Manjaro KDE / Architect 19 & 20 won't boot
Hello first off i love manjaro so far it does what i need to do but i want too go farther down into it but i cant.
First off 18 kde works lke a charm can boot into the live environment install and even upgrade al the way too latest.
the problem comes into play on 19 and now 20. the iso hags on startup an i am at a total loss how too fix this.
tride 2 different DVD an verified the iso checked out even installed kde 20 on sons IBM netbook.
tride the free an none free drivers hangs same spot I believe where it hangs is right before gong into the live desktop.
Now here is the kicker i also downloaded the architect version both 19 and 20 an they also hang but where they hang is enter user name an passwords.
I type manjaro an enter an system sits there for 15 or so min before it asks again for username an once again hangs for 15 then asks for password whereupon it gives input/output error an locks up.
The last thing i did try is installing virtual boxx and tride installing manjaro in vertual box the instiation went perfect. makes me think some knd of video card issue maybe/
system specs
nvidia 210 video card ibm mothrboaed with 32 gig of ram a an i5 2.6 ghz intel cpu.
I am positive something small I just cannt find it.
also if anyone knows how too invert colors of web pages an documents? I am slowly going blind an i can barly read web pages cause there to bright. black page with white text would be great thanks for an help.
Can we see the output of inxi -Fxxxz on the system you are having trouble with? If the Manjaro 18 ISO works, you can use that to get it.
I would just point out that Manjaro is rolling, so the difference between installing 18 then updating and installing 20 is mostly a different default theme. You could always just install that theme after updating from the 18 ISO. Remember the version numbers are mostly for the ISOs, they don't really have much meaning outside of that.
That being said, it is somewhat difficult to update the system from an 18 ISO so if you pulled that off without assistance, nice work!
:confetti_ball:
how do get hat for you.
Boot off the working live ISO, any version.
Open a terminal, type:
inxi -Fxxxz
Open a browser off the live ISO and post it here.
Thanks for the replies just got out o the hospitol. I tride the install 18 an then ugrade got a barly functioning system it boots but gives swap errors wont download teh nvidia drivers an just runs like poo.
So here is teh output you asked for dalto I dont know ho to make it look pretty though. I also put in different graphics card to see if that would work any better no dice.
Host: manjaro Kernel: 5.4.6-2-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.2.0 Desktop: KDE Plasma 5.17.4 tk: Qt 5.14.0 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Desktop Mobo: Intel model: DH55PJ v: AAE93812-303
  serial: <root required> BIOS: Intel v: TCIBX10H.86A.0044.2011.0120.1057
  date: 01/20/2011
  Device-1: hidpp_battery_0 model: Logitech M570 serial: 1028-a9-85-9a-ab
  charge: 100% rechargeable: yes status: Discharging
  Topology: Quad Core model: Intel Core i5 750 bits: 64 type: MCP
  arch: Nehalem rev: 5 L2 cache: 8192 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21285
  Speed: 1197 MHz min/max: 1197/2661 MHz boost: enabled
  Core speeds (MHz): 1: 1197 2: 1197 3: 1197 4: 1197
  Device-1: NVIDIA GF119 [GeForce GT 520] vendor: ASUSTeK driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:1040
  Display: x11 server: X.Org 1.20.6 driver: nouveau unloaded: modesetting
  alternate: fbdev,nv,vesa compositor: kwin_x11 resolution: 1366x768~60Hz
  OpenGL: renderer: NVD9 v: 4.3 Mesa 19.3.1 direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:3b56
  Device-2: NVIDIA GF119 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:0e08
  Sound Server: ALSA v: k5.4.6-2-MANJARO
  Device-1: Intel 82578DC Gigabit Network driver: e1000e v: 3.2.6-k
  port: f020 bus ID: 00:19.0 chip ID: 8086:10f0
  IF: eno1 state: down mac: 38:60:77:56:50:ef
  Device-2: Ralink RT3090 Wireless 802.11n 1T/1R PCIe vendor: Lite-On
  driver: rt2800pci v: 2.3.0 port: e000 bus ID: 03:00.0
  chip ID: 1814:3090
  IF: wlp3s0 state: down mac: d2:46:eb:3f:f4:3f
  Device-3: NetGear A6100 AC600 DB Wireless Adapter [Realtek RTL8811AU]
  type: USB driver: usb-network bus ID: 1-1.4:3 chip ID: 0846:9052
  serial: 00e04c000001
  Local Storage: total: 1.59 TiB used: 107.3 MiB (0.0%)
  ID-1: /dev/sda vendor: Seagate model: ST250DM000-1BC141
  size: 232.89 GiB speed: 3.0 Gb/s rotation: 7200 rpm serial: S2A1QN2R
  rev: JC4B scheme: MBR  Windows 10 exc;usive
  ID-2: /dev/sdb vendor: Seagate model: ST3500413AS size: 465.76 GiB
  speed: 3.0 Gb/s rotation: 7200 rpm serial: S2A3E36K rev: JC66
  scheme: MBR  Manjaro exclusive
  ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-60WN4A0
  size: 931.51 GiB speed: 3.0 Gb/s rotation: 7200 rpm
  serial: WD-WCC6Y1KHFAHY rev: 1A01 scheme: MBR
Partition: Ubuntu KDE exclusive
  ID-1: / size: 11.68 GiB used: 107.3 MiB (0.9%) fs: overlay
  source: ERR-102
  System Temperatures: cpu: 37.0 C mobo: N/A gpu: nouveau temp: 52 C
  Processes: 172 Uptime: 7m Memory: 15.57 GiB used: 620.7 MiB (3.9%)
  Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
  running in: konsole inxi: 3.0.37
All fixed.
strangest thing I hooked up external dvd an this fixed it well the dvd booted but then in order too install I had to disconect the internal dvd/
Once this was done the dvd booted and installed perfectly. The internal dvd must be having some kind of problem.
