Updates
plasmashell
hangs when I try to mess around in the GUI, and I’m unable to restart it withsystemctl
(throwsUnit plasmashell.service not found
). - When I try to use
powershell
itself, it says that Qt couldn’t load it (paste unavailable for now).
Problems
- Desktop Environment freezes often (mouse pointer can be moved)
- Added 5.4.58 in favour of 5.7.15 and replaced graphics drivers.
- If the setting through GUI fails, everything works properly for the same setting through TUI.
- If I switch to a secondary tty terminal and do
sudo systemctl restart sddm
it stopssddm
but doesn’t start it back up. - Manjaro Hello shows 20.1 Mikah when I’m running 20.0.3 Lysia (I switched from Manjaro GNOME 20.1rc to Manjaro KDE using a manual reinstallation from live bootable).
I have read a host of problems similar to this one all within 2020, possibly linked to 20.0.3 Lysia.
Info
Output from mhwd
[tulikam@tulika-hppavilionnotebook ~]$ sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-450xx-prime 2019.10.25 false PCI
video-hybrid-intel-nvidia-440xx-prime 2019.10.25 false PCI
video-modesetting 2020.01.13 true PCI
Output from inxi
[tulikam@tulika-hppavilionnotebook ~]$ sudo inxi -Fxxxza --no-host
[sudo] password for tulikam:
Sorry, try again.
System: Kernel: 5.4.58-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=60db5b06-b7a3-4e80-8171-a302cf4a17d8 rw quiet apparmor=1
Console: tty 1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP Pavilion Notebook v: Type1ProductConfigId serial: <filter> Chassis: type: 10
serial: N/A
Mobo: HP model: 80A4 v: 91.19 serial: <filter> UEFI: Insyde v: F.54 date: 09/22/2015
Battery: ID-1: BAT0 charge: 23.7 Wh condition: 23.7/23.7 Wh (100%) volts: 16.8/14.8 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: Full
CPU: Topology: Dual Core model: Intel Core i5-6200U socket: BGA1168 (U3E1) note: check bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: D6 L1 cache: 128 KiB L2 cache: 3072 KiB
L3 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19204
Speed: 2709 MHz min/max: 400/2800 MHz base/boost: 2000/2400 volts: 0.8 V ext-clock: 100 MHz Core speeds (MHz):
1: 2702 2: 2700 3: 2700 4: 2700
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:1916
Device-2: NVIDIA GM108M [GeForce 940M] driver: nvidia v: 450.57 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1347
Device-3: Realtek HP Truevision HD type: USB driver: uvcvideo bus ID: 1-3:3 chip ID: 0bda:57c4 serial: <filter>
Display: server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.1.5 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d70
Sound Server: ALSA v: k5.4.58-1-MANJARO
Network: Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8723be v: kernel
port: 4000 bus ID: 03:00.0 chip ID: 10ec:b723
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000
bus ID: 04:00.0 chip ID: 10ec:8136
Drives: Local Storage: total: 931.51 GiB used: 14.47 GiB (1.6%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 family: 2.5" HDD MQ01ABD... size: 931.51 GiB block size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 2C temp: 42 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 332d 22h cycles: 3470 Old-Age: g-sense error rate: 21284
Partition: ID-1: / raw size: 931.22 GiB size: 915.60 GiB (98.32%) used: 14.47 GiB (1.6%) fs: ext4 block size: 4096 B
dev: /dev/sda2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 67.0 C mobo: N/A
Info: Processes: 186 Uptime: 20m Memory: 15.48 GiB used: 1.09 GiB (7.0%) Init: systemd v: 245 Compilers: gcc: 10.1.0
Packages: pacman: 1204 lib: 321 flatpak: 0 Shell: Bash (sudo) v: 5.0.18 running in: yakuake inxi: 3.1.05
