Hello.
I want to learn how to configure openvpn and if it is possible how to setting up my cyberghost on it!
Thank you!
First and foremost - custom packages is possible but unsupported
Secondly - think - am I the only one ever wanting to do this? The answer is most likely a no - so search
Search engines has a special tag to limit searching to specific sites e.g.
E.g. keywords cyberghost vpn manjaro - if that does not yield anything useful change the search to cyberghost vpn archlinux - and you will find results pointing to
Then search using the package manager - if no results - look in AUR (Pamac settings enable AUR)
You will then find what you are looking for
$ pamac search cyberghostvpn
cyberghostvpn-openresolv 1.3.4-3 AUR
CyberGhost VPN (with openresolv for clients using NetworkManager)
cyberghostvpn 1.3.4-3 AUR
CyberGhost VPN
