I use xfburn, to burn audio CD’s.
The burn result is perfect, but the burn speed is very low, and it cannot be changed.
The function is grayed out and it does not display any speed.
How can the speed change be activated, to increase the speed?
No change in the GUI.
But, in the terminal this happen:
sudo xfburn
** Message: 16:32:35.336: Using UDEV
** Message: 16:32:39.058: Using gstreamer transcoder.
(xfburn:7252): dconf-WARNING **: 16:32:54.052: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.067: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.087: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.099: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.119: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.135: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.155: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.170: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.189: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.205: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.221: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.239: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.257: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.271: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:32:54.287: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.031: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.041: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.059: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.075: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.091: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.108: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.126: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.144: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.159: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.175: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.192: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.208: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.225: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.241: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.257: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:05.273: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.519: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.560: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.586: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.592: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.610: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.626: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.643: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.659: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.676: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.693: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.711: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:06.728: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:09.405: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:09.470: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:09.495: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:09.516: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:09.558: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:11.372: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:13.027: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.191: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.262: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.278: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.295: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.312: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.329: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.347: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.362: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.379: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.397: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.415: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.431: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:16.447: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:17.022: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:17.037: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:17.054: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:17.094: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): dconf-WARNING **: 16:33:17.095: failed to commit changes to dconf: Fel vid körning av kommandoraden ”dbus-launch --autolaunch=c6aee47fbf2d47599fe583bd3c36f941 --binary-syntax --close-stderr”: Barnprocess avslutades med kod 1
(xfburn:7252): libxfce4ui-CRITICAL **: 16:33:21.383: xfce_titled_dialog_update_icon: assertion 'icon_name != NULL' failed
