First time using manjaro KDE and I don’t know why my system doesn’t shut down. When I try to shut it down via the interface, the screen goes black and shut down, the mouse and computer still on.
My pc is still on when I tell it to shutdown because all the things inside still running, when I shut down from using windows instead Linux, every led, fan, and thing like that stop and shut down too. And if I press the power button after try shut down via manjaro, the system does not start, I need to hold the power button to make the computer shut down, then I press it one more time to turn it on again.
journalctl -p 3 -xb :
heavy_check_mark:
jul 26 10:20:05 kernel: usb 1-10: 3:1: cannot get freq at ep 0x84
jul 26 10:20:09 systemd[649]: Failed to start Update XDG user dir configuration.
░░ Subject: The unit UNIT failed
░░ Defined-By: systemd
░░ Support: Support - Manjaro Linux Forum
░░ The unit UNIT failed.
░░ The result is failed.
jul 26 10:20:44 kernel: usb 1-10: 3:1: cannot get freq at ep 0x84
jul 26 10:21:09 pulseaudio[963]: GetManagedObjects() failed: org.freedesktop.DBus.Error.Tim>
…skipping…
░░ Subject: The unit UNIT failed.
░░ The resulted is failed.
Unfortunately, this option is not shutting down my computer anymore, the PC continues on, making me hold the power button…
The mouse could be on due to a feature called always-on of the USB controller.
That is a setting in the BIOS/UEFI that will always have the USB ports powered as long as the PC is connected to a power outlet. That caises that USB devices will jebon even though the PC is off.
Usually one can turn that off in the BIOS/UEFI settings.
My pc is still on because all the things inside still running, when I shut down from using windows instead Linux, every led, fan, and thing like that stop and shut down too. And if I press the power button after try shut down via manjaro, the system does not start, I need to hold the power button to make the computer shut down, then I press it one more time to turn it on again.
Lol, sorry for this windows thing hahahahaha! Here some info:
Do you know which kernel you have?
If you get to desktop, hit menu and type ‘kernel’ and then make sure you have Linux 5.15 installed, and reboot to choose that.
You can also try letting us know what kind of session you are booting.
When you reach a desktop, you can try this:
pamac install plasma-wayland-session
reboot
Then log in with wayland. Maybe Xorg has some issue shutting down… Journalctl would help.
journalctl -p 3 -xb
░░ Subject: A unidade UNIT falhou
░░ A unidade UNIT falhou.
░░ O resultado é failed.
…skipping…
Just one last question. Did ‘sudo shutdown -h now’ can do any trouble to my system? And there is any way for me to put this command in the interface to shutdown?
You might also check in system settings to see if your computer is set to shutdown or suspend when you push the power button.And no that command will not hurt your system.
Hello everyone, apparently my problem was using the backup of timeshift directly on the root driver xD… I change the driver for backup and then the PC started to shutdown normally again. Thank you all!
