I like Manjaro … it’s … very Kool and everything …
…it’s just too freaking Too Slow ! ha ha
It’s on 1TB SDD. I have i-7 clip. I have 32GB of ram…
… I am like, am I back in the 1990’s ? ha ha
From the grub menu to logon, it takes one minute. From login to desktop, it takes one minute.
Even the apps are slow to start.
I have Windows 10, Ubuntu and elementary and I have no issues.
Any command lines that will fix this issues ?
Thanks ! I will appreciate it’. I want to keep Manjaro too.
I had similar issues (here )
Can you put the output of
systemd-analyze blame
Or at least say how long it takes and what’s the top most lines…
Edit: a typo…
it says “bash: systemd-anlayze: command not found”
My bad…
It was a typo…
It should be ANALYZE like so:
omano
4 March 2021 05:15
5
Output of:
systemd-analyze
systemd-analyze critical-chain
Takes me 20 seconds to boot, because I have a slow BIOS that takes half of the boot time (so without the slow BIOS it would boot in 10 seconds actually). Manjaro is not slow, you have an issue.
12.982s dev-sda1.device
12.589s snapd.service
6.274s dev-loop1.device
5.979s dev-loop16.device
5.724s dev-loop2.device
5.552s dev-loop8.device
5.532s dev-loop11.device
4.830s dev-loop4.device
4.762s accounts-daemon.service
4.642s dev-loop13.device
4.619s NetworkManager.service
4.501s avahi-daemon.service
4.496s systemd-logind.service
4.225s dev-loop17.device
4.073s dev-loop7.device
lines 1-15
omano
4 March 2021 05:19
7
Give full output of each commands, not just first lines.
