Manjaro KDE (17.0)
release-final
gellivara
#21
I just tried again by using the ‘button’ on the Manjaro Hello and it started but failed with same failed to format error for the / drive. It did format the /boot from the previous attempt.[quote=“artoo, post:20, topic:18957”]
Please reboot livecd.[/quote]Would it be OK to just do it now w/o reboot?
Setup to get desktop usable is a PITA due to the windows all being offscreen.
{edit
Assuming it is OK, am installing the dev version:
Packages (7) calamares-3.1.0-3 [removal] manjaro-efi-utils-20170307-1 manjaro-live-base-20170307-2 manjaro-live-skel-20170307-2 manjaro-live-systemd-20170307-2 manjaro-tools-base-0.14.6-1 calamares-dev-3.1.0.r3093.6bb046fa-2
#22
If
cat /etc/mtab
in live session shows any mounts in /tmp/calamares-some_id/
Then you either need to manually unmount them all, or reboot.
Sometimes calamares doesn’t unmount if it failed for some reason, so second start will crash partitioning, since stuff is still mounted and it can’t be formatted whatever.
#23
There are no mounts in /tmp except for tmpfs
[manjaro@manjaro ~]$ cat /etc/mtab|grep /tmp
tmpfs /tmp tmpfs rw,nosuid,nodev 0 0
[manjaro@manjaro ~]$ cat /etc/mtab|grep cala
It (calamares-dev) segfaulted on the first run:
[manjaro@manjaro ~]$ sudo -E calamares -d
16:53:02 [1]: Calamares version: 3.1.0.r3093.6bb046fa
Translation: Calamares: Using system locale: "en_US"
Translation: Qt: Using default locale, system locale one not found: "en_US"
16:53:02 [1]: Default font =====
Pixel size:    -1
Point size:    10
Point sizeF:   10
Font family:   "Noto Sans"
Metric height: 18
16:53:02 [1]: Font height: 18
16:53:02 [1]: Available languages: ("ar", "ast", "bg", "ca", "cs_CZ", "da", "de", "el", "en", "en_GB", "es_MX", "es", "eu", "fr", "hr", "hu", "id", "is", "it_IT", "ja", "lt", "nl", "pl", "pt_BR", "pt_PT", "ro", "ru", "sk", "sv", "th", "tr_TR", "zh_CN", "zh_TW")
m_crashReporterChar:  /usr/bin/../libexec/calamares_crash_reporter
m_crashReporterWChar: /usr/bin/../libexec/calamares_crash_reporter16:53:02 [1]: CalamaresApplication thread: 0x154a9d0
16:53:02 [1]: Using log file: "/home/manjaro/.cache/Calamares/Calamares/Calamares.log"
16:53:02 [1]: Using Calamares settings file at "/etc/calamares/settings.conf"
16:53:02 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
16:53:02 [1]: WARNING: the selected branding component does not ship translations.
16:53:02 [1]: Loaded branding component "manjaro"
16:53:02 [1]: STARTUP: initQmlPath, initSettings, initBranding done
16:53:02 [1]: STARTUP: initModuleManager: module init started
16:53:02 [1]: STARTUP: initModuleManager: all modules init done
16:53:02 [1]: STARTUP: initJobQueue done
16:53:02 [1]: Proposed window size: 1080 648
16:53:02 [1]: STARTUP: CalamaresWindow created; loadModules started
16:53:02 [1]: Initial locale  "en_US"
16:53:02 [8]: Translation: Calamares: Using system locale: "en_US"
16:53:02 [8]: Translation: Qt: Using default locale, system locale one not found: "en_US"
16:53:02 [1]: ViewModule "welcome@welcome" loading complete.
16:53:02 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file  OR  * a well-formed /etc/locale.gen     OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
16:53:02 [1]: ViewModule "locale@locale" loading complete.
16:53:02 [1]: ViewModule "keyboard@keyboard" loading complete.
16:53:02 [8]: Loaded backend plugin:  "pmlibpartedbackendplugin"
16:53:02 [1]: ViewModule "partition@partition" loading complete.
16:53:02 [1]: ViewModule "users@users" loading complete.
16:53:02 [1]: ViewModule "summary@summary" loading complete.
16:53:02 [1]: Module "partition@partition" already loaded.
16:53:02 [1]: QML import paths: ("/usr/share/calamares/qml", "/usr/bin", "qrc:/qt-project.org/imports", "/usr/lib/qt/qml")
16:53:02 [1]: LAST VS IS EVS!
16:53:02 [1]: Module "locale@locale" already loaded.
16:53:02 [1]: Module "keyboard@keyboard" already loaded.
16:53:02 [1]: Module "users@users" already loaded.
16:53:02 [0]: void Calamares::Module::loadConfigurationFile(const QString&) bad module configuration format "/usr/share/calamares/modules/umount.conf"
16:53:02 [1]: ViewModule "finished@finished" loading complete.
16:53:02 [1]: STARTUP: loadModules for all modules done
16:53:03 [1]: STARTUP: Window now visible and ProgressTreeView populated
16:53:03 [1]: Need at least storage bytes: 8482560409
16:53:03 [1]: Need at least ram bytes: 1073741824
16:53:03 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot:  true true true true true
16:53:03 [0]: QCoreApplication: Object event filter cannot be in a different thread.
No layout variant specified on the command line
Trailing -variant option ignored
16:53:03 [1]: xkbmap selection changed to:  "us" - ""
Dump file was written to: /tmp/408b8b3a-ec3c-e11c-159b3ee2-15f100ee.dmp
Translation: Calamares: Using default locale, system locale one not found: "en_US"
16:53:03 [1]: Arguments list: "/usr/bin/../libexec/calamares_crash_reporter, /tmp/408b8b3a-ec3c-e11c-159b3ee2-15f100ee.dmp, 6613, 11, Calamares, /usr/bin/calamares, 3.1.0.r3093.6bb046fa, 6622"
These are all our args: "/usr/bin/../libexec/calamares_crash_reporter, /tmp/408b8b3a-ec3c-e11c-159b3ee2-15f100ee.dmp, 6613, 11, Calamares, /usr/bin/calamares, 3.1.0.r3093.6bb046fa, 6622"
Segmentation fault
The next try started the installer.
#24
You find on the left hand bottom corner a button to open debug window.
Can you please try to capture a screenshot of the first tab?
Also some inxi info would help.
#25
Well did not see the reply until after started and completed the attempt but I did get these snapshots and the output of calamares -d.
Install failed; same error. (same pic as in previous post)
calamares -d:
16:59:29 [1]: Calamares version: 3.1.0.r3093.6bb046fa
16:59:29 [1]: Default font =====
Pixel size:    -1
Point size:    10
Point sizeF:   10
Metric height: 18
16:59:29 [1]: Font height: 18
16:59:29 [1]: Available languages: ("ar", "ast", "bg", "ca", "cs_CZ", "da", "de", "el", "en", "en_GB", "es_MX", "es", "eu", "fr", "hr", "hu", "id", "is", "it_IT", "ja", "lt", "nl", "pl", "pt_BR", "pt_PT", "ro", "ru", "sk", "sv", "th", "tr_TR", "zh_CN", "zh_TW")
m_crashReporterWChar: /usr/bin/../libexec/calamares_crash_reporter16:59:29 [1]: CalamaresApplication thread: 0x16f09d0
16:59:29 [1]: Using log file: "/home/manjaro/.cache/Calamares/Calamares/Calamares.log"
16:59:29 [1]: Using Calamares settings file at "/etc/calamares/settings.conf"
16:59:29 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
16:59:29 [1]: WARNING: the selected branding component does not ship translations.
16:59:29 [1]: Loaded branding component "manjaro"
16:59:29 [1]: STARTUP: initQmlPath, initSettings, initBranding done
16:59:29 [1]: STARTUP: initModuleManager: module init started
16:59:29 [1]: STARTUP: initModuleManager: all modules init done
16:59:29 [1]: STARTUP: initJobQueue done
16:59:29 [1]: Proposed window size: 1080 648
16:59:29 [1]: STARTUP: CalamaresWindow created; loadModules started
16:59:29 [1]: Initial locale  "en_US"
16:59:29 [8]: Translation: Calamares: Using system locale: "en_US"
16:59:29 [8]: Translation: Qt: Using default locale, system locale one not found: "en_US"
16:59:29 [1]: ViewModule "welcome@welcome" loading complete.
16:59:29 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file  OR  * a well-formed /etc/locale.gen     OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
16:59:29 [1]: ViewModule "locale@locale" loading complete.
16:59:30 [1]: ViewModule "keyboard@keyboard" loading complete.
16:59:30 [8]: Loaded backend plugin:  "pmlibpartedbackendplugin"
16:59:30 [1]: ViewModule "partition@partition" loading complete.
16:59:30 [1]: ViewModule "users@users" loading complete.
16:59:30 [1]: ViewModule "summary@summary" loading complete.
16:59:30 [1]: Module "partition@partition" already loaded.
16:59:30 [1]: QML import paths: ("/usr/share/calamares/qml", "/usr/bin", "qrc:/qt-project.org/imports", "/usr/lib/qt/qml")
16:59:30 [1]: LAST VS IS EVS!
16:59:30 [1]: Module "locale@locale" already loaded.
16:59:30 [1]: Module "keyboard@keyboard" already loaded.
16:59:30 [1]: Module "users@users" already loaded.
16:59:30 [0]: void Calamares::Module::loadConfigurationFile(const QString&) bad module configuration format "/usr/share/calamares/modules/umount.conf"
16:59:30 [1]: ViewModule "finished@finished" loading complete.
16:59:30 [1]: STARTUP: loadModules for all modules done
16:59:30 [1]: STARTUP: Window now visible and ProgressTreeView populated
16:59:30 [1]: Need at least storage bytes: 8482560409
16:59:30 [1]: Need at least ram bytes: 1073741824
16:59:30 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot:  true true true true true
16:59:30 [1]: xkbmap selection changed to:  "us" - ""
16:59:31 [1]: GeoIP reporting "America/Chicago"
23:59:31 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file  OR  * a well-formed /etc/locale.gen     OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
16:59:31 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file  OR  * a well-formed /etc/locale.gen     OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
16:59:42 [8]: getting bad sectors failed for  "/dev/sde" :  No such file or directory
16:59:46 [0]: blkid: unknown file system type  ""  on  "/dev/sde3"
16:59:47 [8]: getting bad sectors failed for  "/dev/sdf" :  No such file or directory
16:59:48 [0]: blkid: unknown file system type  ""  on  "/dev/sdf4"
16:59:48 [8]: getting smart status failed for  "/dev/sdg" :  Operation not supported
16:59:49 [1]: LIST OF DETECTED DEVICES:
node    capacity        name    prettyName
16:59:49 [1]: "/dev/sda" 1000202273280 "ATA HGST HTS721010A9" "ATA HGST HTS721010A9 – 931.51 GiB (/dev/sda)"
16:59:49 [1]: "/dev/sdb" 1000202273280 "ATA HGST HTS721010A9" "ATA HGST HTS721010A9 – 931.51 GiB (/dev/sdb)"
16:59:49 [1]: "/dev/sdc" 500105249280 "ATA Hitachi HTS72505" "ATA Hitachi HTS72505 – 465.76 GiB (/dev/sdc)"
16:59:49 [1]: "/dev/sdd" 500105249280 "ATA Hitachi HTS72505" "ATA Hitachi HTS72505 – 465.76 GiB (/dev/sdd)"
16:59:49 [1]: "/dev/sde" 480101368320 "ATA PNY CS2211 480GB" "ATA PNY CS2211 480GB – 447.13 GiB (/dev/sde)"
16:59:49 [1]: "/dev/sdf" 480101368320 "ATA PNY CS2211 480GB" "ATA PNY CS2211 480GB – 447.13 GiB (/dev/sdf)"
16:59:57 [1]: checking if "/dev/sde1" can be resized.
16:59:57 [1]: "/dev/sde1" seems like a good path
16:59:57 [1]: found Partition* for "/dev/sde1"
16:59:57 [1]: checking if "/dev/sde2" can be resized.
16:59:57 [1]: "/dev/sde2" seems like a good path
16:59:57 [1]: found Partition* for "/dev/sde2"
16:59:57 [1]: "Osprober lines, clean:\n/dev/sde1:Windows 8 (loader):Windows:chain\n/dev/sde2:Windows 8 (loader):Windows1:chain"
16:59:57 [1]: Updating partitioning state widgets.
16:59:57 [0]: QCoreApplication::postEvent: Unexpected null receiver
16:59:57 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
16:59:57 [1]: Required  storage B: 11166914969 "(10GB)"
16:59:57 [1]: Available storage B: 384560144896 "(358GB)" for "/dev/sda1"    length: 1953503937    sectorsUsed: 1202409904    fsType: "ntfs"
16:59:57 [1]: Partition "/dev/sda1" authorized for resize + autopartition install.
16:59:57 [1]: Required  storage B: 9019431321 "(8GB)"
16:59:57 [1]: Storage capacity  B: 1000194015744 "(931GB)" for "/dev/sda1"    length: 1953503937
16:59:57 [1]: Partition "/dev/sda1" authorized for replace install.
16:59:57 [1]: Updating partitioning preview widgets.
17:01:14 [1]: Updating partitioning preview widgets.
17:01:14 [0]: QCoreApplication::postEvent: Unexpected null receiver
17:01:18 [1]: Choice applied:  4
17:01:20 [1]: Clicked row 0
17:01:28 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sde"
17:01:28 [1]: PCM::setBootLoaderInstallPath "/dev/sde"
17:01:47 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
17:01:47 [1]: PCM::setBootLoaderInstallPath "/dev/sda"
17:01:47 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sde"
17:01:47 [1]: PCM::setBootLoaderInstallPath "/dev/sde"
17:02:06 [1]: Clicked row 1
17:02:21 [1]: old boundaries: 2048 1058815 1056768
17:02:21 [1]: new boundaries: 2048 1058815
17:02:21 [1]: dirty status: false
17:02:21 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
17:02:21 [1]: PCM::setBootLoaderInstallPath "/dev/sda"
17:02:21 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sde"
17:02:21 [1]: PCM::setBootLoaderInstallPath "/dev/sde"
17:05:16 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
17:05:16 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
17:05:16 [1]: Creating FillGlobalStorageJob with bootLoader path "/dev/sde"
17:05:16 [1]: PartitionCodeModule has been asked for jobs. About to return: "Clear all temporary mounts.\nClear mounts for partitioning operations on /dev/sde\nCreate new 50177MB partition on /dev/sde (ATA PNY CS2211 480GB) with file system ext4.\nSet partition information"
17:05:16 [1]: Gathering UUIDs for partitions that exist now.
17:05:17 [1]: QHash(("/dev/sdf4", "")("/dev/sdf3", "5c26342d-88e7-4ba8-8873-7f351582ede9")("/dev/sdb1", "461C541E1C540AF7")("/dev/sde1", "96F4D20BF4D1ED8D")("/dev/sdd1", "8EE84F3CE84F2237")("/dev/sde2", "5426068326066678")("/dev/sdf2", "ed7c27e1-4f01-4d91-9d45-a65cc3bcc75b")("/dev/sde4", "01b5c068-bd6c-47a2-aee8-e8a7c651a6b2")("/dev/sdf5", "959d5634-2db6-45e7-8611-e8e8e1906be1")("/dev/sde3", "")("/dev/sde5", "E68A6B148A6AE113")("/dev/sda1", "A4BC5231BC51FDEC")("", "")("/dev/sdc1", "7A48EF3D48EEF6B3")("/dev/sdf1", "B4A0A4B0A0A47B0E"))
17:05:17 [1]: Writing to GlobalStorage["partitions"]
17:05:17 [1]: "/dev/sda1" mtpoint: "" fs: QVariant(QString, "ntfs") "A4BC5231BC51FDEC"
17:05:17 [1]: "" mtpoint: "" fs: QVariant(QString, "unknown") ""
17:05:17 [1]: "/dev/sdb1" mtpoint: "" fs: QVariant(QString, "ntfs") "461C541E1C540AF7"
17:05:17 [1]: "/dev/sdc1" mtpoint: "" fs: QVariant(QString, "ntfs") "7A48EF3D48EEF6B3"
17:05:17 [1]: "/dev/sdd1" mtpoint: "" fs: QVariant(QString, "ntfs") "8EE84F3CE84F2237"
17:05:17 [1]: "/dev/sde4" mtpoint: "/boot" fs: QVariant(QString, "ext4") "01b5c068-bd6c-47a2-aee8-e8a7c651a6b2"
17:05:17 [1]: "" mtpoint: "/" fs: QVariant(QString, "ext4") ""
17:05:17 [1]: "/dev/sde1" mtpoint: "" fs: QVariant(QString, "ntfs") "96F4D20BF4D1ED8D"
17:05:17 [1]: "/dev/sde2" mtpoint: "" fs: QVariant(QString, "ntfs") "5426068326066678"
17:05:17 [1]: "/dev/sde3" mtpoint: "" fs: QVariant(QString, "extended") ""
17:05:17 [1]: "/dev/sde5" mtpoint: "" fs: QVariant(QString, "ntfs") "E68A6B148A6AE113"
17:05:17 [1]: "/dev/sdf1" mtpoint: "" fs: QVariant(QString, "ntfs") "B4A0A4B0A0A47B0E"
17:05:17 [1]: "/dev/sdf2" mtpoint: "" fs: QVariant(QString, "ext4") "ed7c27e1-4f01-4d91-9d45-a65cc3bcc75b"
17:05:17 [1]: "/dev/sdf3" mtpoint: "" fs: QVariant(QString, "btrfs") "5c26342d-88e7-4ba8-8873-7f351582ede9"
17:05:17 [1]: "/dev/sdf4" mtpoint: "" fs: QVariant(QString, "extended") ""
17:05:17 [1]: "/dev/sdf5" mtpoint: "" fs: QVariant(QString, "linuxswap") "959d5634-2db6-45e7-8611-e8e8e1906be1"
17:05:17 [8]: QVariant(QString, "A4BC5231BC51FDEC") "/dev/sda1" "" "ntfs"
17:05:17 [8]: QVariant(QString, "") "" "" "unknown"
17:05:17 [8]: QVariant(QString, "461C541E1C540AF7") "/dev/sdb1" "" "ntfs"
17:05:17 [8]: QVariant(QString, "7A48EF3D48EEF6B3") "/dev/sdc1" "" "ntfs"
17:05:17 [8]: QVariant(QString, "8EE84F3CE84F2237") "/dev/sdd1" "" "ntfs"
17:05:17 [8]: QVariant(QString, "01b5c068-bd6c-47a2-aee8-e8a7c651a6b2") "/dev/sde4" "/boot" "ext4"
17:05:17 [8]: QVariant(QString, "") "" "/" "ext4"
17:05:17 [8]: QVariant(QString, "96F4D20BF4D1ED8D") "/dev/sde1" "" "ntfs"
17:05:17 [8]: QVariant(QString, "5426068326066678") "/dev/sde2" "" "ntfs"
17:05:17 [8]: QVariant(QString, "") "/dev/sde3" "" "extended"
17:05:17 [8]: QVariant(QString, "E68A6B148A6AE113") "/dev/sde5" "" "ntfs"
17:05:17 [8]: QVariant(QString, "B4A0A4B0A0A47B0E") "/dev/sdf1" "" "ntfs"
17:05:17 [8]: QVariant(QString, "ed7c27e1-4f01-4d91-9d45-a65cc3bcc75b") "/dev/sdf2" "" "ext4"
17:05:17 [8]: QVariant(QString, "5c26342d-88e7-4ba8-8873-7f351582ede9") "/dev/sdf3" "" "btrfs"
17:05:17 [8]: QVariant(QString, "") "/dev/sdf4" "" "extended"
17:05:17 [8]: QVariant(QString, "959d5634-2db6-45e7-8611-e8e8e1906be1") "/dev/sdf5" "" "linuxswap"
17:05:17 [1]: Gathering UUIDs for partitions that exist now.
17:06:55 [1]: Creating FillGlobalStorageJob with bootLoader path "/dev/sde"
17:06:55 [1]: PartitionCodeModule has been asked for jobs. About to return: "Clear all temporary mounts.\nClear mounts for partitioning operations on /dev/sde\nCreate new 50177MB partition on /dev/sde (ATA PNY CS2211 480GB) with file system ext4.\nSet partition information"
17:06:55 [0]: Starting job "Clear all temporary mounts."
17:06:55 [1]: Opened mtab. Lines:
17:06:55 [1]: "proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0"
17:06:55 [1]: "sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0"
17:06:55 [1]: "dev /dev devtmpfs rw,nosuid,relatime,size=12330444k,nr_inodes=3082611,mode=755 0 0"
17:06:55 [1]: "run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0"
17:06:55 [1]: "/dev/sdg1 /run/miso/bootmnt iso9660 ro,relatime 0 0"
17:06:55 [1]: "cowspace /run/miso/cowspace tmpfs rw,relatime,size=262144k,mode=755 0 0"
17:06:55 [1]: "overlay_root /run/miso/overlay_root tmpfs rw,relatime,size=18512700k,mode=755 0 0"
17:06:55 [1]: "/dev/loop0 /run/miso/sfs/livefs squashfs ro,relatime 0 0"
17:06:55 [1]: "/dev/loop1 /run/miso/sfs/mhwdfs squashfs ro,relatime 0 0"
17:06:55 [1]: "/dev/loop2 /run/miso/sfs/desktopfs squashfs ro,relatime 0 0"
17:06:55 [1]: "/dev/loop3 /run/miso/sfs/rootfs squashfs ro,relatime 0 0"
17:06:55 [1]: "overlay / overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work 0 0"
17:06:55 [1]: "securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0"
17:06:55 [1]: "tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0"
17:06:55 [1]: "devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0"
17:06:55 [1]: "tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd 0 0"
17:06:55 [1]: "pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0"
17:06:55 [1]: "cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0"
17:06:55 [1]: "systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=34,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0"
17:06:55 [1]: "mqueue /dev/mqueue mqueue rw,relatime 0 0"
17:06:55 [1]: "debugfs /sys/kernel/debug debugfs rw,relatime 0 0"
17:06:55 [1]: "hugetlbfs /dev/hugepages hugetlbfs rw,relatime 0 0"
17:06:55 [1]: "tmpfs /tmp tmpfs rw,nosuid,nodev 0 0"
17:06:55 [1]: "configfs /sys/kernel/config configfs rw,relatime 0 0"
17:06:55 [1]: "tmpfs /etc/pacman.d/gnupg tmpfs rw,relatime,mode=755 0 0"
17:06:55 [1]: "fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0"
17:06:55 [1]: "tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=2468356k,mode=700,uid=1000,gid=1000 0 0"
17:06:55 [1]: "gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0"
17:06:55 [1]: ClearTempMountsJob finished. Here's what was done:
17:06:55 [0]: Starting job "Clear mounts for partitioning operations on /dev/sde"
17:06:56 [1]: ClearMountsJob finished. Here's what was done:
17:06:56 [0]: Starting job "Create new 50177MB partition on /dev/sde (ATA PNY CS2211 480GB) with file system ext4."
17:06:56 [0]: Installation failed:
17:06:56 [0]: - message: "The installer failed to create partition on disk 'ATA PNY CS2211 480GB'."
17:06:56 [0]: - details: "Failed to add partition ‘New Partition’ to device ‘/dev/sde’.\n\n\n\n"
17:07:50 [0]: Calamares will now quit.
17:07:50 [8]: Shutting down Calamares...
17:07:50 [8]: Finished shutdown.
17:07:50 [0]: QBasicTimer::start: QBasicTimer can only be used with threads started with QThread
inxi
[manjaro@manjaro ~]$ inxi -Fxxc 0
System:    Host: manjaro Kernel: 4.9.13-1-MANJARO x86_64 (64 bit gcc: 6.3.1)
           Desktop: KDE Plasma 5.9.3 (Qt 5.8.0) dm: sddm,sddm Distro: Manjaro Linux
Machine:   Device: server Mobo: Supermicro model: X8DTH v: 1234567890 BIOS: American Megatrends v: 2.1b date: 05/04/12
CPU(s):    2 Quad core Intel Xeon X5687s (-HT-MCP-SMP-) cache: 24576 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 57626
           clock speeds: min/max: 1600/3601 MHz 1: 1600 MHz 2: 1600 MHz 3: 1600 MHz 4: 1600 MHz 5: 1600 MHz
           6: 1600 MHz 7: 1600 MHz 8: 1600 MHz 9: 1600 MHz 10: 1600 MHz 11: 1600 MHz 12: 1600 MHz 13: 1600 MHz
           14: 1600 MHz 15: 1600 MHz 16: 1600 MHz
Graphics:  Card: NVIDIA GP106 [GeForce GTX 1060 6GB] bus-ID: 84:00.0 chip-ID: 10de:1c03
           Display Server: X.Org 1.19.2 driver: nvidia Resolution: 3840x2160@61.00hz
           GLX Renderer: GeForce GTX 1060 6GB/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 375.39 Direct Rendering: Yes
Audio:     Card-1 NVIDIA Device 10f1 driver: snd_hda_intel bus-ID: 84:00.1 chip-ID: 10de:10f1
           Card-2 C-Media CMI8788 [Oxygen HD Audio]
           driver: snd_virtuoso port: 9c00 bus-ID: 03:04.0 chip-ID: 13f6:8788
           Sound: Advanced Linux Sound Architecture v: k4.9.13-1-MANJARO
Network:   Card-1: Intel 82576 Gigabit Network Connection
           driver: igb v: 5.4.0-k port: 8c00 bus-ID: 01:00.0 chip-ID: 8086:10c9
           IF: enp1s0f0 state: up speed: 100 Mbps duplex: full mac: 00:25:90:63:a3:c4
           Card-2: Intel 82576 Gigabit Network Connection
           driver: igb v: 5.4.0-k port: 8800 bus-ID: 01:00.1 chip-ID: 8086:10c9
           IF: enp1s0f1 state: up speed: 100 Mbps duplex: full mac: 00:25:90:63:a3:c5
Drives:    HDD Total Size: 3992.4GB (0.1% used)
           ID-1: /dev/sda model: HGST_HTS721010A9 size: 1000.2GB serial: JS10076209HDUW
           ID-2: /dev/sdb model: HGST_HTS721010A9 size: 1000.2GB serial: JR100X4M0AGSNE
           ID-3: /dev/sdc model: Hitachi_HTS72505 size: 500.1GB serial: 091104PCE400VLG251LC
           ID-4: /dev/sdd model: Hitachi_HTS72505 size: 500.1GB serial: 091104PCE400VLG2KHVC
           ID-5: /dev/sde model: PNY_CS2211_480GB size: 480.1GB serial: PNY52152155430000DF9
           ID-6: /dev/sdf model: PNY_CS2211_480GB size: 480.1GB serial: PNY521521554300010B0
           ID-7: USB /dev/sdg model: Silicon size: 31.6GB serial: P1601731000000000000005400-0:0
Partition: ID-1: / size: 18G used: 498M (3%) fs: overlay dev: N/A
           ID-2: swap-1 size: 4.30GB used: 0.00GB (0%) fs: swap dev: /dev/sdf5
Sensors:   System Temperatures: cpu: 23.0C mobo: N/A gpu: 0.0:36C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 310 Uptime: 1:57 Memory: 1958.0/24105.1MB Init: systemd v: 232 Gcc sys: 6.3.1
           Client: Shell (bash 4.4.121 running in yakuake) inxi: 2.3.8
Got any ideas on why it won’t format the same partiton space that it formatted just a day ago with the KDE-rc3 calamares installer?
It is odd. It did format the /boot on the first attempt but it won’t do the / space.
KDE Partition Mgr agrees that /boot is formatted and the rest of the space for that partition is unallocated:
#26
I believe your dos filesystem table is borked, or partitons are somehow misaligned.
You shouldn’t have /dev/sde4 at the beginning, its primary partition, right?
Did you move at some point the entire ntfs partitions to create unallocated free space at the beginning?
#27
[quote=“artoo, post:26, topic:18957”]
You shouldn’t have /dev/sde4 at the beginning, its primary partition, right?[/quote]Numbers mean very little in linux.
The partition is the first and primary …Ah-ha! …wait.
i know why it fails.
One can only have 4 primary with MBR. The 4th is the Extended partition.
I had ext4 + windOS ‘SYSRESVD’ + windOS + extended as the primary partitions.
Now am trying to make the ext4 into two partitions and Calamares wants to make both as primary but it cannot.
It prbly should not have allowed me to select the unallocated to format as ext4 since it is supposed to be smarter than me, :smile:.
I’m glad it is smart enuf not to bork the rest of the partition table. WindOS is a pain but sometimes necessary for sanity checks. I’d rather not lose it just yet.
[/quote]Nope …well, sort-of: I installed Manjaro first then windOS however, I did delete and reformat the Manjaro that was 50GB to make it 49.5GB and add the SYSRESVD for windOS because MS did not make one during the initial install(yet it demands having it). That’s prbly where the renumbering occured.
Of course that does not explain the segfaults at startup.
#28
Looks really nice! Kudos to devs!
The display screen is still the wrong one.
It is creating a virtual desktop and making the empty display(right side) the screen that is displayed:
All windows open on the inaccessible screen. All panels are placed on that screen also.
The SDDM login apparently has the same issue as there was no keyboard or mouse action visible. I blindly typed the password with no echo in the password box and it accepted it.
I could not find the mouse pointer on the desktop until I right-clicked; the pointer then appeared.
Can you guys set the default for KDE “Display” to not enable all the connections that it thinks are displays :question: I.e., only enable the “Primary” display so it won’t dump us into screen/area that cannot be used.
That will work for everybody. Those relatively few that have multiple monitors can arrange the displays and enable those that they need,(which they probably do anyway). Those with only one display and connection do not have to do anything since that is the default for them anyway.
#29
Thank you, KDE of Manjaro is really really nice, KDE has Lots of customization, THANKS :slight_smile:
#30
Hi @Alpha, it seems to be an issue with some configurations. See also here. I’m glad you made it after all.
#31
Please send us your config files you may find in the KDE folder in your home-dir. We will take a look on them and may add adjustments to our default config if needed.
#32
@neognomic
You cud do the following to preserve existing partition structure with Windows Partitions intact and still install Manjaro. Linux does not necessarily need primary partition to install / run.
Note: I am referring to following Partition Table snapshot from ur earlier post on this thread.
https://postimg.cc/image/9r8ch6kcf/
  1. Delete /dev/sde4. Now Unallocated space wud increase to approx 49.5 GB
  2. Select Unallocated space and create new extended partition which shud be named as /dev/sde4 by Disk partitioning utility.
  3. Now create desired number of logical partitions and proceed with installation.
#33
To me it happens to me exactly the same and also I was left the black screen. I had to turn off the laptop by pressing the button. It did not respond to anything.
#34
Can you confirm the 17.0 iso’s have the updated mhwd-db as there seem to be a lot of threads with nvidia not working.
@philm
#35
Thanks so much for the effort! It’s a good idea and one I did consider. I have several Linux installed to extended partition so is not new for me but decided to just KISS and make one ext4.
#36
[quote=“philm, post:31, topic:18957”]
Please send us your config files …[/quote]OK, I can do that!
You mean the fixed KDE 17.0 configs, correct :question:
And, pardon my ignorance, but ‘send’ the ~/.config where :question:
…or do y’all want some specific files? I confess that I do not know where systemsettings5 stores the display config information(more ignorance). …
And, again, thanks for all you and the other devs in Manjaro Team do to make this available to us!
#38
I run Jack. Is there any advantage or great difference for me in running RT scheduling or selecting a realtime kernal?
#39
Seems like cups is broken again tho :frowning:
I cannot connect to to my printer again.
Arch does it again, sigh.
Back to linux mint as i cannot even be bothered to fix it this time
I just remember how much of a pain in the ass to fix my printer the last time and dont feel like it.
#40
You’d be the perfect guy to test this out for us, since you run jack and most of us don’t. Are you noticing issues that you think a realtime kernel might fix, video editing delays, sound issues, etc?
Using Manjaro Settings Manager swapping kernels is easy to do AND UNDO.
#41
I run i3 and followed this tutorial (How to replace Pulseaudio with Jack, Jack and PulseAudio Together as Friend) and can say that I now have the best audio quality on any linux distro. I don’t do any video.
On the basis of “if it aint broke don’t fix it” I can’t help fixing it and see what happens :slight_smile:
