Manjaro installer force quits right after it starts
Hi, I just dual booted Win 11 with Manjaro. Anyone have a clue why the installer window closes out right after i open it?
It pulls out the window then closes it after it’s done loading. It confuses the heck outta me.
Hello,
Secure boot and fast boot enabled? Disable them …
I’ve turned off secure boot but can’t find a fast boot option
I also have an issue where all my files get wiped and everything gets reset everytime i restart/shut down the system. Is this normal?
fast boot or fast startup needs to be disabled in windows …
and what do you mean you lose all files after restart/shurdown? did you managed to install it, or are you still in the live usb session, if youre in the live usb session, then of course you lose everything after restart/shutdown…
I don’t know what a live USB session is but I think that’s what im doing. Do i just keep the USB in the PC and open the boot menu or are there more instructions? I’m also gonna try to disable fast boot
so you didnt install manjaro yet, so you are booting from the usb … yes disable it from windows …
How do i like… NOT boot it from the USB? I have the disk image working and I can launch it whenever
