Hello
in the last 2 weeks i have a boot up speed ,it’s slow ,when i install Manjaro it was really good in boot up speed but i have this problem now
This is the systemd-analyze
output :
Startup finished in 7.787s (firmware) + 6.250s (loader) + 7.475s (kernel) + 29.879s (userspace) = 51.393s
graphical.target reached after 29.875s in userspace
and these are my laptop info :
H/W path Device Class Description
system HP Laptop 17-bs0xx
/0 bus 833D
/0/0 memory 128KiB BIOS
/0/4 processor Intel(R) Core(TM) i3-6006U CPU @ 2.00GHz
/0/4/5 memory 128KiB L1 cache
/0/4/6 memory 512KiB L2 cache
/0/4/7 memory 3MiB L3 cache
/0/26 memory 4GiB System Memory
/0/26/0 memory SODIMM DDR Synchronous [empty]
/0/26/1 memory 4GiB SODIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0.5 ns)
/0/100 bridge Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers
/0/100/2 display Skylake GT2 [HD Graphics 520]
/0/100/4 generic Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
/0/100/14 bus Sunrise Point-LP USB 3.0 xHCI Controller
/0/100/14/0 usb1 bus xHCI Host Controller
/0/100/14/0/5 communication 802.11n WLAN Adapter
/0/100/14/0/7 multimedia HP TrueVision HD Camera
/0/100/14/1 usb2 bus xHCI Host Controller
/0/100/14.2 generic Sunrise Point-LP Thermal subsystem
/0/100/16 communication Sunrise Point-LP CSME HECI #1
/0/100/17 scsi0 storage Sunrise Point-LP SATA Controller [AHCI mode]
/0/100/17/0 /dev/sda disk 1TB WDC WD10JPVX-60J
/0/100/17/0/1 /dev/sda1 volume 259MiB Windows FAT volume
/0/100/17/0/2 /dev/sda2 volume 15MiB reserved partition
/0/100/17/0/3 /dev/sda3 volume 661GiB Windows NTFS volume
/0/100/17/0/4 /dev/sda4 volume 58GiB EFI partition
/0/100/17/0/5 /dev/sda5 volume 979MiB Windows NTFS volume
/0/100/17/0/6 /dev/sda6 volume 14GiB Windows NTFS volume
/0/100/17/0/7 /dev/sda7 volume 97GiB EXT4 volume
/0/100/17/0/8 /dev/sda8 volume 5999MiB Linux swap volume
/0/100/17/1 /dev/cdrom disk DVDRW DA8AESH
/0/100/1c bridge Sunrise Point-LP PCI Express Root Port #1
/0/100/1c/0 display Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile]
/0/100/1c.4 bridge Sunrise Point-LP PCI Express Root Port #5
/0/100/1c.4/0 eno1 network RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
/0/100/1c.5 bridge Sunrise Point-LP PCI Express Root Port #6
/0/100/1c.5/0 wlp3s0 network RTL8723DE 802.11b/g/n PCIe Adapter
/0/100/1f bridge Sunrise Point-LP LPC Controller
/0/100/1f.2 memory Memory controller
/0/100/1f.3 multimedia Sunrise Point-LP HD Audio
/0/100/1f.4 bus Sunrise Point-LP SMBus
/0/1 system Motherboard registers
/0/2 system Motherboard registers
/0/3 system Motherboard registers
/0/5 system AT Real-Time Clock
/0/6 generic PnP device INT3f0d
/0/7 generic PnP device HPQ8001
/0/8 generic PnP device ETD0722
/0/9 system Motherboard registers
/0/a system Motherboard registers
/1 power JC04041
/2 power OEM Define 5
So any one who can help me for fix this problem.
