Manjaro KDE (17.0)
release-final
gellivara
#1
Manjaro Fringilla was a great release! Now we are proud to announce our current stable release we call “Gellivara”. It took us more than three months to prepare this new release series for 2017.
Our KDE edition continues to deliver this powerful, mature and feature-rich desktop environment with a unique look-and-feel, and with the perks of Manjaro’s latest tools. We ship now Plasma 5.9 desktop in combination with the latest KDE-Apps 16.12. It was a huge step to get it all playing together smoothly and to give the user experience the same feeling as our KDE4 editions of the past.
The Manjaro Settings Manager (MSM) now provides an easy-to-use graphical interface for installing and removing the many series of kernels we offer. Manjaro’s selection of readily available kernels remains the most extensive of all Linux distribution we know of. At the time of this release, nine kernel-series are available directly from our binary repositories, ranging from the mature & rock-solid 3.10 series to the latest 4.10 release. Additionally we offer two realtime kernel series. Such a wide array of available kernel options results in extensive hardware support, getting the most out of your system for you, be it old or new.
Features of the new release Gellivara:
  • We updated the stock kernel to linux49 4.9 LTS
  • We updated the Xorg-Stack to v1.19 series
  • We enhanced and improved our Manjaro Tools & Profiles
  • MHWD we adopted a more efficient way to handle libglx binaries
  • Some of our themes got updated and new got designed
Changes since RC3 release:
  • fixed an issue with glx and nvidia driver
  • Plasma 5.9.3
  • Manjaro-Settings-Manager 0.5.1
  • Mesa 17.0.1
  • Xorg-Server 1.19.2
Changes since RC2 release:
  • without plymouth installed
  • kernel v4.9.13
  • newer linux-firmware
  • wayland v1.13.0
  • fixes to octopi
Changes since RC1 release:
  • updated Breath wallpaper
  • updated gstreamer packages
  • updated mesa-stack
  • updated documentation
  • [CAL] Add optional config value neverCreateSwap in partition module.
  • [CAL] Improve EFI configuration check in grubcfg.
  • [CAL] Improve EFI configuration check in bootloader.
  • [CAL] fixed two bugs in packages module
Changes since Beta3 release:
  • Plasma 5.9.2
  • KDE Frameworks 5.31.0
  • Full profile
Changes since Beta2 release:
  • Plasma 5.9.1
  • KDE Apps 16.12.2
  • VLC Nightly added
  • Manjaro Hello 0.4.10
  • Fixed some crashing issues with Xorg-Server
  • [CAL] partition: use always double click to activate a partition tree view item
  • [CAL] netinstall: moved module to a tree based UI
  • [CAL] welcome: Add fallback check for internet connection
  • [CAL] partition: Don’t hardcode /dev/sd* as device path.
  • [CAL] packages: Make try_{install,remove} more robust.
Changes since Beta1 release:
  • Plasma 5.9.0
  • Mesa 13.0.4
  • Manjaro Settings-Manager 0.5.0
  • Network Manager 1.6.0
  • Octopi 0.8.7
  • QT 5.8.0
  • [CAL] fix for an issue in the users module, which could break login if the chosen password had non-Latin1 characters
  • [CAL] proper exception handling in the networkcfg module
  • [CAL] improved autologin configuration handling for sddm.
Changes since Alpha releases:
  • fixes for EFI installation
  • gcc updated to v6.3.1
  • xorg-stack v1.19
  • KDE Apps v16.12.1
  • KDE Framework v5.30
  • Calamares 3.0 includes countless fixes and improvements to the core application and to the modules, as well as an all new PythonQt-based module interface. The PythonQt interface is optional, and allows module developers to create view modules in Python with Qt.
We hope you enjoy this release and let us know what you think of Gellivara. Our latest install media, you can find them on SF.net.
Going for the jugular
#2
A lot of work went into this release.
Congrats to @philm and all the devs and contributers who have toiled hard to produce this quality live environment and GUI installer.
#3
how can one trigger that the text on that page is edited?
it still lists KDE as community-edition:
http://distrowatch.com/table.php?distribution=manjaro
#4
great…now i have to wait 6 hours to get home so i can try it…
#5
Many thanks to all the developers for the effort made. I want to try it.
regards…
#6
Congrats @philm ! Great release :grinning:
#7
@philm KDE Apps version is 16.12.2 or 16.12.3
I did sudo pacman -Syyu
400+ MB of download and KDE apps like Dolphin and Kate says Version 16.12.2.
Also change log on this post shows Apps are at 16.12.2 but news post says 16.12.3.
#8
16.12.2…
16.12.3 is scheduled to be release on march 9th
#9
Thanks. News post for Manjaro 17 KDE requires correction on following URL https://manjaro.org/2017/03/07/manjaro-kde-17-0-released/
It says - “We updated KDE to its latest components: Plasma 5.9.3, Apps 16.12.3, Framework 5.31.0”
#10
Hi,
I have approximately a 5 month old Manjaro stable installation which is updated with all released updates.
Screenfetch told me that I am using Manjaro 17.0. This is what I expect.
I am wondering that one of the latest update does not update the kernel from 4.4 to 4.9 because 4.9 is the new default kernel.
Another strange thing is that Manjaro-setings-manager shows me always kernel 4.4 as default.
Is this a ordinary behaviour?
After Kernel update error at bootup
#11
that kernel branche does not change? yes it’s the normal behavior. if you want to change you can do it when you want. as simple as to click on install in Manjaro settings manager. Once manjaro is installed there is not update that will change or install a new kernel branche. it’s up to the user.
that MSM still show kernel 4.4 as recommended. yes it’s also normal it still didn’t changed in MSM (it will change certainly soon in a next MSM update)
#12
Thanks to everyone for working so hard to bring this release through to final. It’s amazing to see the level of enthusiasm and dedication here, more so for the spirit in which it’s done.
From someone who is visually impaired and uses Manjaro as a tool to make daily life better, THANK YOU.!! You make a difference to people’s lives in ways you may not imagine.
#13
I have installed recently the Manjaro KDE 17.0-rc3. Now that the 17 stable has been released do i have to install again from the start or the RC3 with the updates in Octopi has install the stable version? Sorry for the question but i am total newbie :slight_smile:
#14
Thank you all! Congrats!!
#15
@andreasdimo Just install the updates, and you’ll have the same thing.
#16
I’m downloading the torrent now and quite impressed that it has 76 seeds already.
#17
It took quite a hassle to install. Everytime i open Calamares it crashed. After around 10 time opening and closing I was able to install it. terminal result below:
sudo calamares
20:02:34 [1]: Calamares version: 3.1.0
Translation: Calamares: Using system locale: "en_US"
Translation: Qt: Using default locale, system locale one not found: "en_US"
20:02:34 [1]: Default font =====
Pixel size:    -1
Point size:    9
Point sizeF:   9
Font family:   "Sans Serif"
Metric height: 14
20:02:34 [1]: Font height: 14
20:02:34 [1]: Available languages: ("ar", "ast", "bg", "ca", "cs_CZ", "da", "de", "el", "en", "en_GB", "es_MX", "es", "eu", "fr", "hr", "hu", "id", "is", "it_IT", "ja", "lt", "nl", "pl", "pt_BR", "pt_PT", "ro", "ru", "sk", "sv", "th", "tr_TR", "zh_CN", "zh_TW")
20:02:34 [1]: CalamaresApplication thread: 0xd19d00
20:02:34 [1]: Using log file: "/root/.cache/Calamares/Calamares/Calamares.log"
20:02:34 [1]: Using Calamares settings file at "/etc/calamares/settings.conf"
20:02:34 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
20:02:34 [1]: WARNING: the selected branding component does not ship translations.
20:02:34 [1]: Loaded branding component "manjaro"
20:02:34 [1]: STARTUP: initQmlPath, initSettings, initBranding done
20:02:34 [1]: STARTUP: initModuleManager: module init started
20:02:34 [1]: STARTUP: initModuleManager: all modules init done
20:02:34 [1]: STARTUP: initJobQueue done
20:02:34 [1]: Proposed window size: 1010 520
20:02:34 [1]: STARTUP: CalamaresWindow created; loadModules started
20:02:34 [1]: Initial locale  "en_US"
20:02:34 [1]: ViewModule "welcome@welcome" loading complete.
20:02:34 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file       OR  * a well-formed /etc/locale.gen     OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
20:02:34 [1]: ViewModule "locale@locale" loading complete.
20:02:34 [1]: ViewModule "keyboard@keyboard" loading complete.
20:02:34 [1]: ViewModule "partition@partition" loading complete.
20:02:34 [1]: ViewModule "users@users" loading complete.
20:02:34 [1]: ViewModule "summary@summary" loading complete.
20:02:34 [1]: Module "partition@partition" already loaded.
20:02:34 [1]: QML import paths: ("/usr/share/calamares/qml", "/usr/bin", "qrc:/qt-project.org/imports", "/usr/lib/qt/qml")
20:02:34 [1]: LAST VS IS EVS!
20:02:34 [1]: Module "locale@locale" already loaded.
20:02:34 [1]: Module "keyboard@keyboard" already loaded.
20:02:34 [1]: Module "users@users" already loaded.
20:02:34 [0]: void Calamares::Module::loadConfigurationFile(const QString&) bad module configuration format "/usr/share/calamares/modules/umount.conf"
20:02:34 [1]: ViewModule "finished@finished" loading complete.
20:02:34 [1]: STARTUP: loadModules for all modules done
20:02:36 [1]: STARTUP: Window now visible and ProgressTreeView populated
20:02:36 [1]: Need at least storage bytes: 8482560409
20:02:36 [1]: Need at least ram bytes: 1073741824
20:02:36 [1]: A battery exists, checking for mains power.
20:02:36 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot:  true true true true true
No layout variant specified on the command line
Trailing -variant option ignored
20:02:36 [1]: xkbmap selection changed to:  "us" - ""
Segmentation fault
[manjaro@manjaro ~]$ sudo calamares
20:03:12 [1]: Calamares version: 3.1.0
20:03:12 [1]: Default font =====
Pixel size:    -1
Point size:    9
Point sizeF:   9
Metric height: 14
20:03:12 [1]: Font height: 14
20:03:12 [1]: Available languages: ("ar", "ast", "bg", "ca", "cs_CZ", "da", "de", "el", "en", "en_GB", "es_MX", "es", "eu", "fr", "hr", "hu", "id", "is", "it_IT", "ja", "lt", "nl", "pl", "pt_BR", "pt_PT", "ro", "ru", "sk", "sv", "th", "tr_TR", "zh_CN", "zh_TW")
20:03:12 [1]: CalamaresApplication thread: 0xd6ed00
20:03:12 [1]: Using log file: "/root/.cache/Calamares/Calamares/Calamares.log"
20:03:12 [1]: Using Calamares settings file at "/etc/calamares/settings.conf"
20:03:12 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
20:03:12 [1]: WARNING: the selected branding component does not ship translations.
20:03:12 [1]: Loaded branding component "manjaro"
20:03:12 [1]: STARTUP: initQmlPath, initSettings, initBranding done
20:03:12 [1]: STARTUP: initModuleManager: module init started
20:03:12 [1]: STARTUP: initModuleManager: all modules init done
20:03:12 [1]: STARTUP: initJobQueue done
20:03:12 [1]: Proposed window size: 1010 520
20:03:12 [1]: STARTUP: CalamaresWindow created; loadModules started
20:03:12 [1]: Initial locale  "en_US"
20:03:12 [1]: ViewModule "welcome@welcome" loading complete.
20:03:12 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file      OR  * a well-formed /etc/locale.gen OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
20:03:12 [1]: ViewModule "locale@locale" loading complete.
20:03:12 [1]: ViewModule "keyboard@keyboard" loading complete.
20:03:13 [1]: ViewModule "partition@partition" loading complete.
20:03:13 [1]: ViewModule "users@users" loading complete.
20:03:13 [1]: ViewModule "summary@summary" loading complete.
20:03:13 [1]: Module "partition@partition" already loaded.
20:03:13 [1]: QML import paths: ("/usr/share/calamares/qml", "/usr/bin", "qrc:/qt-project.org/imports", "/usr/lib/qt/qml")
20:03:13 [1]: LAST VS IS EVS!
20:03:13 [1]: Module "locale@locale" already loaded.
20:03:13 [1]: Module "keyboard@keyboard" already loaded.
20:03:13 [1]: Module "users@users" already loaded.
20:03:13 [0]: void Calamares::Module::loadConfigurationFile(const QString&) bad module configuration format "/usr/share/calamares/modules/umount.conf"
20:03:13 [1]: ViewModule "finished@finished" loading complete.
20:03:13 [1]: STARTUP: loadModules for all modules done
20:03:14 [1]: STARTUP: Window now visible and ProgressTreeView populated
20:03:14 [1]: Need at least storage bytes: 8482560409
20:03:14 [1]: Need at least ram bytes: 1073741824
20:03:15 [1]: A battery exists, checking for mains power.
20:03:15 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot:  true true true true true
Segmentation fault
#18
@philm
The ‘black screen’ is fixed. Yeah!
Thank you!
The intial desktop looks like this:
Yep, there are no windows, panel or any access to them. I opened konsole, systemsettings5, as well as created two(2) panels and they are all placed offscreen with no access to them, :confounded:.
Thru manipulation of my monitor’s setup I was able to get the desktop display in the viewable area/screen and FIX the KDE System Settings “Display” so that the primary display is also the onscreen display.
This is all caused because the deafult setup creates one HUGE virtual desktop and makes the primary display screen the screen that is not viewable/available.
… a major headache for anyone with multiple connections from graphics card to monitor.
Once I got that fixed, I ran the installer. The segfault that was occuring at first use is no more. Yeah!
But the installer failed:
I did not do anything very special. I used the same partition that I had used before(w/ KDE-17-rc3). Rather than use the whole partition for / I split the parttion into /boot and / and told it to format each as ext4. It failed.
I’ve done this setup(/boot and /) hundreds if not thousands of times over the years with other installers and did it for 16.10.3 install(as ext4 and btrfs). It should just work.
Here’s the calamares debug output
[manjaro@manjaro ~]$ sudo -E calamares -d
21:42:16 [1]: Calamares version: 3.1.0
21:42:16 [1]: Default font =====
Pixel size:    -1
Point size:    10
Point sizeF:   10
Font family:   "Noto Sans"
Metric height: 18
21:42:16 [1]: Font height: 18
21:42:16 [1]: Available languages: ("ar", "ast", "bg", "ca", "cs_CZ", "da", "de", "el", "en", "en_GB", "es_MX", "es", "eu", "fr", "hr", "hu", "id", "is", "it_IT", "ja", "lt", "nl", "pl", "pt_BR", "pt_PT", "ro", "ru", "sk", "sv", "th", "tr_TR", "zh_CN", "zh_TW")
21:42:16 [1]: CalamaresApplication thread: 0x14499d0
21:42:16 [1]: Using log file: "/home/manjaro/.cache/Calamares/Calamares/Calamares.log"
21:42:16 [1]: Using Calamares settings file at "/etc/calamares/settings.conf"
21:42:16 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
21:42:16 [1]: WARNING: the selected branding component does not ship translations.
21:42:16 [1]: Loaded branding component "manjaro"
21:42:17 [1]: STARTUP: initQmlPath, initSettings, initBranding done
21:42:17 [1]: STARTUP: initModuleManager: module init started
21:42:17 [1]: STARTUP: initModuleManager: all modules init done
21:42:17 [1]: STARTUP: initJobQueue done
21:42:17 [1]: Proposed window size: 1080 648
21:42:17 [1]: STARTUP: CalamaresWindow created; loadModules started
21:42:17 [1]: Initial locale  "en_US"
21:42:17 [8]: Translation: Calamares: Using system locale: "en_US"
21:42:17 [8]: Translation: Qt: Using default locale, system locale one not found: "en_US"
21:42:17 [1]: ViewModule "welcome@welcome" loading complete.
21:42:17 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file  OR  * a well-formed /etc/locale.gen     OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
21:42:17 [1]: ViewModule "locale@locale" loading complete.
21:42:18 [1]: ViewModule "keyboard@keyboard" loading complete.
21:42:18 [8]: Loaded backend plugin:  "pmlibpartedbackendplugin"
21:42:18 [1]: ViewModule "partition@partition" loading complete.
21:42:18 [1]: ViewModule "users@users" loading complete.
21:42:18 [1]: ViewModule "summary@summary" loading complete.
21:42:18 [1]: Module "partition@partition" already loaded.
21:42:18 [1]: QML import paths: ("/usr/share/calamares/qml", "/usr/bin", "qrc:/qt-project.org/imports", "/usr/lib/qt/qml")
21:42:18 [1]: LAST VS IS EVS!
21:42:18 [1]: Module "locale@locale" already loaded.
21:42:18 [1]: Module "keyboard@keyboard" already loaded.
21:42:18 [1]: Module "users@users" already loaded.
21:42:18 [0]: void Calamares::Module::loadConfigurationFile(const QString&) bad module configuration format "/usr/share/calamares/modules/umount.conf"
21:42:18 [1]: ViewModule "finished@finished" loading complete.
21:42:18 [1]: STARTUP: loadModules for all modules done
21:42:18 [1]: STARTUP: Window now visible and ProgressTreeView populated
21:42:18 [1]: Need at least storage bytes: 8482560409
21:42:18 [1]: Need at least ram bytes: 1073741824
21:42:18 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot:  true true true true true
21:42:18 [1]: xkbmap selection changed to:  "us" - ""
21:42:19 [1]: GeoIP reporting "America/Chicago"
22:42:19 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file  OR  * a well-formed /etc/locale.gen     OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
15:42:19 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file  OR  * a well-formed /etc/locale.gen     OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
15:42:31 [8]: getting bad sectors failed for  "/dev/sde" :  No such file or directory
15:42:33 [0]: blkid: unknown file system type  ""  on  "/dev/sde3"
15:42:34 [8]: getting bad sectors failed for  "/dev/sdf" :  No such file or directory
15:42:34 [0]: blkid: unknown file system type  ""  on  "/dev/sdf4"
15:42:34 [8]: getting smart status failed for  "/dev/sdg" :  Operation not supported
15:42:36 [1]: LIST OF DETECTED DEVICES:
node    capacity        name    prettyName
15:42:36 [1]: "/dev/sda" 1000202273280 "ATA HGST HTS721010A9" "ATA HGST HTS721010A9 – 931.51 GiB (/dev/sda)"
15:42:36 [1]: "/dev/sdb" 1000202273280 "ATA HGST HTS721010A9" "ATA HGST HTS721010A9 – 931.51 GiB (/dev/sdb)"
15:42:36 [1]: "/dev/sdc" 500105249280 "ATA Hitachi HTS72505" "ATA Hitachi HTS72505 – 465.76 GiB (/dev/sdc)"
15:42:36 [1]: "/dev/sdd" 500105249280 "ATA Hitachi HTS72505" "ATA Hitachi HTS72505 – 465.76 GiB (/dev/sdd)"
15:42:36 [1]: "/dev/sde" 480101368320 "ATA PNY CS2211 480GB" "ATA PNY CS2211 480GB – 447.13 GiB (/dev/sde)"
15:42:36 [1]: "/dev/sdf" 480101368320 "ATA PNY CS2211 480GB" "ATA PNY CS2211 480GB – 447.13 GiB (/dev/sdf)"
15:42:44 [1]: checking if "/dev/sde1" can be resized.
15:42:44 [1]: "/dev/sde1" seems like a good path
15:42:44 [1]: found Partition* for "/dev/sde1"
15:42:44 [1]: checking if "/dev/sde2" can be resized.
15:42:44 [1]: "/dev/sde2" seems like a good path
15:42:44 [1]: found Partition* for "/dev/sde2"
15:42:45 [1]: checking if "/dev/sde4" can be resized.
15:42:45 [1]: "/dev/sde4" seems like a good path
15:42:45 [1]: found Partition* for "/dev/sde4"
15:42:45 [1]: "Osprober lines, clean:\n/dev/sde1:Windows 8 (loader):Windows:chain\n/dev/sde2:Windows 8 (loader):Windows1:chain\n/dev/sde4:Manjaro Linux (17.0-rc3):ManjaroLinux:linux"
15:42:45 [1]: Updating partitioning state widgets.
15:42:45 [0]: QCoreApplication::postEvent: Unexpected null receiver
15:42:45 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
15:42:45 [1]: Required  storage B: 11166914969 "(10GB)"
15:42:45 [1]: Available storage B: 384560144896 "(358GB)" for "/dev/sda1"    length: 1953503937    sectorsUsed: 1202409904    fsType: "ntfs"
15:42:45 [1]: Partition "/dev/sda1" authorized for resize + autopartition install.
15:42:45 [1]: Required  storage B: 9019431321 "(8GB)"
15:42:45 [1]: Storage capacity  B: 1000194015744 "(931GB)" for "/dev/sda1"    length: 1953503937
15:42:45 [1]: Partition "/dev/sda1" authorized for replace install.
15:42:45 [1]: Updating partitioning preview widgets.
15:45:38 [1]: Updating partitioning preview widgets.
15:45:38 [0]: QCoreApplication::postEvent: Unexpected null receiver
15:45:45 [1]: Updating partitioning state widgets.
15:45:45 [0]: QCoreApplication::postEvent: Unexpected null receiver
15:45:45 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
15:45:45 [1]: Required  storage B: 11166914969 "(10GB)"
15:45:45 [1]: Available storage B: 1048576 "(0GB)" for "/dev/sde3"    length: 727937024    sectorsUsed: 727934976    fsType: "extended"
15:45:45 [1]: Available storage B: 358094266368 "(333GB)" for "/dev/sde5"    length: 727934976    sectorsUsed: 28532112    fsType: "ntfs"
15:45:45 [1]: Partition "/dev/sde5" authorized for resize + autopartition install.
15:45:45 [1]: Required  storage B: 9019431321 "(8GB)"
15:45:45 [1]: Storage capacity  B: 53154414592 "(49GB)" for "/dev/sde4"    length: 103817216
15:45:45 [1]: Partition "/dev/sde4" authorized for replace install.
15:45:45 [1]: Updating partitioning preview widgets.
15:45:47 [1]: Clicked row 0
15:45:48 [1]: Clicked row 0
15:45:57 [1]: Choice applied:  4
15:46:15 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sde"
15:46:15 [1]: PCM::setBootLoaderInstallPath "/dev/sde"
15:46:24 [1]: Clicked row 0
15:49:31 [1]: old boundaries: 2048 103819263 103817216
15:49:31 [1]: new boundaries: 2048 1058815
15:49:31 [1]: dirty status: true
15:49:31 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
15:49:31 [1]: PCM::setBootLoaderInstallPath "/dev/sda"
15:49:31 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sde"
15:49:31 [1]: PCM::setBootLoaderInstallPath "/dev/sde"
15:49:36 [1]: Clicked row 1
15:49:48 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sde"
15:49:48 [1]: PCM::setBootLoaderInstallPath "/dev/sde"
15:50:07 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
15:50:07 [1]: PCM::setBootLoaderInstallPath "/dev/sda"
15:50:07 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sde"
15:50:07 [1]: PCM::setBootLoaderInstallPath "/dev/sde"
15:51:55 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
15:51:55 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
15:51:55 [1]: Creating FillGlobalStorageJob with bootLoader path "/dev/sde"
15:51:55 [1]: PartitionCodeModule has been asked for jobs. About to return: "Clear all temporary mounts.\nClear mounts for partitioning operations on /dev/sde\nDelete partition /dev/sde4.\nCreate new 516MB partition on /dev/sde (ATA PNY CS2211 480GB) with file system ext4.\nSet flags on 516MB ext4 partition.\nCreate new 50177MB partition on /dev/sde (ATA PNY CS2211 480GB) with file system ext4.\nSet partition information"
15:51:55 [1]: Gathering UUIDs for partitions that exist now.
15:51:56 [1]: QHash(("/dev/sdf5", "959d5634-2db6-45e7-8611-e8e8e1906be1")("", "")("/dev/sdd1", "8EE84F3CE84F2237")("/dev/sdf2", "ed7c27e1-4f01-4d91-9d45-a65cc3bcc75b")("/dev/sdf3", "5c26342d-88e7-4ba8-8873-7f351582ede9")("/dev/sde5", "E68A6B148A6AE113")("/dev/sda1", "A4BC5231BC51FDEC")("/dev/sdb1", "461C541E1C540AF7")("/dev/sde2", "5426068326066678")("/dev/sdf1", "B4A0A4B0A0A47B0E")("/dev/sde3", "")("/dev/sde1", "96F4D20BF4D1ED8D")("/dev/sdf4", "")("/dev/sdc1", "7A48EF3D48EEF6B3"))
15:51:56 [1]: Writing to GlobalStorage["partitions"]
15:51:56 [1]: "/dev/sda1" mtpoint: "" fs: QVariant(QString, "ntfs") "A4BC5231BC51FDEC"
15:51:56 [1]: "" mtpoint: "" fs: QVariant(QString, "unknown") ""
15:51:56 [1]: "/dev/sdb1" mtpoint: "" fs: QVariant(QString, "ntfs") "461C541E1C540AF7"
15:51:56 [1]: "/dev/sdc1" mtpoint: "" fs: QVariant(QString, "ntfs") "7A48EF3D48EEF6B3"
15:51:56 [1]: "/dev/sdd1" mtpoint: "" fs: QVariant(QString, "ntfs") "8EE84F3CE84F2237"
15:51:56 [1]: "" mtpoint: "/boot" fs: QVariant(QString, "ext4") ""
15:51:56 [1]: "" mtpoint: "/" fs: QVariant(QString, "ext4") ""
15:51:56 [1]: "/dev/sde1" mtpoint: "" fs: QVariant(QString, "ntfs") "96F4D20BF4D1ED8D"
15:51:56 [1]: "/dev/sde2" mtpoint: "" fs: QVariant(QString, "ntfs") "5426068326066678"
15:51:56 [1]: "/dev/sde3" mtpoint: "" fs: QVariant(QString, "extended") ""
15:51:56 [1]: "/dev/sde5" mtpoint: "" fs: QVariant(QString, "ntfs") "E68A6B148A6AE113"
15:51:56 [1]: "/dev/sdf1" mtpoint: "" fs: QVariant(QString, "ntfs") "B4A0A4B0A0A47B0E"
15:51:56 [1]: "/dev/sdf2" mtpoint: "" fs: QVariant(QString, "ext4") "ed7c27e1-4f01-4d91-9d45-a65cc3bcc75b"
15:51:56 [1]: "/dev/sdf3" mtpoint: "" fs: QVariant(QString, "btrfs") "5c26342d-88e7-4ba8-8873-7f351582ede9"
15:51:56 [1]: "/dev/sdf4" mtpoint: "" fs: QVariant(QString, "extended") ""
15:51:56 [1]: "/dev/sdf5" mtpoint: "" fs: QVariant(QString, "linuxswap") "959d5634-2db6-45e7-8611-e8e8e1906be1"
15:51:56 [8]: QVariant(QString, "A4BC5231BC51FDEC") "/dev/sda1" "" "ntfs"
15:51:56 [8]: QVariant(QString, "") "" "" "unknown"
15:51:56 [8]: QVariant(QString, "461C541E1C540AF7") "/dev/sdb1" "" "ntfs"
15:51:56 [8]: QVariant(QString, "7A48EF3D48EEF6B3") "/dev/sdc1" "" "ntfs"
15:51:56 [8]: QVariant(QString, "8EE84F3CE84F2237") "/dev/sdd1" "" "ntfs"
15:51:56 [8]: QVariant(QString, "") "" "/boot" "ext4"
15:51:56 [8]: QVariant(QString, "") "" "/" "ext4"
15:51:56 [8]: QVariant(QString, "96F4D20BF4D1ED8D") "/dev/sde1" "" "ntfs"
15:51:56 [8]: QVariant(QString, "5426068326066678") "/dev/sde2" "" "ntfs"
15:51:56 [8]: QVariant(QString, "") "/dev/sde3" "" "extended"
15:51:56 [8]: QVariant(QString, "E68A6B148A6AE113") "/dev/sde5" "" "ntfs"
15:51:56 [8]: QVariant(QString, "B4A0A4B0A0A47B0E") "/dev/sdf1" "" "ntfs"
15:51:56 [8]: QVariant(QString, "ed7c27e1-4f01-4d91-9d45-a65cc3bcc75b") "/dev/sdf2" "" "ext4"
15:51:56 [8]: QVariant(QString, "5c26342d-88e7-4ba8-8873-7f351582ede9") "/dev/sdf3" "" "btrfs"
15:51:56 [8]: QVariant(QString, "") "/dev/sdf4" "" "extended"
15:51:56 [8]: QVariant(QString, "959d5634-2db6-45e7-8611-e8e8e1906be1") "/dev/sdf5" "" "linuxswap"
15:51:56 [1]: Gathering UUIDs for partitions that exist now.
15:53:01 [1]: Creating FillGlobalStorageJob with bootLoader path "/dev/sde"
15:53:01 [1]: PartitionCodeModule has been asked for jobs. About to return: "Clear all temporary mounts.\nClear mounts for partitioning operations on /dev/sde\nDelete partition /dev/sde4.\nCreate new 516MB partition on /dev/sde (ATA PNY CS2211 480GB) with file system ext4.\nSet flags on 516MB ext4 partition.\nCreate new 50177MB partition on /dev/sde (ATA PNY CS2211 480GB) with file system ext4.\nSet partition information"
15:53:01 [0]: Starting job "Clear all temporary mounts."
15:53:01 [1]: Opened mtab. Lines:
15:53:01 [1]: "proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0"
15:53:01 [1]: "sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0"
15:53:01 [1]: "dev /dev devtmpfs rw,nosuid,relatime,size=12330444k,nr_inodes=3082611,mode=755 0 0"
15:53:01 [1]: "run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0"
15:53:01 [1]: "/dev/sdg1 /run/miso/bootmnt iso9660 ro,relatime 0 0"
15:53:01 [1]: "cowspace /run/miso/cowspace tmpfs rw,relatime,size=262144k,mode=755 0 0"
15:53:01 [1]: "overlay_root /run/miso/overlay_root tmpfs rw,relatime,size=18512700k,mode=755 0 0"
15:53:01 [1]: "/dev/loop0 /run/miso/sfs/livefs squashfs ro,relatime 0 0"
15:53:01 [1]: "/dev/loop1 /run/miso/sfs/mhwdfs squashfs ro,relatime 0 0"
15:53:01 [1]: "/dev/loop2 /run/miso/sfs/desktopfs squashfs ro,relatime 0 0"
15:53:01 [1]: "/dev/loop3 /run/miso/sfs/rootfs squashfs ro,relatime 0 0"
15:53:01 [1]: "overlay / overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work 0 0"
15:53:01 [1]: "securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0"
15:53:01 [1]: "tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0"
15:53:01 [1]: "devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0"
15:53:01 [1]: "tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd 0 0"
15:53:01 [1]: "pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0"
15:53:01 [1]: "cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0"
15:53:01 [1]: "systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=34,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0"
15:53:01 [1]: "mqueue /dev/mqueue mqueue rw,relatime 0 0"
15:53:01 [1]: "debugfs /sys/kernel/debug debugfs rw,relatime 0 0"
15:53:01 [1]: "hugetlbfs /dev/hugepages hugetlbfs rw,relatime 0 0"
15:53:01 [1]: "tmpfs /tmp tmpfs rw,nosuid,nodev 0 0"
15:53:01 [1]: "configfs /sys/kernel/config configfs rw,relatime 0 0"
15:53:01 [1]: "tmpfs /etc/pacman.d/gnupg tmpfs rw,relatime,mode=755 0 0"
15:53:01 [1]: "fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0"
15:53:01 [1]: "tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=2468356k,mode=700,uid=1000,gid=1000 0 0"
15:53:01 [1]: "gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0"
15:53:01 [1]: ClearTempMountsJob finished. Here's what was done:
15:53:01 [0]: Starting job "Clear mounts for partitioning operations on /dev/sde"
15:53:01 [1]: ClearMountsJob finished. Here's what was done:
15:53:01 [0]: Starting job "Delete partition /dev/sde4."
15:53:02 [0]: Starting job "Create new 516MB partition on /dev/sde (ATA PNY CS2211 480GB) with file system ext4."
15:53:02 [0]: Starting job "Set flags on partition /dev/sde4."
15:53:02 [0]: Starting job "Create new 50177MB partition on /dev/sde (ATA PNY CS2211 480GB) with file system ext4."
15:53:03 [0]: Installation failed:
15:53:03 [0]: - message: "The installer failed to create partition on disk 'ATA PNY CS2211 480GB'."
15:53:03 [0]: - details: "Failed to add partition ‘New Partition’ to device ‘/dev/sde’.\n\n\n\n"
15:54:44 [0]: Calamares will now quit.
15:54:44 [8]: Shutting down Calamares...
15:54:44 [8]: Finished shutdown.
15:54:44 [0]: QBasicTimer::start: QBasicTimer can only be used with threads started with QThread
Also, the Calamares installer is still not remembering storage choices and is resetting the location of the bootloader to the first storage drive it recognizes.
This is bad thing. Someone can install to drive ‘a’ and the bootloader could be installed to a different drive and overwrite MBR that user does not want written! E.g., a windOS install on a separate HDD/SDD.
c-ya
#19
I guess I spoke too soon about the segfault.
I decided to give the installer another chance.
It segfaulted:
16:35:46 [1]: Calamares version: 3.1.0
16:35:46 [1]: Default font =====
Pixel size:    -1
Point size:    10
Point sizeF:   10
Metric height: 18
16:35:46 [1]: Font height: 18
16:35:46 [1]: Available languages: ("ar", "ast", "bg", "ca", "cs_CZ", "da", "de", "el", "en", "en_GB", "es_MX", "es", "eu", "fr", "hr", "hu", "id", "is", "it_IT", "ja", "lt", "nl", "pl", "pt_BR", "pt_PT", "ro", "ru", "sk", "sv", "th", "tr_TR", "zh_CN", "zh_TW")
16:35:46 [1]: CalamaresApplication thread: 0x19209d0
16:35:46 [1]: Using log file: "/home/manjaro/.cache/Calamares/Calamares/Calamares.log"
16:35:46 [1]: Using Calamares settings file at "/etc/calamares/settings.conf"
16:35:46 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
16:35:46 [1]: WARNING: the selected branding component does not ship translations.
16:35:46 [1]: Loaded branding component "manjaro"
16:35:46 [1]: STARTUP: initQmlPath, initSettings, initBranding done
16:35:46 [1]: STARTUP: initModuleManager: module init started
16:35:46 [1]: STARTUP: initModuleManager: all modules init done
16:35:46 [1]: STARTUP: initJobQueue done
16:35:46 [1]: Proposed window size: 1080 648
16:35:46 [1]: STARTUP: CalamaresWindow created; loadModules started
16:35:46 [1]: Initial locale  "en_US"
16:35:46 [8]: Translation: Calamares: Using system locale: "en_US"
16:35:46 [8]: Translation: Qt: Using default locale, system locale one not found: "en_US"
16:35:46 [1]: ViewModule "welcome@welcome" loading complete.
16:35:46 [1]: WARNING: cannot acquire a list of available locales. The locale and localecfg modules will be broken as long as this system does not provide  * a /usr/share/i18n/SUPPORTED file  OR  * a well-formed /etc/locale.gen     OR  * a complete pre-compiled locale-gen database which allows complete locale -a output.
16:35:46 [1]: ViewModule "locale@locale" loading complete.
16:35:47 [1]: ViewModule "keyboard@keyboard" loading complete.
16:35:47 [8]: Loaded backend plugin:  "pmlibpartedbackendplugin"
16:35:47 [1]: ViewModule "partition@partition" loading complete.
16:35:47 [1]: ViewModule "users@users" loading complete.
16:35:47 [1]: ViewModule "summary@summary" loading complete.
16:35:47 [1]: Module "partition@partition" already loaded.
16:35:47 [1]: QML import paths: ("/usr/share/calamares/qml", "/usr/bin", "qrc:/qt-project.org/imports", "/usr/lib/qt/qml")
16:35:47 [1]: LAST VS IS EVS!
16:35:47 [1]: Module "locale@locale" already loaded.
16:35:47 [1]: Module "keyboard@keyboard" already loaded.
16:35:47 [1]: Module "users@users" already loaded.
16:35:47 [0]: void Calamares::Module::loadConfigurationFile(const QString&) bad module configuration format "/usr/share/calamares/modules/umount.conf"
16:35:47 [1]: ViewModule "finished@finished" loading complete.
16:35:47 [1]: STARTUP: loadModules for all modules done
16:35:47 [1]: STARTUP: Window now visible and ProgressTreeView populated
16:35:47 [1]: Need at least storage bytes: 8482560409
16:35:47 [1]: Need at least ram bytes: 1073741824
16:35:47 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot:  true true true true true
16:35:48 [1]: xkbmap selection changed to:  "us" - ""
Segmentation fault
Have Fun!
#20
If you are willing to give it another try.
Please reboot livecd.
Before starting installer, install in live session calamares-dev.
Then start installation.
