I am unable to use my cursor after locking my screen. This happens on Kernel 5.10 and 5.9.
5.4 works without any issues. (I was separately facing some issues with snap packages here so I can’t go back to 5.4). Does this have anything to do with the Nvidia support?
Attaching inxi output for reference. Any help will be appreciated. Thanks in advance!
Kernel: 5.9.1-1-rt19-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.20.4 Distro: Manjaro Linux
Type: Laptop System: Dell product: Precision 5530 v: N/A serial: <filter>
Mobo: Dell model: 0NFGCT v: A00 serial: <filter> UEFI: Dell v: 1.16.2
date: 04/21/2020
ID-1: BAT0 charge: 59.7 Wh condition: 60.3/97.0 Wh (62%)
model: LGC-LGC8.33 DELL 5XJ2894 status: Charging
Info: 6-Core model: Intel Core i7-8850H bits: 64 type: MT MCP arch: Kaby Lake
note: check rev: A L2 cache: 9 MiB
bogomips: 62431
Speed: 800 MHz min/max: 800/4300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0
Device-2: NVIDIA GP107GLM [Quadro P1000 Mobile] vendor: Dell driver: N/A
bus ID: 01:00.0
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-12:4
Display: x11 server: X.Org 1.20.10 driver: modesetting unloaded: intel
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.9.1-1-rt19-MANJARO
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Bigfoot Networks driver: ath10k_pci v: kernel port: 3000
bus ID: 3b:00.0
IF: wlp59s0 state: up mac: <filter>
Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-4:2
Local Storage: total: 476.94 GiB used: 179.89 GiB (37.7%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC401 NVMe 512GB size: 476.94 GiB
temp: 33.9 C
ID-1: / size: 27.25 GiB used: 18.12 GiB (66.5%) fs: ext4 dev: /dev/nvme0n1p7
ID-2: /boot/efi size: 511 MiB used: 332 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p5
ID-3: /home size: 196.03 GiB used: 35.39 GiB (18.1%) fs: ext4
dev: /dev/nvme0n1p8
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p6
System Temperatures: cpu: 52.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2515 fan-2: 2488
Processes: 352 Uptime: 48m Memory: 15.27 GiB used: 3.94 GiB (25.8%)
Init: systemd Compilers: gcc: 10.2.0 Packages: 1377 Shell: Bash v: 5.1.0
inxi: 3.2.01
