: Permission denied
[ 34240.182] (EE) AMDGPU(0): failed to set mode: Permission denied
[ 34257.362] (II) UnloadModule: "libinput"
[ 34257.363] (II) UnloadModule: "libinput"
[ 34257.373] (II) Server terminated successfully (0). Closing log file.
